    MagicMirror² v2.15.0 is available don't work.
    44 Posts 9 Posters 20.5k Views 10 Watching
    • L Offline
      linuxha @sdetweil
      @sdetweil thanks, I made the changes but the results are the same. I think there’s something else wrong with the weather.gov part of the module.
      • BKeyportB Offline
        BKeyport Module Developer
        Problem with MMM-DHT-Sensor with v2.15.0 - Can you guys help me get this module back operating?
        > mmm-dht-sensor@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-DHT-Sensor
        > electron-rebuild -e ../../node_modules/electron
        ⠋ Searching dependency tree
        An unhandled error occurred inside electron-rebuild
        Could not detect abi for version 11.3.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
        Error: Could not detect abi for version 11.3.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
            at Object.getAbi (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/node-abi/index.js:30:9)
            at new Rebuilder (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:126:28)
            at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:404:23)
            at Object.doRebuild [as rebuild] (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:427:16)
            at /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/cli.js:120:33
            at Generator.next (<anonymous>)
            at fulfilled (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/src/cli.js:6:58)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 255
        npm ERR! mmm-dht-sensor@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron`
        npm ERR! Exit status 255
        npm ERR!
        npm ERR! Failed at the mmm-dht-sensor@1.1.1 postinstall script.
        npm ERR!     /home/pi/.npm/_logs/2021-04-02T22_35_34_988Z-debug.log
        Log is as follows:
        1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'install' ]
        2 info using npm@6.14.10
        3 info using node@v10.24.0
        4 verbose npm-session 2c69a8fa27d520f4
        5 silly install runPreinstallTopLevelLifecycles
        6 silly preinstall mmm-dht-sensor@1.1.1
        7 info lifecycle mmm-dht-sensor@1.1.1~preinstall: mmm-dht-sensor@1.1.1
        8 silly install loadCurrentTree
        9 silly install readLocalPackageData
        10 timing stage:loadCurrentTree Completed in 3333ms
        11 silly install loadIdealTree
        12 silly install cloneCurrentTreeToIdealTree
        13 timing stage:loadIdealTree:cloneCurrentTree Completed in 29ms
        14 silly install loadShrinkwrap
        15 timing stage:loadIdealTree:loadShrinkwrap Completed in 1663ms
        16 silly install loadAllDepsIntoIdealTree
        17 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 1711ms
        18 timing stage:loadIdealTree Completed in 4008ms
        19 silly currentTree mmm-dht-sensor@1.1.1
        19 silly currentTree ├── abbrev@1.1.1
        19 silly currentTree ├── ajv@6.12.2
        19 silly currentTree ├── ansi-regex@2.1.1
        19 silly currentTree ├── ansi-styles@3.2.1
        19 silly currentTree ├── aproba@1.2.0
        19 silly currentTree ├── are-we-there-yet@1.1.5
        19 silly currentTree ├── asn1@0.2.4
        19 silly currentTree ├── assert-plus@1.0.0
        19 silly currentTree ├── asynckit@0.4.0
        19 silly currentTree ├── aws-sign2@0.7.0
        19 silly currentTree ├── aws4@1.9.1
        19 silly currentTree ├── balanced-match@1.0.0
        19 silly currentTree ├── bcrypt-pbkdf@1.0.2
        19 silly currentTree ├── brace-expansion@1.1.11
        19 silly currentTree ├── camelcase@5.3.1
        19 silly currentTree ├── caseless@0.12.0
        19 silly currentTree ├── chalk@2.4.2
