    MMM-CalendarExt2: Black Screen
    30 Posts 3 Posters 11.1k Views 3 Watching
    • J
      jack819
      I will start this by saying I am a newbie so bear with me. I have installed multiple other modules with little to no issues. However, when I try to install this, I cannot get it to work. I tried and when Magic Mirror started, it would not show up. I tried sample configs, the most basic config, etc. I started over from the beginning and installed Magic Mirror and all of the other modules again. When I start Magic Mirror, I just get a black screen. I also tried changing the webcal:// to http:// and still get the black screen. Any help would be greatly appreciated.
      L 1 Reply Last reply
      • L
        linuxha @jack819
        @jack819 from the MagicMirror² v2.15.0 is available don’t work. thread
        … valid-url was removed from the mm package. do
        npm install valid-url
        in the mm folder
        • J
          jack819
          I can get Magic Mirror to start but the MMM-CalendarExt2 does not. Here is my config file (i know this is very basic but I tried more advanced ones and they still did not work):
          			module: 'MMM-CalendarExt2',
          				calendars : [
          						url: "my url that is working with the standard calendar module",
          				views: [
          						mode: "daily",
          				scenes: [
          S L 2 Replies Last reply
            sdetweil @jack819
            @jack819 can u look in the console where u start <MM (npm start ) and see what messages are there, and also, open the developers windows, ctrl-shift-i on the mm keyboard, and select the console tab, put ext in the filter field
            look at those messages
            J 2 Replies Last reply
            • L
              linuxha @jack819
              @jack819 , I may have given you bad advice. It shouldn’t cause any issues. Sorry about that.
              So starting over, Did you do all of this (and have no errors)?
              cd ~/MagicMirror/modules
              git clone --depth=1 https://github.com/eouia/MMM-CalendarExt2
              cd MMM-CalendarExt2
              npm install
              J 1 Reply Last reply
              • J
                jack819 @sdetweil
                @sdetweil Like I said, this is all new to me. How do I look in the console where I start <MM? I have it set up to auto start. I was able to look in the developers window and nothing is shown when I put ‘ext’ in the filter field.
                • J
                  jack819 @linuxha
                  @linuxha This is exactly what I did and I had no errors.
                  • J
                    jack819 @sdetweil
                    @sdetweil I am a moron. I knew what to do. Here is the message:
                    > magicmirror@2.15.0 start /home/pi/MagicMirror
                    > ./run-start.sh $1
                    [06.04.2021 07:12.49.510] [LOG]   Starting MagicMirror: v2.15.0
                    [06.04.2021 07:12.49.519] [LOG]   Loading config ...
                    [06.04.2021 07:12.49.538] [LOG]   Loading module helpers ...
                    [06.04.2021 07:12.49.545] [LOG]   No helper found for module: alert.
                    [06.04.2021 07:12.50.029] [LOG]   Initializing new module helper ...
                    [06.04.2021 07:12.50.031] [LOG]   Module helper loaded: updatenotification
                    [06.04.2021 07:12.50.035] [LOG]   No helper found for module: clock.
                    [06.04.2021 07:12.51.159] [LOG]   Initializing new module helper ...
                    [06.04.2021 07:12.51.163] [LOG]   Module helper loaded: MMM-Jast
                    [06.04.2021 07:12.52.389] [LOG]   Initializing new module helper ...
                    [06.04.2021 07:12.52.390] [LOG]   Module helper loaded: calendar
                    [06.04.2021 07:12.52.750] [LOG]   Initializing new module helper ...
                    [06.04.2021 07:12.52.752] [LOG]   Module helper loaded: MMM-CalendarExt2
                    [06.04.2021 07:12.52.757] [LOG]   Initializing new module helper ...
                    [06.04.2021 07:12.52.759] [LOG]   Module helper loaded: currentweather
                    [06.04.2021 07:12.52.763] [LOG]   Initializing new module helper ...
                    [06.04.2021 07:12.52.765] [LOG]   Module helper loaded: weatherforecast
                    [06.04.2021 07:12.52.766] [LOG]   All module helpers loaded.
                    [06.04.2021 07:12.52.983] [LOG]   Starting server on port 8080 ...
                    [06.04.2021 07:12.53.011] [LOG]   Server started ...
