    MagicMirror² v2.15.0 is available don't work.
    44 Posts 9 Posters 20.2k Views 10 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sdetweil
      @sdetweil do i have to replace current weather and forecast?
        sdetweil @Stoffbeuteluwe
        @stoffbeuteluwe no… but there won’t be any fixes…
          @sdetweil how can I get the new module or code ?
            @stoffbeuteluwe yes, both in one
              @sdetweil how can I get the new one ?
              • L Offline
                linuxha
                I’ve been playing with weather.gov and it seems to be having problems. My config:
                			module: "weather",
                			type: "current",
                			weatherProvider: "weather.gov", //
                			windUnits: "imperial",
                			tempUnits: "imperial",
                			useBeaufort: false,
                			fade: false,
                				apiBase: "https://api.weather.gov/points/",
                				weatherEndpoint: "/forecast/hourly", // for current
                				lat:        40.25571,
                				lon:        -74.39416,
                			module: "weather",
                			type: "daily",
                			weatherProvider: "weather.gov", //Default value: openweathermap
                			useBeaufort: false,
                			fade: false,
                				weatherEndpoint: "/forecast", // for forecast
                				lat:        40.25571,
                				lon:        -74.39416,
                and from the browser:
                api.weather.gov/points/2.5/forecast/hourly?lat=40.25571&lon=-74.39416&units=imperial&lang=en&APPID=:1 Failed to load resource: the server responded with a status of 404 ()
                openweathermap.js:45 Could not load data ...  XMLHttpRequest
                (anonymous) @ openweathermap.js:45
                That URL is all sorts of wonky. The points URL returns the points to get the needed properties:
                Mine: https://api.weather.gov/points/40.25571,-74.39416 (under properties “gridId”: “PHI”,“gridX”: 73,“gridY”: 92, )
                then builds:
                Mine: https://api.weather.gov/gridpoints/PHI/73,92/forecast
                  sdetweil @linuxha
                  @linuxha forecast has a problem… there is a timing bug in the module…
                  if u change the updateInterval to 1 minute it will update then , or 2 minutes,
                  default is 10 and it will update then, but 10 minutes is a long time to wait for 1st update…
                  I opened an issue , someone has to work on it.
                  sadly it is not any easy fix
                  L 1 Reply Last reply Reply Quote 1
                  • L Offline
                    linuxha @sdetweil
                    @sdetweil thanks, I made the changes but the results are the same. I think there’s something else wrong with the weather.gov part of the module.
                    • BKeyportB Offline
                      BKeyport Module Developer
                      Problem with MMM-DHT-Sensor with v2.15.0 - Can you guys help me get this module back operating?
                      > mmm-dht-sensor@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-DHT-Sensor
                      > electron-rebuild -e ../../node_modules/electron
                      ⠋ Searching dependency tree
                      An unhandled error occurred inside electron-rebuild
                      Could not detect abi for version 11.3.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                      Error: Could not detect abi for version 11.3.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                          at Object.getAbi (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/node-abi/index.js:30:9)
                          at new Rebuilder (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:126:28)
                          at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:404:23)
                          at Object.doRebuild [as rebuild] (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:427:16)
                          at /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/cli.js:120:33
                          at Generator.next (<anonymous>)
                          at fulfilled (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/cli.js:6:58)
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 255
                      npm ERR! mmm-dht-sensor@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron`
                      npm ERR! Exit status 255
                      npm ERR!
                      npm ERR! Failed at the mmm-dht-sensor@1.1.1 postinstall script.
