    MagicMirror² v2.15.0 is available don't work.
    44 Posts 9 Posters 21.7k Views 10 Watching
      sdetweil @BKeyport
      @bkeyport from your module folder, can you do this
      npm ls node-abi
      BKeyportB 1 Reply Last reply
      • BKeyportB
        mmm-dht-sensor@1.1.1 /home/pi/MagicMirror/modules/MMM-DHT-Sensor
        └─┬ electron-rebuild@1.10.1
          └── node-abi@2.16.0
        For what it’s worth, it started working again on it’s own after issuing this command. No need to reinstall it’s dependencies.
        Bizarre.
          sdetweil @BKeyport
          @bkeyport great!
          C 1 Reply Last reply
            ChrizZz @sdetweil
            I do have some strange things after the update.
            At first, the new weather module is just “loading” without displaying content. Even after 30+ minutes. Is there something wrong with the config? I saw that there is a minor issue with the data request which will cause it to load for ~10min (or to reduce the update interval).
            			module: "weather",
            			classes: "always",
            				type: "current",
            				locationID: "YYY",
            				appid: "XXX"
            And I have new lines of errors in the log, I don’t understand why these syntax errors appear. I checked my config file and everything looks fine. Regarding git, does this mean it couldn’t connect to github?
            [03.04.2021 23:22.22.900] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
            [03.04.2021 23:22.24.037] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
            [03.04.2021 23:22.25.987] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
            [03.04.2021 23:22.27.080] [ERROR] Failed to fetch git data for MMM-Parcel: Error: block timeout reached
            [03.04.2021 23:22.35.518] [ERROR] Failed to fetch git data for MMM-Face-Reco-DNN: Error: block timeout reached
            [03.04.2021 23:22.39.290] [ERROR] Failed to fetch git data for MMM-PIR-Sensor: Error: block timeout reached
            [03.04.2021 23:32.42.638] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
            [03.04.2021 23:37.14.466] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
            [03.04.2021 23:37.14.577] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
            [03.04.2021 23:52.14.126] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
            [03.04.2021 23:52.14.377] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
            S C 2 Replies Last reply
              sdetweil @ChrizZz
              @chrizzz looks like a networking error… did u npm install after git pull? did both work?
                danjvd @sdetweil
                @sdetweil Thanks for the help, was about to make a post when I found this thread.
                  ChrizZz @sdetweil
                  @sdetweil yes I did and both worked.
                  I did npm install in all module folders too and did the npm install of MM multiple times just to check if something is wrong
                  • StoffbeuteluweS
                    Stoffbeuteluwe Project Sponsor
                    Hallo, i have installed the updatescript and than I have installed the valid url …the mirror starts normal and when i stop the Mirror I get this.
                    nal SIGINT
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! magicmirror@2.15.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.15.0 start script.
                    npm ERR!     /Users/patrickhahn/.npm/_logs/2021-04-06T20_05_51_094Z-debug.log
                    patrickhahn@Mac-mini MagicMirror %
                    hope somebody can help me …thanks
                      sdetweil @Stoffbeuteluwe
                      @stoffbeuteluwe that’s ok when u stop
                      • unfriendlydeviceU
                        unfriendlydevice @sdetweil
                        @sdetweil what is the full command to run this? I’ve done some searching on the forum but haven’t found anything.
                          sdetweil @unfriendlydevice
                          @unfriendlydevice run ‘this’???
                          unfriendlydeviceU 1 Reply Last reply
                          • unfriendlydeviceU
                            @sdetweil to run the electron-rebuild as you advised (sorry I think I replied to the main thread instead of your earlier reply)
                              @unfriendlydevice
                              npm install electron-rebuild
                              now change to your module folder where u need the electron rebuild
                              then
                              ~/MagicMirror/node_modules/.bin/electron-rebuild
                              (note the dot . in front of bin)
                              • unfriendlydeviceU
                                @sdetweil That’s great thanks
                                  ChrizZz @ChrizZz
                                  @chrizzz said in MagicMirror² v2.15.0 is available don't work.:
                                  			module: "weather",
                                  			classes: "always",
                                  				type: "current",
                                  				locationID: "YYY",
                                  				appid: "XXX"
                                  I checked this again with switching back to the old module and the old module works. The forcasting takes 10min (as expected) but the module itself works. I thought this might be something with the connection to the API. Any ideas?
                                  • 2 / 3