                    [06.04.2021 07:12.53.014] [LOG]   Connecting socket for: updatenotification
                    [06.04.2021 07:12.53.018] [LOG]   Connecting socket for: MMM-Jast
                    [06.04.2021 07:12.53.019] [LOG]   MMM-Jast helper method started...
                    [06.04.2021 07:12.53.020] [LOG]   Connecting socket for: calendar
                    [06.04.2021 07:12.53.022] [LOG]   Starting node helper for: calendar
                    [06.04.2021 07:12.53.023] [LOG]   Connecting socket for: MMM-CalendarExt2
                    [06.04.2021 07:12.53.024] [LOG]   Connecting socket for: currentweather
                    [06.04.2021 07:12.53.026] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                    [06.04.2021 07:12.53.028] [LOG]   Connecting socket for: weatherforecast
                    [06.04.2021 07:12.53.030] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                    [06.04.2021 07:12.53.031] [LOG]   Sockets connected & modules started ...
                    [06.04.2021 07:12.53.536] [ERROR] Whoops! There was an uncaught exception...
                    [06.04.2021 07:12.53.549] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                        at Server.setupListenHandle [as _listen2] (net.js:1313:16)
                        at listenInCluster (net.js:1361:12)
                        at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7)
                        at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8) {
                      code: 'EADDRINUSE',
                      errno: 'EADDRINUSE',
                      syscall: 'listen',
                      address: '127.0.0.1',
                      port: 8080
                    [06.04.2021 07:12.53.554] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [06.04.2021 07:12.53.556] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [06.04.2021 07:12.53.602] [LOG]   Launching application.
                      sdetweil @jack819
                      @jack819 looks like u already have a copy of mm running
                      if using pm2, then do
                      pm2 status
                      and
                      pm2 restart 0
                      • J
                        jack819 @sdetweil
                        @sdetweil I did that command and still do not have the Calendar showing up.
                          sdetweil @jack819
                          @jack819 and what do the messages say?
                          • J
                            jack819
                            Here you go:
                              sdetweil @jack819
                              @jack819 you can’t have two instance running!
                              do
                              pm2 stop all
                              pm2 info 0
                              pm2 info 1
                              look at the path of each and decide which one is right
                              then
                              pm2 start ??
                              ?? is the name or number
                              if all is good then get rid of the other one
                              pm2 delete ???
                              pm2 save
                              and by messages, i meant the output of
                              pm2 logs --lines=50
                              pm2 --help will show u all the things I can do
                              • J
                                jack819 @sdetweil
                                @sdetweil Ok. I did that and looked in the console. Here is the message:
                                > ./run-start.sh $1
                                [08.04.2021 12:24.35.192] [LOG]   Starting MagicMirror: v2.15.0
                                [08.04.2021 12:24.35.203] [LOG]   Loading config ...
                                [08.04.2021 12:24.35.216] [LOG]   Loading module helpers ...
                                [08.04.2021 12:24.35.220] [LOG]   No helper found for module: alert.
                                [08.04.2021 12:24.35.510] [LOG]   Initializing new module helper ...
                                [08.04.2021 12:24.35.512] [LOG]   Module helper loaded: updatenotification
                                [08.04.2021 12:24.35.514] [LOG]   No helper found for module: clock.
                                [08.04.2021 12:24.36.214] [LOG]   Initializing new module helper ...
                                [08.04.2021 12:24.36.215] [LOG]   Module helper loaded: MMM-Jast
                                [08.04.2021 12:24.37.017] [LOG]   Initializing new module helper ...
                                [08.04.2021 12:24.37.018] [LOG]   Module helper loaded: calendar
                                [08.04.2021 12:24.37.270] [LOG]   Initializing new module helper ...
                                [08.04.2021 12:24.37.272] [LOG]   Module helper loaded: MMM-CalendarExt2
                                [08.04.2021 12:24.37.277] [LOG]   Initializing new module helper ...
                                [08.04.2021 12:24.37.278] [LOG]   Module helper loaded: currentweather
                                [08.04.2021 12:24.37.282] [LOG]   Initializing new module helper ...
                                [08.04.2021 12:24.37.283] [LOG]   Module helper loaded: weatherforecast
                                [08.04.2021 12:24.37.284] [LOG]   All module helpers loaded.