                      npm ERR!     /home/pi/.npm/_logs/2021-04-02T22_35_34_988Z-debug.log
                      Log is as follows:
                      1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'install' ]
                      2 info using npm@6.14.10
                      3 info using node@v10.24.0
                      4 verbose npm-session 2c69a8fa27d520f4
                      5 silly install runPreinstallTopLevelLifecycles
                      6 silly preinstall mmm-dht-sensor@1.1.1
                      7 info lifecycle mmm-dht-sensor@1.1.1~preinstall: mmm-dht-sensor@1.1.1
                      8 silly install loadCurrentTree
                      9 silly install readLocalPackageData
                      10 timing stage:loadCurrentTree Completed in 3333ms
                      11 silly install loadIdealTree
                      12 silly install cloneCurrentTreeToIdealTree
                      13 timing stage:loadIdealTree:cloneCurrentTree Completed in 29ms
                      14 silly install loadShrinkwrap
                      15 timing stage:loadIdealTree:loadShrinkwrap Completed in 1663ms
                      16 silly install loadAllDepsIntoIdealTree
                      17 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 1711ms
                      18 timing stage:loadIdealTree Completed in 4008ms
                      19 silly currentTree mmm-dht-sensor@1.1.1
                      19 silly currentTree ├── abbrev@1.1.1
                      19 silly currentTree ├── ajv@6.12.2
                      19 silly currentTree ├── ansi-regex@2.1.1
                      19 silly currentTree ├── ansi-styles@3.2.1
                      19 silly currentTree ├── aproba@1.2.0
                      19 silly currentTree ├── are-we-there-yet@1.1.5
                      19 silly currentTree ├── asn1@0.2.4
                      19 silly currentTree ├── assert-plus@1.0.0
                      19 silly currentTree ├── asynckit@0.4.0
                      19 silly currentTree ├── aws-sign2@0.7.0
                      19 silly currentTree ├── aws4@1.9.1
                      19 silly currentTree ├── balanced-match@1.0.0
                      19 silly currentTree ├── bcrypt-pbkdf@1.0.2
                      19 silly currentTree ├── brace-expansion@1.1.11
                      19 silly currentTree ├── camelcase@5.3.1
                      19 silly currentTree ├── caseless@0.12.0
                      19 silly currentTree ├── chalk@2.4.2
                      19 silly currentTree ├── chownr@1.1.4
                      19 silly currentTree ├── cli-cursor@2.1.0
                      19 silly currentTree ├── cli-spinners@2.3.0
                      19 silly currentTree ├─┬ cliui@5.0.0
                      19 silly currentTree │ ├── ansi-regex@4.1.0
                      19 silly currentTree │ ├── is-fullwidth-code-point@2.0.0
                      19 silly currentTree │ ├── string-width@3.1.0
                      19 silly currentTree │ └── strip-ansi@5.2.0
                      19 silly currentTree ├── clone@1.0.4
                      19 silly currentTree ├── code-point-at@1.1.0
                      19 silly currentTree ├── color-convert@1.9.3
                      19 silly currentTree ├── color-name@1.1.3
                      19 silly currentTree ├── colors@1.4.0
                      19 silly currentTree ├── combined-stream@1.0.8
                      19 silly currentTree ├── concat-map@0.0.1
                      19 silly currentTree ├── console-control-strings@1.1.0
                      19 silly currentTree ├── core-util-is@1.0.2
                      19 silly currentTree ├── dashdash@1.14.1
                      19 silly currentTree ├── debug@4.1.1
                      19 silly currentTree ├── decamelize@1.2.0
                      19 silly currentTree ├── defaults@1.0.3
                      19 silly currentTree ├── delayed-stream@1.0.0
                      19 silly currentTree ├── delegates@1.0.0
                      19 silly currentTree ├── detect-libc@1.0.3
                      19 silly currentTree ├── ecc-jsbn@0.1.2
                      19 silly currentTree ├── electron-rebuild@1.10.1
                      19 silly currentTree ├── emoji-regex@7.0.3
                      19 silly currentTree ├── env-paths@2.2.0
                      19 silly currentTree ├── escape-string-regexp@1.0.5
