    MagicMirror² v2.15.0 is available don't work.
    44 Posts 9 Posters 17.4k Views 10 Watching
    • unfriendlydeviceU Offline
      unfriendlydevice @sdetweil
      @sdetweil to run the electron-rebuild as you advised (sorry I think I replied to the main thread instead of your earlier reply)
        sdetweil @unfriendlydevice
        @unfriendlydevice
        cd ~/MagicMirror
        npm install electron-rebuild
        now change to your module folder where u need the electron rebuild
        then
        ~/MagicMirror/node_modules/.bin/electron-rebuild
        (note the dot . in front of bin)
        unfriendlydeviceU 1 Reply Last reply Reply Quote 1
          @sdetweil That’s great thanks
          • C Offline
            ChrizZz @ChrizZz
            @chrizzz said in MagicMirror² v2.15.0 is available don't work.:
            I do have some strange things after the update.
            At first, the new weather module is just “loading” without displaying content. Even after 30+ minutes. Is there something wrong with the config? I saw that there is a minor issue with the data request which will cause it to load for ~10min (or to reduce the update interval).
            			module: "weather",
            			classes: "always",
            				type: "current",
            				locationID: "YYY",
            				appid: "XXX"
            I checked this again with switching back to the old module and the old module works. The forcasting takes 10min (as expected) but the module itself works. I thought this might be something with the connection to the API. Any ideas?
            • 5 / 5