        19 silly currentTree ├── chownr@1.1.4
        19 silly currentTree ├── cli-cursor@2.1.0
        19 silly currentTree ├── cli-spinners@2.3.0
        19 silly currentTree ├─┬ cliui@5.0.0
        19 silly currentTree │ ├── ansi-regex@4.1.0
        19 silly currentTree │ ├── is-fullwidth-code-point@2.0.0
        19 silly currentTree │ ├── string-width@3.1.0
        19 silly currentTree │ └── strip-ansi@5.2.0
        19 silly currentTree ├── clone@1.0.4
        19 silly currentTree ├── code-point-at@1.1.0
        19 silly currentTree ├── color-convert@1.9.3
        19 silly currentTree ├── color-name@1.1.3
        19 silly currentTree ├── colors@1.4.0
        19 silly currentTree ├── combined-stream@1.0.8
        19 silly currentTree ├── concat-map@0.0.1
        19 silly currentTree ├── console-control-strings@1.1.0
        19 silly currentTree ├── core-util-is@1.0.2
        19 silly currentTree ├── dashdash@1.14.1
        19 silly currentTree ├── debug@4.1.1
        19 silly currentTree ├── decamelize@1.2.0
        19 silly currentTree ├── defaults@1.0.3
        19 silly currentTree ├── delayed-stream@1.0.0
        19 silly currentTree ├── delegates@1.0.0
        19 silly currentTree ├── detect-libc@1.0.3
        19 silly currentTree ├── ecc-jsbn@0.1.2
        19 silly currentTree ├── electron-rebuild@1.10.1
        19 silly currentTree ├── emoji-regex@7.0.3
        19 silly currentTree ├── env-paths@2.2.0
        19 silly currentTree ├── escape-string-regexp@1.0.5
        19 silly currentTree ├── extend@3.0.2
        19 silly currentTree ├── extsprintf@1.3.0
        19 silly currentTree ├── fast-deep-equal@3.1.1
        19 silly currentTree ├── fast-json-stable-stringify@2.1.0
        19 silly currentTree ├── find-up@3.0.0
        19 silly currentTree ├── forever-agent@0.6.1
        19 silly currentTree ├── form-data@2.3.3
        19 silly currentTree ├── fs-extra@8.1.0
        19 silly currentTree ├── fs-minipass@1.2.7
        19 silly currentTree ├── fs.realpath@1.0.0
        19 silly currentTree ├── gauge@2.7.4
        19 silly currentTree ├── get-caller-file@2.0.5
        19 silly currentTree ├── getpass@0.1.7
        19 silly currentTree ├── glob@7.1.6
        19 silly currentTree ├── graceful-fs@4.2.3
        19 silly currentTree ├── har-schema@2.0.0
        19 silly currentTree ├── har-validator@5.1.3
        19 silly currentTree ├── has-flag@3.0.0
        19 silly currentTree ├── has-unicode@2.0.1
        19 silly currentTree ├── http-signature@1.2.0
        19 silly currentTree ├── inflight@1.0.6
        19 silly currentTree ├── inherits@2.0.4
        19 silly currentTree ├── is-fullwidth-code-point@1.0.0
        19 silly currentTree ├── is-typedarray@1.0.0
        19 silly currentTree ├── isarray@1.0.0
        19 silly currentTree ├── isexe@2.0.0
        19 silly currentTree ├── isstream@0.1.2
        19 silly currentTree ├── jsbn@0.1.1
        19 silly currentTree ├── json-schema-traverse@0.4.1
        19 silly currentTree ├── json-schema@0.2.3
        19 silly currentTree ├── json-stringify-safe@5.0.1
        19 silly currentTree ├── jsonfile@4.0.0
        19 silly currentTree ├── jsprim@1.4.1
        19 silly currentTree ├── locate-path@3.0.0
        19 silly currentTree ├── lodash.assign@4.2.0
        19 silly currentTree ├── log-symbols@2.2.0
        19 silly currentTree ├── mime-db@1.44.0
        19 silly currentTree ├── mime-types@2.1.27
        19 silly currentTree ├── mimic-fn@1.2.0
        19 silly currentTree ├── minimatch@3.0.4
        19 silly currentTree ├── minimist@1.2.5
        19 silly currentTree ├── minipass@2.9.0
        19 silly currentTree ├── minizlib@1.3.3
        19 silly currentTree ├── mkdirp@0.5.5
        19 silly currentTree ├── ms@2.1.2