                                [08.04.2021 12:24.37.446] [LOG]   Starting server on port 8080 ...
                                [08.04.2021 12:24.37.473] [LOG]   Server started ...
                                [08.04.2021 12:24.37.476] [LOG]   Connecting socket for: updatenotification
                                [08.04.2021 12:24.37.479] [LOG]   Connecting socket for: MMM-Jast
                                [08.04.2021 12:24.37.481] [LOG]   MMM-Jast helper method started...
                                [08.04.2021 12:24.37.482] [LOG]   Connecting socket for: calendar
                                [08.04.2021 12:24.37.483] [LOG]   Starting node helper for: calendar
                                [08.04.2021 12:24.37.484] [LOG]   Connecting socket for: MMM-CalendarExt2
                                [08.04.2021 12:24.37.485] [LOG]   Connecting socket for: currentweather
                                [08.04.2021 12:24.37.486] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                [08.04.2021 12:24.37.488] [LOG]   Connecting socket for: weatherforecast
                                [08.04.2021 12:24.37.490] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                [08.04.2021 12:24.37.491] [LOG]   Sockets connected & modules started ...
                                [08.04.2021 12:24.37.842] [ERROR] Whoops! There was an uncaught exception...
                                [08.04.2021 12:24.37.853] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                  code: 'EADDRINUSE',
                                  syscall: 'listen',
                                  port: 8080
                                [08.04.2021 12:24.37.855] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [08.04.2021 12:24.37.856] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                [08.04.2021 12:24.37.896] [LOG]   Launching application.
                                  sdetweil @jack819
                                  @jack819 looks like something is still running on port 8080
                                  SO, stop MM (ctrl-c)
                                  and then do
                                  ps -ef | grep node
                                  • J
                                    jack819 @sdetweil
                                    @sdetweil Did that and got this message:
                                    pi@raspberrypi:~ $ ps -ef | grep node
                                    pi        1391  1358  1 12:41 pts/0    00:00:00 grep --color=auto node
                                    pi@raspberrypi:~ $
                                    The message in the console is still the same:
                                    > ./run-start.sh $1
                                    [08.04.2021 12:44.57.081] [LOG]   Starting MagicMirror: v2.15.0
                                    [08.04.2021 12:44.57.091] [LOG]   Loading config ...
                                    [08.04.2021 12:44.57.102] [LOG]   Loading module helpers ...
                                    [08.04.2021 12:44.57.105] [LOG]   No helper found for module: alert.
                                    [08.04.2021 12:44.57.398] [LOG]   Initializing new module helper ...
                                    [08.04.2021 12:44.57.400] [LOG]   Module helper loaded: updatenotification
                                    [08.04.2021 12:44.57.401] [LOG]   No helper found for module: clock.
                                    [08.04.2021 12:44.58.115] [LOG]   Initializing new module helper ...
                                    [08.04.2021 12:44.58.116] [LOG]   Module helper loaded: MMM-Jast
                                    [08.04.2021 12:44.58.951] [LOG]   Initializing new module helper ...
                                    [08.04.2021 12:44.58.953] [LOG]   Module helper loaded: calendar
                                    [08.04.2021 12:44.59.195] [LOG]   Initializing new module helper ...
                                    [08.04.2021 12:44.59.196] [LOG]   Module helper loaded: MMM-CalendarExt2
                                    [08.04.2021 12:44.59.199] [LOG]   Initializing new module helper ...
                                    [08.04.2021 12:44.59.199] [LOG]   Module helper loaded: currentweather
                                    [08.04.2021 12:44.59.201] [LOG]   Initializing new module helper ...
                                    [08.04.2021 12:44.59.203] [LOG]   Module helper loaded: weatherforecast
                                    [08.04.2021 12:44.59.204] [LOG]   All module helpers loaded.
                                    [08.04.2021 12:44.59.353] [LOG]   Starting server on port 8080 ...
                                    [08.04.2021 12:44.59.378] [LOG]   Server started ...
                                    [08.04.2021 12:44.59.380] [LOG]   Connecting socket for: updatenotification
                                    [08.04.2021 12:44.59.382] [LOG]   Connecting socket for: MMM-Jast
                                    [08.04.2021 12:44.59.383] [LOG]   MMM-Jast helper method started...