                      19 silly currentTree ├── extend@3.0.2
                      19 silly currentTree ├── extsprintf@1.3.0
                      19 silly currentTree ├── fast-deep-equal@3.1.1
                      19 silly currentTree ├── fast-json-stable-stringify@2.1.0
                      19 silly currentTree ├── find-up@3.0.0
                      19 silly currentTree ├── forever-agent@0.6.1
                      19 silly currentTree ├── form-data@2.3.3
                      19 silly currentTree ├── fs-extra@8.1.0
                      19 silly currentTree ├── fs-minipass@1.2.7
                      19 silly currentTree ├── fs.realpath@1.0.0
                      19 silly currentTree ├── gauge@2.7.4
                      19 silly currentTree ├── get-caller-file@2.0.5
                      19 silly currentTree ├── getpass@0.1.7
                      19 silly currentTree ├── glob@7.1.6
                      19 silly currentTree ├── graceful-fs@4.2.3
                      19 silly currentTree ├── har-schema@2.0.0
                      19 silly currentTree ├── har-validator@5.1.3
                      19 silly currentTree ├── has-flag@3.0.0
                      19 silly currentTree ├── has-unicode@2.0.1
                      19 silly currentTree ├── http-signature@1.2.0
                      19 silly currentTree ├── inflight@1.0.6
                      19 silly currentTree ├── inherits@2.0.4
                      19 silly currentTree ├── is-fullwidth-code-point@1.0.0
                      19 silly currentTree ├── is-typedarray@1.0.0
                      19 silly currentTree ├── isarray@1.0.0
                      19 silly currentTree ├── isexe@2.0.0
                      19 silly currentTree ├── isstream@0.1.2
                      19 silly currentTree ├── jsbn@0.1.1
                      19 silly currentTree ├── json-schema-traverse@0.4.1
                      19 silly currentTree ├── json-schema@0.2.3
                      19 silly currentTree ├── json-stringify-safe@5.0.1
                      19 silly currentTree ├── jsonfile@4.0.0
                      19 silly currentTree ├── jsprim@1.4.1
                      19 silly currentTree ├── locate-path@3.0.0
                      19 silly currentTree ├── lodash.assign@4.2.0
                      19 silly currentTree ├── log-symbols@2.2.0
                      19 silly currentTree ├── mime-db@1.44.0
                      19 silly currentTree ├── mime-types@2.1.27
                      19 silly currentTree ├── mimic-fn@1.2.0
                      19 silly currentTree ├── minimatch@3.0.4
                      19 silly currentTree ├── minimist@1.2.5
                      19 silly currentTree ├── minipass@2.9.0
                      19 silly currentTree ├── minizlib@1.3.3
                      19 silly currentTree ├── mkdirp@0.5.5
                      19 silly currentTree ├── ms@2.1.2
                      19 silly currentTree ├── node-abi@2.16.0
                      19 silly currentTree ├── node-addon-api@1.7.2
                      19 silly currentTree ├── node-dht-sensor@0.4.3
                      19 silly currentTree ├── node-gyp@6.1.0
                      19 silly currentTree ├── nopt@4.0.3
                      19 silly currentTree ├── npmlog@4.1.2
                      19 silly currentTree ├── number-is-nan@1.0.1
                      19 silly currentTree ├── oauth-sign@0.9.0
                      19 silly currentTree ├── object-assign@4.1.1
                      19 silly currentTree ├── once@1.4.0
                      19 silly currentTree ├── onetime@2.0.1
                      19 silly currentTree ├─┬ ora@3.4.0
                      19 silly currentTree ├── os-homedir@1.0.2
                      19 silly currentTree ├── os-tmpdir@1.0.2
                      19 silly currentTree ├── osenv@0.1.5
                      19 silly currentTree ├── p-limit@2.3.0
                      19 silly currentTree ├── p-locate@3.0.0
                      19 silly currentTree ├── p-try@2.2.0
                      19 silly currentTree ├── path-exists@3.0.0
                      19 silly currentTree ├── path-is-absolute@1.0.1
                      19 silly currentTree ├── performance-now@2.1.0
                      19 silly currentTree ├── process-nextick-args@2.0.1
                      19 silly currentTree ├── psl@1.8.0
