    MagicMirror² v2.15.0 is available don't work.
    44 Posts 9 Posters 16.6k Views 10 Watching
    • BKeyportB Offline
      mmm-dht-sensor@1.1.1 /home/pi/MagicMirror/modules/MMM-DHT-Sensor
      └─┬ electron-rebuild@1.10.1
        └── node-abi@2.16.0
      For what it’s worth, it started working again on it’s own after issuing this command. No need to reinstall it’s dependencies.
      Bizarre.
        sdetweil @BKeyport
        @bkeyport great!
        • C Offline
          ChrizZz @sdetweil
          I do have some strange things after the update.
          At first, the new weather module is just “loading” without displaying content. Even after 30+ minutes. Is there something wrong with the config? I saw that there is a minor issue with the data request which will cause it to load for ~10min (or to reduce the update interval).
          			module: "weather",
          			classes: "always",
          				type: "current",
          				locationID: "YYY",
          				appid: "XXX"
          And I have new lines of errors in the log, I don’t understand why these syntax errors appear. I checked my config file and everything looks fine. Regarding git, does this mean it couldn’t connect to github?
          [03.04.2021 23:22.22.900] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
          [03.04.2021 23:22.24.037] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
          [03.04.2021 23:22.25.987] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
          [03.04.2021 23:22.27.080] [ERROR] Failed to fetch git data for MMM-Parcel: Error: block timeout reached
          [03.04.2021 23:22.35.518] [ERROR] Failed to fetch git data for MMM-Face-Reco-DNN: Error: block timeout reached
          [03.04.2021 23:22.39.290] [ERROR] Failed to fetch git data for MMM-PIR-Sensor: Error: block timeout reached
          [03.04.2021 23:32.42.638] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
          [03.04.2021 23:37.14.466] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
          [03.04.2021 23:37.14.577] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
          [03.04.2021 23:52.14.126] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
          [03.04.2021 23:52.14.377] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
          S C 2 Replies Last reply Reply Quote 0
            sdetweil @ChrizZz
            @chrizzz looks like a networking error… did u npm install after git pull? did both work?
              danjvd @sdetweil
              @sdetweil Thanks for the help, was about to make a post when I found this thread.
              • C Offline
                ChrizZz @sdetweil
                @sdetweil yes I did and both worked.
                I did npm install in all module folders too and did the npm install of MM multiple times just to check if something is wrong
                • StoffbeuteluweS Offline
                  Stoffbeuteluwe Project Sponsor
                  Hallo, i have installed the updatescript and than I have installed the valid url …the mirror starts normal and when i stop the Mirror I get this.
                  nal SIGINT
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! magicmirror@2.15.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.15.0 start script.
                  npm ERR!     /Users/patrickhahn/.npm/_logs/2021-04-06T20_05_51_094Z-debug.log
                  patrickhahn@Mac-mini MagicMirror %
                  hope somebody can help me …thanks
                    sdetweil @Stoffbeuteluwe
                    @stoffbeuteluwe that’s ok when u stop
                    • unfriendlydeviceU Offline
                      unfriendlydevice @sdetweil
                      @sdetweil what is the full command to run this? I’ve done some searching on the forum but haven’t found anything.
                        sdetweil @unfriendlydevice
                        @unfriendlydevice run ‘this’???
                        unfriendlydeviceU 1 Reply Last reply Reply Quote 0
                        • 4 / 5