                                    [08.04.2021 12:44.59.384] [LOG]   Connecting socket for: calendar
                                    [08.04.2021 12:44.59.386] [LOG]   Starting node helper for: calendar
                                    [08.04.2021 12:44.59.387] [LOG]   Connecting socket for: MMM-CalendarExt2
                                    [08.04.2021 12:44.59.389] [LOG]   Connecting socket for: currentweather
                                    [08.04.2021 12:44.59.390] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                    [08.04.2021 12:44.59.391] [LOG]   Connecting socket for: weatherforecast
                                    [08.04.2021 12:44.59.393] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                    [08.04.2021 12:44.59.394] [LOG]   Sockets connected & modules started ...
                                    [08.04.2021 12:44.59.751] [ERROR] Whoops! There was an uncaught exception...
                                    [08.04.2021 12:44.59.763] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                      code: 'EADDRINUSE',
                                      syscall: 'listen',
                                      port: 8080
                                    [08.04.2021 12:44.59.766] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [08.04.2021 12:44.59.767] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [08.04.2021 12:44.59.809] [LOG]   Launching application.
                                    [08.04.2021 12:45.21.540] [LOG]   Shutting down server...
                                    [08.04.2021 12:45.21.544] [LOG]   Stopping module helper: updatenotification
                                    [08.04.2021 12:45.21.546] [LOG]   Stopping module helper: MMM-Jast
                                    [08.04.2021 12:45.21.548] [LOG]   Stopping module helper: calendar
                                    [08.04.2021 12:45.21.550] [LOG]   Stopping module helper: currentweather
                                    [08.04.2021 12:45.21.551] [LOG]   Stopping module helper: weatherforecast
                                      sdetweil @jack819
                                      @jack819 ok, cant tell
                                      ps -ef
                                      will have to look thru the process list
                                      do u have another web server on this machine?
                                      pihole
                                      • J
                                        jack819 @sdetweil
                                        @sdetweil Here is the list:
                                        UID        PID  PPID  C STIME TTY          TIME CMD
                                        root         1     0  0 12:39 ?        00:00:04 /sbin/init splash
                                        root         2     0  0 12:39 ?        00:00:00 [kthreadd]
                                        root         3     2  0 12:39 ?        00:00:00 [rcu_gp]
                                        root         4     2  0 12:39 ?        00:00:00 [rcu_par_gp]
                                        root         8     2  0 12:39 ?        00:00:00 [mm_percpu_wq]
                                        root         9     2  0 12:39 ?        00:00:00 [rcu_tasks_rude_]
                                        root        10     2  0 12:39 ?        00:00:00 [rcu_tasks_trace]
                                        root        11     2  0 12:39 ?        00:00:00 [ksoftirqd/0]
                                        root        12     2  0 12:39 ?        00:00:04 [rcu_sched]
                                        root        13     2  0 12:39 ?        00:00:00 [migration/0]
                                        root        14     2  0 12:39 ?        00:00:00 [cpuhp/0]
                                        root        15     2  0 12:39 ?        00:00:00 [cpuhp/1]
                                        root        16     2  0 12:39 ?        00:00:00 [migration/1]
                                        root        17     2  0 12:39 ?        00:00:01 [ksoftirqd/1]
                                        root        20     2  0 12:39 ?        00:00:00 [cpuhp/2]
                                        root        21     2  0 12:39 ?        00:00:00 [migration/2]
                                        root        22     2  0 12:39 ?        00:00:00 [ksoftirqd/2]
                                        root        25     2  0 12:39 ?        00:00:00 [cpuhp/3]
                                        root        26     2  0 12:39 ?        00:00:00 [migration/3]
                                        root        27     2  0 12:39 ?        00:00:00 [ksoftirqd/3]
                                        root        30     2  0 12:39 ?        00:00:00 [kdevtmpfs]