        19 silly currentTree ├── node-abi@2.16.0
        19 silly currentTree ├── node-addon-api@1.7.2
        19 silly currentTree ├── node-dht-sensor@0.4.3
        19 silly currentTree ├── node-gyp@6.1.0
        19 silly currentTree ├── nopt@4.0.3
        19 silly currentTree ├── npmlog@4.1.2
        19 silly currentTree ├── number-is-nan@1.0.1
        19 silly currentTree ├── oauth-sign@0.9.0
        19 silly currentTree ├── object-assign@4.1.1
        19 silly currentTree ├── once@1.4.0
        19 silly currentTree ├── onetime@2.0.1
        19 silly currentTree ├─┬ ora@3.4.0
        19 silly currentTree ├── os-homedir@1.0.2
        19 silly currentTree ├── os-tmpdir@1.0.2
        19 silly currentTree ├── osenv@0.1.5
        19 silly currentTree ├── p-limit@2.3.0
        19 silly currentTree ├── p-locate@3.0.0
        19 silly currentTree ├── p-try@2.2.0
        19 silly currentTree ├── path-exists@3.0.0
        19 silly currentTree ├── path-is-absolute@1.0.1
        19 silly currentTree ├── performance-now@2.1.0
        19 silly currentTree ├── process-nextick-args@2.0.1
        19 silly currentTree ├── psl@1.8.0
        19 silly currentTree ├── punycode@2.1.1
        19 silly currentTree ├── qs@6.5.2
        19 silly currentTree ├── readable-stream@2.3.7
        19 silly currentTree ├── request@2.88.2
        19 silly currentTree ├── require-directory@2.1.1
        19 silly currentTree ├── require-main-filename@2.0.0
        19 silly currentTree ├── restore-cursor@2.0.0
        19 silly currentTree ├── rimraf@2.7.1
        19 silly currentTree ├── rxjs@6.5.5
        19 silly currentTree ├── safe-buffer@5.1.2
        19 silly currentTree ├── safer-buffer@2.1.2
        19 silly currentTree ├── semver@5.7.1
        19 silly currentTree ├── set-blocking@2.0.0
        19 silly currentTree ├── signal-exit@3.0.3
        19 silly currentTree ├─┬ spawn-rx@3.0.0
        19 silly currentTree │ ├── debug@2.6.9
        19 silly currentTree │ └── ms@2.0.0
        19 silly currentTree ├── sshpk@1.16.1
        19 silly currentTree ├── string_decoder@1.1.1
        19 silly currentTree ├── string-width@1.0.2
        19 silly currentTree ├── strip-ansi@3.0.1
        19 silly currentTree ├── supports-color@5.5.0
        19 silly currentTree ├── tar@4.4.13
        19 silly currentTree ├── tough-cookie@2.5.0
        19 silly currentTree ├── tslib@1.11.1
        19 silly currentTree ├── tunnel-agent@0.6.0
        19 silly currentTree ├── tweetnacl@0.14.5
        19 silly currentTree ├── universalify@0.1.2
        19 silly currentTree ├── uri-js@4.2.2
        19 silly currentTree ├── util-deprecate@1.0.2
        19 silly currentTree ├── uuid@3.4.0
        19 silly currentTree ├── verror@1.10.0
        19 silly currentTree ├── wcwidth@1.0.1
        19 silly currentTree ├── which-module@2.0.0
        19 silly currentTree ├── which@1.3.1
        19 silly currentTree ├── wide-align@1.1.3
        19 silly currentTree ├─┬ wrap-ansi@5.1.0
        19 silly currentTree ├── wrappy@1.0.2
        19 silly currentTree ├── y18n@4.0.0
        19 silly currentTree ├── yallist@3.1.1
        19 silly currentTree ├── yargs-parser@15.0.1
        19 silly currentTree └─┬ yargs@14.2.3
        19 silly currentTree   ├── ansi-regex@4.1.0
        19 silly currentTree   ├── is-fullwidth-code-point@2.0.0
        19 silly currentTree   ├── string-width@3.1.0
        19 silly currentTree   └── strip-ansi@5.2.0
        20 silly idealTree mmm-dht-sensor@1.1.1
        20 silly idealTree ├── abbrev@1.1.1
        20 silly idealTree ├── ajv@6.12.2
        20 silly idealTree ├── ansi-regex@2.1.1
        20 silly idealTree ├── ansi-styles@3.2.1
        20 silly idealTree ├── aproba@1.2.0
        20 silly idealTree ├── are-we-there-yet@1.1.5