                      19 silly currentTree ├── punycode@2.1.1
                      19 silly currentTree ├── qs@6.5.2
                      19 silly currentTree ├── readable-stream@2.3.7
                      19 silly currentTree ├── request@2.88.2
                      19 silly currentTree ├── require-directory@2.1.1
                      19 silly currentTree ├── require-main-filename@2.0.0
                      19 silly currentTree ├── restore-cursor@2.0.0
                      19 silly currentTree ├── rimraf@2.7.1
                      19 silly currentTree ├── rxjs@6.5.5
                      19 silly currentTree ├── safe-buffer@5.1.2
                      19 silly currentTree ├── safer-buffer@2.1.2
                      19 silly currentTree ├── semver@5.7.1
                      19 silly currentTree ├── set-blocking@2.0.0
                      19 silly currentTree ├── signal-exit@3.0.3
                      19 silly currentTree ├─┬ spawn-rx@3.0.0
                      19 silly currentTree │ ├── debug@2.6.9
                      19 silly currentTree │ └── ms@2.0.0
                      19 silly currentTree ├── sshpk@1.16.1
                      19 silly currentTree ├── string_decoder@1.1.1
                      19 silly currentTree ├── string-width@1.0.2
                      19 silly currentTree ├── strip-ansi@3.0.1
                      19 silly currentTree ├── supports-color@5.5.0
                      19 silly currentTree ├── tar@4.4.13
                      19 silly currentTree ├── tough-cookie@2.5.0
                      19 silly currentTree ├── tslib@1.11.1
                      19 silly currentTree ├── tunnel-agent@0.6.0
                      19 silly currentTree ├── tweetnacl@0.14.5
                      19 silly currentTree ├── universalify@0.1.2
                      19 silly currentTree ├── uri-js@4.2.2
                      19 silly currentTree ├── util-deprecate@1.0.2
                      19 silly currentTree ├── uuid@3.4.0
                      19 silly currentTree ├── verror@1.10.0
                      19 silly currentTree ├── wcwidth@1.0.1
                      19 silly currentTree ├── which-module@2.0.0
                      19 silly currentTree ├── which@1.3.1
                      19 silly currentTree ├── wide-align@1.1.3
                      19 silly currentTree ├─┬ wrap-ansi@5.1.0
                      19 silly currentTree ├── wrappy@1.0.2
                      19 silly currentTree ├── y18n@4.0.0
                      19 silly currentTree ├── yallist@3.1.1
                      19 silly currentTree ├── yargs-parser@15.0.1
                      19 silly currentTree └─┬ yargs@14.2.3
                      19 silly currentTree   ├── ansi-regex@4.1.0
                      19 silly currentTree   ├── is-fullwidth-code-point@2.0.0
                      19 silly currentTree   ├── string-width@3.1.0
                      19 silly currentTree   └── strip-ansi@5.2.0
                      20 silly idealTree mmm-dht-sensor@1.1.1
                      20 silly idealTree ├── abbrev@1.1.1
                      20 silly idealTree ├── ajv@6.12.2
                      20 silly idealTree ├── ansi-regex@2.1.1
                      20 silly idealTree ├── ansi-styles@3.2.1
                      20 silly idealTree ├── aproba@1.2.0
                      20 silly idealTree ├── are-we-there-yet@1.1.5
                      20 silly idealTree ├── asn1@0.2.4
                      20 silly idealTree ├── assert-plus@1.0.0
                      20 silly idealTree ├── asynckit@0.4.0
                      20 silly idealTree ├── aws-sign2@0.7.0
                      20 silly idealTree ├── aws4@1.9.1
                      20 silly idealTree ├── balanced-match@1.0.0
                      20 silly idealTree ├── bcrypt-pbkdf@1.0.2
                      20 silly idealTree ├── brace-expansion@1.1.11
                      20 silly idealTree ├── camelcase@5.3.1
                      20 silly idealTree ├── caseless@0.12.0
                      20 silly idealTree ├── chalk@2.4.2
                      20 silly idealTree ├── chownr@1.1.4
                      20 silly idealTree ├── cli-cursor@2.1.0
                      20 silly idealTree ├── cli-spinners@2.3.0
                      20 silly idealTree ├─┬ cliui@5.0.0
                      20 silly idealTree │ ├── ansi-regex@4.1.0