                                        root        31     2  0 12:39 ?        00:00:00 [netns]
                                        root        33     2  0 12:39 ?        00:00:03 [kworker/1:1-events]
                                        root        35     2  0 12:39 ?        00:00:00 [kauditd]
                                        root        36     2  0 12:39 ?        00:00:00 [khungtaskd]
                                        root        37     2  0 12:39 ?        00:00:00 [oom_reaper]
                                        root        38     2  0 12:39 ?        00:00:00 [writeback]
                                        root        39     2  0 12:39 ?        00:00:00 [kcompactd0]
                                        root        57     2  0 12:39 ?        00:00:00 [kblockd]
                                        root        58     2  0 12:39 ?        00:00:00 [blkcg_punt_bio]
                                        root        59     2  0 12:39 ?        00:00:00 [watchdogd]
                                        root        60     2  0 12:39 ?        00:00:01 [kworker/3:1-events]
                                        root        62     2  0 12:39 ?        00:00:00 [rpciod]
                                        root        63     2  0 12:39 ?        00:00:00 [kworker/u9:0-hci0]
                                        root        64     2  0 12:39 ?        00:00:00 [xprtiod]
                                        root        65     2  0 12:39 ?        00:00:00 [kswapd0]
                                        root        66     2  0 12:39 ?        00:00:00 [nfsiod]
                                        root        67     2  0 12:39 ?        00:00:00 [kthrotld]
                                        root        68     2  0 12:39 ?        00:00:00 [iscsi_eh]
                                        root        69     2  0 12:39 ?        00:00:00 [iscsi_destroy]
                                        root        72     2  0 12:39 ?        00:00:00 [DWC Notificatio]
                                        root        73     2  0 12:39 ?        00:00:00 [uas]
                                        root        75     2  0 12:39 ?        00:00:00 [vchiq-slot/0]
                                        root        76     2  0 12:39 ?        00:00:00 [vchiq-recy/0]
                                        root        77     2  0 12:39 ?        00:00:00 [vchiq-sync/0]
                                        root        78     2  0 12:39 ?        00:00:00 [zswap-shrink]
                                        root        79     2  0 12:39 ?        00:00:00 [sdhci]
                                        root        80     2  0 12:39 ?        00:00:00 [irq/47-mmc0]
                                        root        82     2  0 12:39 ?        00:00:00 [mmc_complete]
                                        root        83     2  0 12:39 ?        00:00:00 [kworker/1:1H-kblockd]
                                        root        84     2  0 12:39 ?        00:00:00 [jbd2/mmcblk0p2-]
                                        root        85     2  0 12:39 ?        00:00:00 [ext4-rsv-conver]
                                        root        87     2  0 12:39 ?        00:00:00 [ipv6_addrconf]
                                        root       103     2  0 12:39 ?        00:00:00 [kworker/3:2H-kblockd]
                                        root       106     2  0 12:39 ?        00:00:01 [kworker/0:2H+kblockd]
                                        root       112     1  0 12:39 ?        00:00:00 /lib/systemd/systemd-journald
                                        root       113     2  0 12:39 ?        00:00:00 [kworker/2:2H-kblockd]
                                        root       149     1  0 12:39 ?        00:00:00 /lib/systemd/systemd-udevd
                                        root       180     2  0 12:39 ?        00:00:00 [vchiq-keep/0]
                                        root       181     2  0 12:39 ?        00:00:00 [SMIO]
                                        root       188     2  0 12:39 ?        00:00:00 [mmal-vchiq]
                                        root       190     2  0 12:39 ?        00:00:00 [mmal-vchiq]
                                        root       191     2  0 12:39 ?        00:00:00 [mmal-vchiq]
                                        root       193     2  0 12:39 ?        00:00:00 [mmal-vchiq]
                                        root       210     2  1 12:39 ?        00:00:40 [v3d_bin]
                                        root       213     2  1 12:39 ?        00:00:36 [v3d_render]
                                        root       215     2  0 12:39 ?        00:00:05 [v3d_tfu]
                                        root       218     2  0 12:39 ?        00:00:00 [v3d_csd]
                                        root       219     2  0 12:39 ?        00:00:00 [v3d_cache_clean]