        20 silly idealTree ├── asn1@0.2.4
        20 silly idealTree ├── assert-plus@1.0.0
        20 silly idealTree ├── asynckit@0.4.0
        20 silly idealTree ├── aws-sign2@0.7.0
        20 silly idealTree ├── aws4@1.9.1
        20 silly idealTree ├── balanced-match@1.0.0
        20 silly idealTree ├── bcrypt-pbkdf@1.0.2
        20 silly idealTree ├── brace-expansion@1.1.11
        20 silly idealTree ├── camelcase@5.3.1
        20 silly idealTree ├── caseless@0.12.0
        20 silly idealTree ├── chalk@2.4.2
        20 silly idealTree ├── chownr@1.1.4
        20 silly idealTree ├── cli-cursor@2.1.0
        20 silly idealTree ├── cli-spinners@2.3.0
        20 silly idealTree ├─┬ cliui@5.0.0
        20 silly idealTree │ ├── ansi-regex@4.1.0
        20 silly idealTree │ ├── is-fullwidth-code-point@2.0.0
        20 silly idealTree │ ├── string-width@3.1.0
        20 silly idealTree │ └── strip-ansi@5.2.0
        20 silly idealTree ├── clone@1.0.4
        20 silly idealTree ├── code-point-at@1.1.0
        20 silly idealTree ├── color-convert@1.9.3
        20 silly idealTree ├── color-name@1.1.3
        20 silly idealTree ├── colors@1.4.0
        20 silly idealTree ├── combined-stream@1.0.8
        20 silly idealTree ├── concat-map@0.0.1
        20 silly idealTree ├── console-control-strings@1.1.0
        20 silly idealTree ├── core-util-is@1.0.2
        20 silly idealTree ├── dashdash@1.14.1
        20 silly idealTree ├── debug@4.1.1
        20 silly idealTree ├── decamelize@1.2.0
        20 silly idealTree ├── defaults@1.0.3
        20 silly idealTree ├── delayed-stream@1.0.0
        20 silly idealTree ├── delegates@1.0.0
        20 silly idealTree ├── detect-libc@1.0.3
        20 silly idealTree ├── ecc-jsbn@0.1.2
        20 silly idealTree ├── electron-rebuild@1.10.1
        20 silly idealTree ├── emoji-regex@7.0.3
        20 silly idealTree ├── env-paths@2.2.0
        20 silly idealTree ├── escape-string-regexp@1.0.5
        20 silly idealTree ├── extend@3.0.2
        20 silly idealTree ├── extsprintf@1.3.0
        20 silly idealTree ├── fast-deep-equal@3.1.1
        20 silly idealTree ├── fast-json-stable-stringify@2.1.0
        20 silly idealTree ├── find-up@3.0.0
        20 silly idealTree ├── forever-agent@0.6.1
        20 silly idealTree ├── form-data@2.3.3
        20 silly idealTree ├── fs-extra@8.1.0
        20 silly idealTree ├── fs-minipass@1.2.7
        20 silly idealTree ├── fs.realpath@1.0.0
        20 silly idealTree ├── gauge@2.7.4
        20 silly idealTree ├── get-caller-file@2.0.5
        20 silly idealTree ├── getpass@0.1.7
        20 silly idealTree ├── glob@7.1.6
        20 silly idealTree ├── graceful-fs@4.2.3
        20 silly idealTree ├── har-schema@2.0.0
        20 silly idealTree ├── har-validator@5.1.3
        20 silly idealTree ├── has-flag@3.0.0
        20 silly idealTree ├── has-unicode@2.0.1
        20 silly idealTree ├── http-signature@1.2.0
        20 silly idealTree ├── inflight@1.0.6
        20 silly idealTree ├── inherits@2.0.4
        20 silly idealTree ├── is-fullwidth-code-point@1.0.0
        20 silly idealTree ├── is-typedarray@1.0.0
        20 silly idealTree ├── isarray@1.0.0
        20 silly idealTree ├── isexe@2.0.0
        20 silly idealTree ├── isstream@0.1.2
        20 silly idealTree ├── jsbn@0.1.1
        20 silly idealTree ├── json-schema-traverse@0.4.1
        20 silly idealTree ├── json-schema@0.2.3
        20 silly idealTree ├── json-stringify-safe@5.0.1
        20 silly idealTree ├── jsonfile@4.0.0
        20 silly idealTree ├── jsprim@1.4.1
        20 silly idealTree ├── locate-path@3.0.0
        20 silly idealTree ├── lodash.assign@4.2.0
        20 silly idealTree ├── log-symbols@2.2.0
        20 silly idealTree ├── mime-db@1.44.0