                      20 silly idealTree │ ├── is-fullwidth-code-point@2.0.0
                      20 silly idealTree │ ├── string-width@3.1.0
                      20 silly idealTree │ └── strip-ansi@5.2.0
                      20 silly idealTree ├── clone@1.0.4
                      20 silly idealTree ├── code-point-at@1.1.0
                      20 silly idealTree ├── color-convert@1.9.3
                      20 silly idealTree ├── color-name@1.1.3
                      20 silly idealTree ├── colors@1.4.0
                      20 silly idealTree ├── combined-stream@1.0.8
                      20 silly idealTree ├── concat-map@0.0.1
                      20 silly idealTree ├── console-control-strings@1.1.0
                      20 silly idealTree ├── core-util-is@1.0.2
                      20 silly idealTree ├── dashdash@1.14.1
                      20 silly idealTree ├── debug@4.1.1
                      20 silly idealTree ├── decamelize@1.2.0
                      20 silly idealTree ├── defaults@1.0.3
                      20 silly idealTree ├── delayed-stream@1.0.0
                      20 silly idealTree ├── delegates@1.0.0
                      20 silly idealTree ├── detect-libc@1.0.3
                      20 silly idealTree ├── ecc-jsbn@0.1.2
                      20 silly idealTree ├── electron-rebuild@1.10.1
                      20 silly idealTree ├── emoji-regex@7.0.3
                      20 silly idealTree ├── env-paths@2.2.0
                      20 silly idealTree ├── escape-string-regexp@1.0.5
                      20 silly idealTree ├── extend@3.0.2
                      20 silly idealTree ├── extsprintf@1.3.0
                      20 silly idealTree ├── fast-deep-equal@3.1.1
                      20 silly idealTree ├── fast-json-stable-stringify@2.1.0
                      20 silly idealTree ├── find-up@3.0.0
                      20 silly idealTree ├── forever-agent@0.6.1
                      20 silly idealTree ├── form-data@2.3.3
                      20 silly idealTree ├── fs-extra@8.1.0
                      20 silly idealTree ├── fs-minipass@1.2.7
                      20 silly idealTree ├── fs.realpath@1.0.0
                      20 silly idealTree ├── gauge@2.7.4
                      20 silly idealTree ├── get-caller-file@2.0.5
                      20 silly idealTree ├── getpass@0.1.7
                      20 silly idealTree ├── glob@7.1.6
                      20 silly idealTree ├── graceful-fs@4.2.3
                      20 silly idealTree ├── har-schema@2.0.0
                      20 silly idealTree ├── har-validator@5.1.3
                      20 silly idealTree ├── has-flag@3.0.0
                      20 silly idealTree ├── has-unicode@2.0.1
                      20 silly idealTree ├── http-signature@1.2.0
                      20 silly idealTree ├── inflight@1.0.6
                      20 silly idealTree ├── inherits@2.0.4
                      20 silly idealTree ├── is-fullwidth-code-point@1.0.0
                      20 silly idealTree ├── is-typedarray@1.0.0
                      20 silly idealTree ├── isarray@1.0.0
                      20 silly idealTree ├── isexe@2.0.0
                      20 silly idealTree ├── isstream@0.1.2
                      20 silly idealTree ├── jsbn@0.1.1
                      20 silly idealTree ├── json-schema-traverse@0.4.1
                      20 silly idealTree ├── json-schema@0.2.3
                      20 silly idealTree ├── json-stringify-safe@5.0.1
                      20 silly idealTree ├── jsonfile@4.0.0
                      20 silly idealTree ├── jsprim@1.4.1
                      20 silly idealTree ├── locate-path@3.0.0
                      20 silly idealTree ├── lodash.assign@4.2.0
                      20 silly idealTree ├── log-symbols@2.2.0
                      20 silly idealTree ├── mime-db@1.44.0
                      20 silly idealTree ├── mime-types@2.1.27
                      20 silly idealTree ├── mimic-fn@1.2.0
                      20 silly idealTree ├── minimatch@3.0.4
                      20 silly idealTree ├── minimist@1.2.5
                      20 silly idealTree ├── minipass@2.9.0
                      20 silly idealTree ├── minizlib@1.3.3
                      20 silly idealTree ├── mkdirp@0.5.5
                      20 silly idealTree ├── ms@2.1.2
                      20 silly idealTree ├── node-abi@2.16.0