                                        root       221     2  0 12:39 ?        00:00:00 [card1-crtc0]
                                        root       229     2  0 12:39 ?        00:00:00 [cfg80211]
                                        root       235     2  0 12:39 ?        00:00:00 [brcmf_wq/mmc1:0]
                                        root       238     2  0 12:39 ?        00:00:00 [brcmf_wdog/mmc1]
                                        systemd+   322     1  0 12:39 ?        00:00:00 /lib/systemd/systemd-timesyncd
                                        root       359     1  0 12:39 ?        00:00:00 /usr/sbin/rsyslogd -n -iNONE
                                        root       362     1  0 12:39 ?        00:00:00 /usr/lib/udisks2/udisksd
                                        nobody     363     1  0 12:39 ?        00:00:00 /usr/sbin/thd --triggers /etc/tr
                                        root       366     1  0 12:39 ?        00:00:00 /usr/sbin/cupsd -l
                                        root       368     1  0 12:39 ?        00:00:00 /lib/systemd/systemd-logind
                                        avahi      373     1  0 12:39 ?        00:00:00 avahi-daemon: running [raspberry
                                        root       376     1  0 12:39 ?        00:00:00 /usr/sbin/cron -f
                                        root       383     1  0 12:39 ?        00:00:00 /usr/sbin/alsactl -E HOME=/run/a
                                        avahi      394   373  0 12:39 ?        00:00:00 avahi-daemon: chroot helper
                                        message+   395     1  0 12:39 ?        00:00:00 /usr/bin/dbus-daemon --system --
                                        root       401     1  0 12:39 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /r
                                        root       409     1  0 12:39 ?        00:00:00 /usr/sbin/rngd -r /dev/hwrng
                                        root       430     1  0 12:39 ?        00:00:00 /sbin/dhcpcd -q -b
                                        root       460     1  0 12:39 ?        00:00:00 /usr/sbin/cups-browsed
                                        root       484     1  0 12:39 ?        00:00:00 /usr/sbin/lightdm
                                        root       493     1  0 12:39 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
                                        root       516     1  0 12:39 ?        00:00:00 wpa_supplicant -B -c/etc/wpa_sup
                                        root       527   484  5 12:39 tty7     00:01:56 /usr/lib/xorg/Xorg -s 0 -dpms :0
                                        root       528     1  0 12:39 tty1     00:00:00 /bin/login -f
                                        root       547     1  0 12:39 ?        00:00:00 nginx: master process /usr/sbin/
                                        www-data   548   547  0 12:39 ?        00:00:00 nginx: worker process
                                        www-data   549   547  0 12:39 ?        00:00:00 nginx: worker process
                                        www-data   550   547  0 12:39 ?        00:00:00 nginx: worker process
                                        www-data   551   547  0 12:39 ?        00:00:00 nginx: worker process
                                        pi         554     1  0 12:39 ?        00:00:02 PM2 v4.5.6: God Daemon (/home/pi
                                        root       576   484  0 12:39 ?        00:00:00 lightdm --session-child 14 17
                                        pi         593     1  0 12:39 ?        00:00:00 /lib/systemd/systemd --user
                                        pi         594   593  0 12:39 ?        00:00:00 (sd-pam)
                                        pi         607   576  0 12:39 ?        00:00:00 /usr/bin/lxsession -s LXDE-pi -e
                                        pi         616   593  0 12:39 ?        00:00:00 /usr/bin/dbus-daemon --session -
                                        pi         640   607  0 12:39 ?        00:00:00 /usr/bin/ssh-agent x-session-man
                                        root       654     1  0 12:39 ?        00:00:00 /usr/bin/hciattach /dev/serial1
                                        root       658     2  0 12:39 ?        00:00:00 [kworker/u9:2-hci0]
                                        root       660     1  0 12:39 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
                                        pi         663   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfsd
                                        pi         686   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfsd-fuse /run/us
                                        pi         689   528  0 12:39 tty1     00:00:00 -bash
                                        pi         692   607  0 12:39 ?        00:00:00 openbox --config-file /home/pi/.