        20 silly idealTree ├── mime-types@2.1.27
        20 silly idealTree ├── mimic-fn@1.2.0
        20 silly idealTree ├── minimatch@3.0.4
        20 silly idealTree ├── minimist@1.2.5
        20 silly idealTree ├── minipass@2.9.0
        20 silly idealTree ├── minizlib@1.3.3
        20 silly idealTree ├── mkdirp@0.5.5
        20 silly idealTree ├── ms@2.1.2
        20 silly idealTree ├── node-abi@2.16.0
        20 silly idealTree ├── node-addon-api@1.7.2
        20 silly idealTree ├── node-dht-sensor@0.4.3
        20 silly idealTree ├── node-gyp@6.1.0
        20 silly idealTree ├── nopt@4.0.3
        20 silly idealTree ├── npmlog@4.1.2
        20 silly idealTree ├── number-is-nan@1.0.1
        20 silly idealTree ├── oauth-sign@0.9.0
        20 silly idealTree ├── object-assign@4.1.1
        20 silly idealTree ├── once@1.4.0
        20 silly idealTree ├── onetime@2.0.1
        20 silly idealTree ├─┬ ora@3.4.0
        20 silly idealTree ├── os-homedir@1.0.2
        20 silly idealTree ├── os-tmpdir@1.0.2
        20 silly idealTree ├── osenv@0.1.5
        20 silly idealTree ├── p-limit@2.3.0
        20 silly idealTree ├── p-locate@3.0.0
        20 silly idealTree ├── p-try@2.2.0
        20 silly idealTree ├── path-exists@3.0.0
        20 silly idealTree ├── path-is-absolute@1.0.1
        20 silly idealTree ├── performance-now@2.1.0
        20 silly idealTree ├── process-nextick-args@2.0.1
        20 silly idealTree ├── psl@1.8.0
        20 silly idealTree ├── punycode@2.1.1
        20 silly idealTree ├── qs@6.5.2
        20 silly idealTree ├── readable-stream@2.3.7
        20 silly idealTree ├── request@2.88.2
        20 silly idealTree ├── require-directory@2.1.1
        20 silly idealTree ├── require-main-filename@2.0.0
        20 silly idealTree ├── restore-cursor@2.0.0
        20 silly idealTree ├── rimraf@2.7.1
        20 silly idealTree ├── rxjs@6.5.5
        20 silly idealTree ├── safe-buffer@5.1.2
        20 silly idealTree ├── safer-buffer@2.1.2
        20 silly idealTree ├── semver@5.7.1
        20 silly idealTree ├── set-blocking@2.0.0
        20 silly idealTree ├── signal-exit@3.0.3
        20 silly idealTree ├─┬ spawn-rx@3.0.0
        20 silly idealTree │ ├── debug@2.6.9
        20 silly idealTree │ └── ms@2.0.0
        20 silly idealTree ├── sshpk@1.16.1
        20 silly idealTree ├── string_decoder@1.1.1
        20 silly idealTree ├── string-width@1.0.2
        20 silly idealTree ├── strip-ansi@3.0.1
        20 silly idealTree ├── supports-color@5.5.0
        20 silly idealTree ├── tar@4.4.13
        20 silly idealTree ├── tough-cookie@2.5.0
        20 silly idealTree ├── tslib@1.11.1
        20 silly idealTree ├── tunnel-agent@0.6.0
        20 silly idealTree ├── tweetnacl@0.14.5
        20 silly idealTree ├── universalify@0.1.2
        20 silly idealTree ├── uri-js@4.2.2
        20 silly idealTree ├── util-deprecate@1.0.2
        20 silly idealTree ├── uuid@3.4.0
        20 silly idealTree ├── verror@1.10.0
        20 silly idealTree ├── wcwidth@1.0.1
        20 silly idealTree ├── which-module@2.0.0
        20 silly idealTree ├── which@1.3.1
        20 silly idealTree ├── wide-align@1.1.3
        20 silly idealTree ├─┬ wrap-ansi@5.1.0
        20 silly idealTree ├── wrappy@1.0.2
        20 silly idealTree ├── y18n@4.0.0
        20 silly idealTree ├── yallist@3.1.1
        20 silly idealTree ├── yargs-parser@15.0.1
        20 silly idealTree └─┬ yargs@14.2.3
        20 silly idealTree   ├── ansi-regex@4.1.0
        20 silly idealTree   ├── is-fullwidth-code-point@2.0.0
        20 silly idealTree   ├── string-width@3.1.0
        20 silly idealTree   └── strip-ansi@5.2.0
        21 silly install generateActionsToTake