                      20 silly idealTree ├── node-addon-api@1.7.2
                      20 silly idealTree ├── node-dht-sensor@0.4.3
                      20 silly idealTree ├── node-gyp@6.1.0
                      20 silly idealTree ├── nopt@4.0.3
                      20 silly idealTree ├── npmlog@4.1.2
                      20 silly idealTree ├── number-is-nan@1.0.1
                      20 silly idealTree ├── oauth-sign@0.9.0
                      20 silly idealTree ├── object-assign@4.1.1
                      20 silly idealTree ├── once@1.4.0
                      20 silly idealTree ├── onetime@2.0.1
                      20 silly idealTree ├─┬ ora@3.4.0
                      20 silly idealTree ├── os-homedir@1.0.2
                      20 silly idealTree ├── os-tmpdir@1.0.2
                      20 silly idealTree ├── osenv@0.1.5
                      20 silly idealTree ├── p-limit@2.3.0
                      20 silly idealTree ├── p-locate@3.0.0
                      20 silly idealTree ├── p-try@2.2.0
                      20 silly idealTree ├── path-exists@3.0.0
                      20 silly idealTree ├── path-is-absolute@1.0.1
                      20 silly idealTree ├── performance-now@2.1.0
                      20 silly idealTree ├── process-nextick-args@2.0.1
                      20 silly idealTree ├── psl@1.8.0
                      20 silly idealTree ├── punycode@2.1.1
                      20 silly idealTree ├── qs@6.5.2
                      20 silly idealTree ├── readable-stream@2.3.7
                      20 silly idealTree ├── request@2.88.2
                      20 silly idealTree ├── require-directory@2.1.1
                      20 silly idealTree ├── require-main-filename@2.0.0
                      20 silly idealTree ├── restore-cursor@2.0.0
                      20 silly idealTree ├── rimraf@2.7.1
                      20 silly idealTree ├── rxjs@6.5.5
                      20 silly idealTree ├── safe-buffer@5.1.2
                      20 silly idealTree ├── safer-buffer@2.1.2
                      20 silly idealTree ├── semver@5.7.1
                      20 silly idealTree ├── set-blocking@2.0.0
                      20 silly idealTree ├── signal-exit@3.0.3
                      20 silly idealTree ├─┬ spawn-rx@3.0.0
                      20 silly idealTree │ ├── debug@2.6.9
                      20 silly idealTree │ └── ms@2.0.0
                      20 silly idealTree ├── sshpk@1.16.1
                      20 silly idealTree ├── string_decoder@1.1.1
                      20 silly idealTree ├── string-width@1.0.2
                      20 silly idealTree ├── strip-ansi@3.0.1
                      20 silly idealTree ├── supports-color@5.5.0
                      20 silly idealTree ├── tar@4.4.13
                      20 silly idealTree ├── tough-cookie@2.5.0
                      20 silly idealTree ├── tslib@1.11.1
                      20 silly idealTree ├── tunnel-agent@0.6.0
                      20 silly idealTree ├── tweetnacl@0.14.5
                      20 silly idealTree ├── universalify@0.1.2
                      20 silly idealTree ├── uri-js@4.2.2
                      20 silly idealTree ├── util-deprecate@1.0.2
                      20 silly idealTree ├── uuid@3.4.0
                      20 silly idealTree ├── verror@1.10.0
                      20 silly idealTree ├── wcwidth@1.0.1
                      20 silly idealTree ├── which-module@2.0.0
                      20 silly idealTree ├── which@1.3.1
                      20 silly idealTree ├── wide-align@1.1.3
                      20 silly idealTree ├─┬ wrap-ansi@5.1.0
                      20 silly idealTree ├── wrappy@1.0.2
                      20 silly idealTree ├── y18n@4.0.0
                      20 silly idealTree ├── yallist@3.1.1
                      20 silly idealTree ├── yargs-parser@15.0.1
                      20 silly idealTree └─┬ yargs@14.2.3
                      20 silly idealTree   ├── ansi-regex@4.1.0
                      20 silly idealTree   ├── is-fullwidth-code-point@2.0.0
                      20 silly idealTree   ├── string-width@3.1.0
                      20 silly idealTree   └── strip-ansi@5.2.0
                      21 silly install generateActionsToTake
                      22 timing stage:generateActionsToTake Completed in 156ms