                                        pi         700   607  0 12:39 ?        00:00:00 lxpolkit
                                        pi         706   607  0 12:39 ?        00:00:03 lxpanel --profile LXDE-pi
                                        pi         729     1  0 12:39 ?        00:00:00 xcompmgr -aR
                                        pi         745   593  0 12:39 ?        00:00:00 /usr/bin/pulseaudio --daemonize=
                                        pi         747     1  0 12:39 ?        00:00:01 /usr/bin/python3 /usr/share/syst
                                        pi         748     1  0 12:39 ?        00:00:00 /usr/bin/ssh-agent -s
                                        rtkit      749     1  0 12:39 ?        00:00:00 /usr/lib/rtkit/rtkit-daemon
                                        root       792     2  0 12:39 ?        00:00:00 [krfcommd]
                                        pi         798     1  0 12:39 ?        00:00:00 /usr/lib/menu-cache/menu-cached
                                        pi         802   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-udisks2-volum
                                        pi         806   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-goa-volume-mo
                                        pi         810   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volum
                                        pi         814   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-afc-volume-mo
                                        pi         819   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-mo
                                        pi         830   663  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfsd-trash --spaw
                                        pi        1050   706  1 12:40 ?        00:00:37 /usr/lib/chromium-browser/chromi
                                        pi        1072  1050  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                                        pi        1073  1050  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                                        pi        1075  1073  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                                        pi        1096  1072  2 12:40 ?        00:00:48 /usr/lib/chromium-browser/chromi
                                        pi        1102  1050  0 12:40 ?        00:00:03 /usr/lib/chromium-browser/chromi
                                        pi        1113  1075  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                                        pi        1125  1096  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                                        pi        1130  1075  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                                        pi        1140  1075  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                                        pi        1205  1075  0 12:40 ?        00:00:04 /usr/lib/chromium-browser/chromi
                                        pi        1340  1075  3 12:40 ?        00:01:12 /usr/lib/chromium-browser/chromi
                                        root      1697     2  0 12:51 ?        00:00:02 [kworker/0:3-events]
                                        root      1706     2  0 12:51 ?        00:00:00 [kworker/1:2H]
                                        root      1708     2  0 12:51 ?        00:00:00 [kworker/2:1H]
                                        root      1709     2  0 12:51 ?        00:00:00 [kworker/3:0H]
                                        root      1765     2  0 12:57 ?        00:00:00 [kworker/u8:1-events_unbound]
                                        root      1772     2  0 12:58 ?        00:00:00 [kworker/2:1-mm_percpu_wq]
                                        root      1781     2  0 13:00 ?        00:00:00 [kworker/0:0H]
                                        root      1793     2  0 13:02 ?        00:00:00 [kworker/0:0+events_freezable]
                                        root      1796     2  0 13:03 ?        00:00:00 [kworker/u8:0-ext4-rsv-conversio
                                        root      1830     2  0 13:04 ?        00:00:00 [kworker/0:2-mm_percpu_wq]
                                        root      1834     2  0 13:05 ?        00:00:00 [kworker/1:0-events]
                                        root      1838     2  0 13:06 ?        00:00:00 [kworker/2:0-events]
                                        root      1842     2  0 13:07 ?        00:00:00 [kworker/3:0-events]
                                        root      1849     2  0 13:09 ?        00:00:00 [kworker/0:1-events]
                                        root      1859     2  0 13:11 ?        00:00:00 [kworker/u8:2-events_unbound]
                                        pi        1864   593  0 13:11 ?        00:00:00 /usr/lib/gvfs/gvfsd-metadata
                                        root      1870     2  0 13:11 ?        00:00:00 [kworker/1:2-mm_percpu_wq]
                                        root      1871     2  0 13:11 ?        00:00:00 [kworker/2:2-events]
                                        root      1900     2  0 13:12 ?        00:00:00 [kworker/1:0H]
                                        root      1974     2  0 13:13 ?        00:00:00 [kworker/3:2-events]
                                        root      1975     2  0 13:13 ?        00:00:00 [kworker/0:1H]
                                        root      1982     2  0 13:13 ?        00:00:00 [kworker/3:1H]
                                        pi        2008   706  2 13:13 ?        00:00:00 lxterminal
                                        pi        2014  2008  0 13:13 pts/0    00:00:00 bash
                                        root      2043     2  0 13:13 ?        00:00:00 [kworker/2:3]
                                        pi        2044  2014  0 13:14 pts/0    00:00:00 ps -ef
                                        pi@raspberrypi:~ $
                                        I do not have a web server running on this machine.
                                          sdetweil @jack819
                                          @jack819 said in MMM-CalendarExt2: Black Screen:
                                          root 547 1 0 12:39 ? 0:00:00 nginx: master process /usr/sbin/
                                          think that is incorrect
                                          • J
                                            jack819
                                            @sdetweil I can barely figure out the simplest tasks on this so I don’t know how that happened. How do I stop that or remove it? The other option (which I would prefer not to do) is I can wipe this all (operating system, etc) and re-install everything.