        22 timing stage:generateActionsToTake Completed in 156ms
        23 silly diffTrees action count 0
        24 silly decomposeActions action count 0
        25 silly install executeActions
        26 silly doSerial global-install 0
        27 verbose correctMkdir /home/pi/.npm/_locks correctMkdir not in flight; initializing
        28 verbose lock using /home/pi/.npm/_locks/staging-27e98ab6b31520c2.lock for /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.staging
        29 silly doParallel extract 0
        30 silly doReverseSerial unbuild 0
        31 silly doSerial remove 0
        32 silly doSerial move 0
        33 silly doSerial finalize 0
        34 silly doParallel refresh-package-json 0
        35 silly doParallel preinstall 0
        36 silly doSerial build 0
        37 silly doSerial global-link 0
        38 silly doParallel update-linked 0
        39 silly doSerial install 0
        40 silly doSerial postinstall 0
        41 verbose unlock done using /home/pi/.npm/_locks/staging-27e98ab6b31520c2.lock for /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.staging
        42 timing stage:executeActions Completed in 401ms
        43 timing stage:rollbackFailedOptional Completed in 1ms
        44 silly install runPostinstallTopLevelLifecycles
        45 silly build mmm-dht-sensor@1.1.1
        46 info linkStuff mmm-dht-sensor@1.1.1
        47 silly linkStuff mmm-dht-sensor@1.1.1 has /home/pi/MagicMirror/modules as its parent node_modules
        48 silly install mmm-dht-sensor@1.1.1
        49 info lifecycle mmm-dht-sensor@1.1.1~install: mmm-dht-sensor@1.1.1
        50 silly postinstall mmm-dht-sensor@1.1.1
        51 info lifecycle mmm-dht-sensor@1.1.1~postinstall: mmm-dht-sensor@1.1.1
        52 verbose lifecycle mmm-dht-sensor@1.1.1~postinstall: unsafe-perm in lifecycle true
        53 verbose lifecycle mmm-dht-sensor@1.1.1~postinstall: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
        54 verbose lifecycle mmm-dht-sensor@1.1.1~postinstall: CWD: /home/pi/MagicMirror/modules/MMM-DHT-Sensor
        55 silly lifecycle mmm-dht-sensor@1.1.1~postinstall: Args: [ '-c', 'electron-rebuild -e ../../node_modules/electron' ]
        56 timing audit submit Completed in 648ms
        57 http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/audits/quick 658ms
        58 timing audit body Completed in 20ms
        59 silly lifecycle mmm-dht-sensor@1.1.1~postinstall: Returned: code: 255  signal: null
        60 info lifecycle mmm-dht-sensor@1.1.1~postinstall: Failed to exec postinstall script
        61 verbose stack Error: mmm-dht-sensor@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron`
        61 verbose stack Exit status 255
        61 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
        61 verbose stack     at EventEmitter.emit (events.js:198:13)
        61 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
        61 verbose stack     at ChildProcess.emit (events.js:198:13)
        61 verbose stack     at maybeClose (internal/child_process.js:982:16)
        61 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        62 verbose pkgid mmm-dht-sensor@1.1.1
        63 verbose cwd /home/pi/MagicMirror/modules/MMM-DHT-Sensor
        64 verbose Linux 5.10.11-v7l+
        65 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install"
        66 verbose node v10.24.0
        67 verbose npm  v6.14.10
        68 error code ELIFECYCLE
        69 error errno 255
        70 error mmm-dht-sensor@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron`
        70 error Exit status 255
        71 error Failed at the mmm-dht-sensor@1.1.1 postinstall script.
        71 error This is probably not a problem with npm. There is likely additional logging output above.