                      23 silly diffTrees action count 0
                      24 silly decomposeActions action count 0
                      25 silly install executeActions
                      26 silly doSerial global-install 0
                      27 verbose correctMkdir /home/pi/.npm/_locks correctMkdir not in flight; initializing
                      28 verbose lock using /home/pi/.npm/_locks/staging-27e98ab6b31520c2.lock for /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.staging
                      29 silly doParallel extract 0
                      30 silly doReverseSerial unbuild 0
                      31 silly doSerial remove 0
                      32 silly doSerial move 0
                      33 silly doSerial finalize 0
                      34 silly doParallel refresh-package-json 0
                      35 silly doParallel preinstall 0
                      36 silly doSerial build 0
                      37 silly doSerial global-link 0
                      38 silly doParallel update-linked 0
                      39 silly doSerial install 0
                      40 silly doSerial postinstall 0
                      41 verbose unlock done using /home/pi/.npm/_locks/staging-27e98ab6b31520c2.lock for /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.staging
                      42 timing stage:executeActions Completed in 401ms
                      43 timing stage:rollbackFailedOptional Completed in 1ms
                      44 silly install runPostinstallTopLevelLifecycles
                      45 silly build mmm-dht-sensor@1.1.1
                      46 info linkStuff mmm-dht-sensor@1.1.1
                      47 silly linkStuff mmm-dht-sensor@1.1.1 has /home/pi/MagicMirror/modules as its parent node_modules
                      48 silly install mmm-dht-sensor@1.1.1
                      49 info lifecycle mmm-dht-sensor@1.1.1~install: mmm-dht-sensor@1.1.1
                      50 silly postinstall mmm-dht-sensor@1.1.1
                      51 info lifecycle mmm-dht-sensor@1.1.1~postinstall: mmm-dht-sensor@1.1.1
                      52 verbose lifecycle mmm-dht-sensor@1.1.1~postinstall: unsafe-perm in lifecycle true
                      53 verbose lifecycle mmm-dht-sensor@1.1.1~postinstall: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                      54 verbose lifecycle mmm-dht-sensor@1.1.1~postinstall: CWD: /home/pi/MagicMirror/modules/MMM-DHT-Sensor
                      55 silly lifecycle mmm-dht-sensor@1.1.1~postinstall: Args: [ '-c', 'electron-rebuild -e ../../node_modules/electron' ]
                      56 timing audit submit Completed in 648ms
                      57 http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/audits/quick 658ms
                      58 timing audit body Completed in 20ms
                      59 silly lifecycle mmm-dht-sensor@1.1.1~postinstall: Returned: code: 255  signal: null
                      60 info lifecycle mmm-dht-sensor@1.1.1~postinstall: Failed to exec postinstall script
                      61 verbose stack Error: mmm-dht-sensor@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron`
                      61 verbose stack Exit status 255
                      61 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                      61 verbose stack     at EventEmitter.emit (events.js:198:13)
                      61 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                      61 verbose stack     at ChildProcess.emit (events.js:198:13)
                      61 verbose stack     at maybeClose (internal/child_process.js:982:16)
                      61 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                      62 verbose pkgid mmm-dht-sensor@1.1.1
                      63 verbose cwd /home/pi/MagicMirror/modules/MMM-DHT-Sensor
                      64 verbose Linux 5.10.11-v7l+
                      65 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install"
                      66 verbose node v10.24.0
                      67 verbose npm  v6.14.10
                      68 error code ELIFECYCLE
                      69 error errno 255
                      70 error mmm-dht-sensor@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron`
                      70 error Exit status 255
                      71 error Failed at the mmm-dht-sensor@1.1.1 postinstall script.