        72 verbose exit [ 255, true ]
          sdetweil @BKeyport
          @bkeyport from your module folder, can you do this
          npm ls node-abi
          • BKeyportB Offline
            mmm-dht-sensor@1.1.1 /home/pi/MagicMirror/modules/MMM-DHT-Sensor
            └─┬ electron-rebuild@1.10.1
              └── node-abi@2.16.0
            For what it’s worth, it started working again on it’s own after issuing this command. No need to reinstall it’s dependencies.
            Bizarre.
              sdetweil @BKeyport
              @bkeyport great!
                ChrizZz @sdetweil
                I do have some strange things after the update.
                At first, the new weather module is just “loading” without displaying content. Even after 30+ minutes. Is there something wrong with the config? I saw that there is a minor issue with the data request which will cause it to load for ~10min (or to reduce the update interval).
                			module: "weather",
                			classes: "always",
                				type: "current",
                				locationID: "YYY",
                				appid: "XXX"
                And I have new lines of errors in the log, I don’t understand why these syntax errors appear. I checked my config file and everything looks fine. Regarding git, does this mean it couldn’t connect to github?
                [03.04.2021 23:22.22.900] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                [03.04.2021 23:22.24.037] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                [03.04.2021 23:22.25.987] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
                [03.04.2021 23:22.27.080] [ERROR] Failed to fetch git data for MMM-Parcel: Error: block timeout reached
                [03.04.2021 23:22.35.518] [ERROR] Failed to fetch git data for MMM-Face-Reco-DNN: Error: block timeout reached
                [03.04.2021 23:22.39.290] [ERROR] Failed to fetch git data for MMM-PIR-Sensor: Error: block timeout reached
                [03.04.2021 23:32.42.638] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
                [03.04.2021 23:37.14.466] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                [03.04.2021 23:37.14.577] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                [03.04.2021 23:52.14.126] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                [03.04.2021 23:52.14.377] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
                S C 2 Replies Last reply Reply Quote 0
                  sdetweil @ChrizZz
                  @chrizzz looks like a networking error… did u npm install after git pull? did both work?
                    danjvd @sdetweil
                    @sdetweil Thanks for the help, was about to make a post when I found this thread.
                      ChrizZz @sdetweil
                      @sdetweil yes I did and both worked.
                      I did npm install in all module folders too and did the npm install of MM multiple times just to check if something is wrong
                      • StoffbeuteluweS Offline
                        Stoffbeuteluwe Project Sponsor
                        Hallo, i have installed the updatescript and than I have installed the valid url …the mirror starts normal and when i stop the Mirror I get this.
                        nal SIGINT
                        npm ERR! errno 1
                        npm ERR! magicmirror@2.15.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.15.0 start script.
                        npm ERR!     /Users/patrickhahn/.npm/_logs/2021-04-06T20_05_51_094Z-debug.log
                        patrickhahn@Mac-mini MagicMirror %
                        hope somebody can help me …thanks
                          sdetweil @Stoffbeuteluwe
                          @stoffbeuteluwe that’s ok when u stop
                          • unfriendlydeviceU Offline
                            unfriendlydevice @sdetweil
                            @sdetweil what is the full command to run this? I’ve done some searching on the forum but haven’t found anything.
                              sdetweil @unfriendlydevice
                              @unfriendlydevice run ‘this’???
                              unfriendlydeviceU 1 Reply Last reply Reply Quote 0
                                @sdetweil to run the electron-rebuild as you advised (sorry I think I replied to the main thread instead of your earlier reply)
                                  @unfriendlydevice
                                  npm install electron-rebuild
                                  now change to your module folder where u need the electron rebuild
                                  then
                                  ~/MagicMirror/node_modules/.bin/electron-rebuild
                                  (note the dot . in front of bin)
                                  unfriendlydeviceU 1 Reply Last reply Reply Quote 1
                                    @sdetweil That’s great thanks
                                      ChrizZz @ChrizZz
                                      @chrizzz said in MagicMirror² v2.15.0 is available don't work.:
                                      			module: "weather",
                                      			classes: "always",
                                      				type: "current",
                                      				locationID: "YYY",
                                      				appid: "XXX"
                                      I checked this again with switching back to the old module and the old module works. The forcasting takes 10min (as expected) but the module itself works. I thought this might be something with the connection to the API. Any ideas?
                                      • 2 / 3