                      71 error This is probably not a problem with npm. There is likely additional logging output above.
                      72 verbose exit [ 255, true ]
                        sdetweil @BKeyport
                        @bkeyport from your module folder, can you do this
                        npm ls node-abi
                        • BKeyportB Offline
                          mmm-dht-sensor@1.1.1 /home/pi/MagicMirror/modules/MMM-DHT-Sensor
                          └─┬ electron-rebuild@1.10.1
                            └── node-abi@2.16.0
                          For what it’s worth, it started working again on it’s own after issuing this command. No need to reinstall it’s dependencies.
                          Bizarre.
                            sdetweil @BKeyport
                            @bkeyport great!
                            • C Offline
                              ChrizZz @sdetweil
                              I do have some strange things after the update.
                              At first, the new weather module is just “loading” without displaying content. Even after 30+ minutes. Is there something wrong with the config? I saw that there is a minor issue with the data request which will cause it to load for ~10min (or to reduce the update interval).
                              			module: "weather",
                              			classes: "always",
                              				type: "current",
                              				locationID: "YYY",
                              				appid: "XXX"
                              And I have new lines of errors in the log, I don’t understand why these syntax errors appear. I checked my config file and everything looks fine. Regarding git, does this mean it couldn’t connect to github?
                              [03.04.2021 23:22.22.900] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                              [03.04.2021 23:22.24.037] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                              [03.04.2021 23:22.25.987] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
                              [03.04.2021 23:22.27.080] [ERROR] Failed to fetch git data for MMM-Parcel: Error: block timeout reached
                              [03.04.2021 23:22.35.518] [ERROR] Failed to fetch git data for MMM-Face-Reco-DNN: Error: block timeout reached
                              [03.04.2021 23:22.39.290] [ERROR] Failed to fetch git data for MMM-PIR-Sensor: Error: block timeout reached
                              [03.04.2021 23:32.42.638] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
                              [03.04.2021 23:37.14.466] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                              [03.04.2021 23:37.14.577] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                              [03.04.2021 23:52.14.126] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                              [03.04.2021 23:52.14.377] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                              S C 2 Replies Last reply Reply Quote 0
                                sdetweil @ChrizZz
                                @chrizzz looks like a networking error… did u npm install after git pull? did both work?
                                  danjvd @sdetweil
                                  @sdetweil Thanks for the help, was about to make a post when I found this thread.
                                  • C Offline
                                    ChrizZz @sdetweil
                                    @sdetweil yes I did and both worked.
                                    I did npm install in all module folders too and did the npm install of MM multiple times just to check if something is wrong
                                      Hallo, i have installed the updatescript and than I have installed the valid url …the mirror starts normal and when i stop the Mirror I get this.
                                      nal SIGINT
                                      npm ERR! errno 1
                                      npm ERR! magicmirror@2.15.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the magicmirror@2.15.0 start script.
                                      npm ERR!     /Users/patrickhahn/.npm/_logs/2021-04-06T20_05_51_094Z-debug.log
                                      patrickhahn@Mac-mini MagicMirror %
                                      hope somebody can help me …thanks
                                        @stoffbeuteluwe that’s ok when u stop
                                        • unfriendlydeviceU Offline
                                          unfriendlydevice @sdetweil
                                          @sdetweil what is the full command to run this? I’ve done some searching on the forum but haven’t found anything.
                                            sdetweil @unfriendlydevice
                                            @unfriendlydevice run ‘this’???
                                            unfriendlydeviceU 1 Reply Last reply Reply Quote 0
                                            • 2 / 3
