    MMM-CalendarExt2: Black Screen
    30 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @jack819
      @jack819 no idea… it might be because of some other app, like pihole,
        jack819 @sdetweil
        @sdetweil I completely deleted everything off the SD card and reflashed it with the new OS. Then I installed MM again but am still showing the same message and the Calendar is acting the same. Any idea?
          sdetweil @jack819
          @jack819 that makes no sense. how did u install MagicMirror?
          git clone or the automated script?
          neither of those use nginx
            jack819 @sdetweil
            @sdetweil I used this command in terminal (which may be the problem):
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
            It was off a MM website that had a tutorial. I think I will reflash and install another way then see what happens.
              sdetweil @jack819
              @jack819 that’s my script. and what I recommend. it does everything
              it will install pm2 for you
              and u used the pi is, full version to flash the sd card?
              what do you do after the script finishes?
                jack819 @sdetweil
                @sdetweil Correct. Used the Pi OS full version. Run the script then once it is done setup for autostart and turn off screensaver. After that I just installed modules.
                  sdetweil @jack819
                  @jack819 the script does pm2 and screensaver already
                  can u show me ~/install.log
                    jack819 @sdetweil
                    @sdetweil Correct. I do that in the script.
                    When I type that command into terminal, it says permission denied.
                      sdetweil @jack819
                      @jack819 show me, means dump , edit, … use some command
                      to type out the file, use the cat command (cat = type in windows)
                      to edit the file use nano
                      nano ~/install.log
                        jack819 @sdetweil
                        @sdetweil Here you go:
                        install starting  - Fri Apr  9 08:58:51 EDT 2021
                        installing on armv7l processor system
                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) $
                        ^[[96mUpdating packages ...^[[90m
                        Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspb$
                        apt-get update  completed ok
                        apt-get upgrade  started
                        apt upgrade result =rc=0 Reading package lists...
                        Building dependency tree...
                        Reading state information...
                        Calculating upgrade...
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        ^[[96mInstalling helper tools ...^[[90m
                        build-essential is already the newest version (12.6).
                        curl is already the newest version (7.64.0-4+deb10u2).
                        git is already the newest version (1:2.20.1-2+deb10u3).
                        unzip is already the newest version (6.0-23+deb10u2).
                        wget is already the newest version (1.20.1-1.1).
                        wget set to manually installed.
                        ^[[96mCheck current Node installation ...^[[0m
                        ^[[93mNode.js is not installed.^[[0m
                        ^[[96mInstalling Node.js ...^[[90m
                        Node release info = ## Installing the NodeSource Node.js 10.x repo... ## Popula$
                        v10.24.1
                        ^[[92mNode.js installation Done! version=v10.24.1^[[0m
                        ^[[96mCheck current NPM installation ...^[[0m
                        ^[[0mNPM currently installed. Checking version number.
                        ^[[0mMinimum npm version: ^[[1mV6.0.0^[[0m
                        ^[[0mInstalled npm version: ^[[1mV6.14.12^[[0m
                        ^[[92mNo npm upgrade necessary.^[[0m
                        ^[[96mCloning MagicMirror ...^[[90m
                        ^[[92mCloning MagicMirror Done!^[[90m
                        package.json update for armv7l completed ok
                        ^[[96mInstalling dependencies ...^[[90m
                        ^[[92mDependencies installation Done!^[[90m
                        fixing sandbox permissions
                        setting up initial config.js
                        ^[[96mCheck plymouth installation ...^[[0m
                        ^[[90mSplashscreen: Checking themes directory.^[[0m
                        ^[[90mSplashscreen: Create theme directory if not exists.^[[0m
                        ^[[92mSplashscreen: Changed theme to MagicMirror successfully.^[[0m
                        install and setup pm2
                        pm2 not installed, installing
                        pm2 install result /usr/bin/pm2 -> /usr/lib/node_modules/pm2/bin/pm2 /usr/bin/p$
                        get the pm2 platform specific startup command
                        startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/b$
                        __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
                         _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
                          _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
                           _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                            _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                             _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                              _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                               _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                                _\///______________\///______________\///__\///////////////__
                                                  Runtime Edition
                                PM2 is a Production Process Manager for Node.js applications
                                             with a built-in Load Balancer.
                                        Start and Daemonize any application:
                                        $ pm2 start app.js
                                        Load Balance 4 instances of api.js:
                                        $ pm2 start api.js -i 4
                                        Monitor in production:
                                        $ pm2 monitor
                                        Make pm2 auto-boot at server restart:
                                        $ pm2 startup
                                        To go further checkout:
                                        http://pm2.io/
                        [PM2] Init System found: systemd
                        Platform systemd
                        Template
                        [Unit]
                        Description=PM2 process manager
                        Documentation=https://pm2.keymetrics.io/
                        After=network.target
                        [Service]
                        Type=forking
                        User=pi
                        LimitNOFILE=infinity
                        LimitNPROC=infinity
                        LimitCORE=infinity
                        Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/s$
                        Environment=PM2_HOME=/home/pi/.pm2
                        PIDFile=/home/pi/.pm2/pm2.pid
                        Restart=on-failure
                        ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                        ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                        ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                        [Install]
                        WantedBy=multi-user.target
                        Target path
                        /etc/systemd/system/pm2-pi.service
                        Command list
                        [ 'systemctl enable pm2-pi' ]
                        [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                        [PM2] Making script booting at startup...
                        [PM2] [-] Executing: systemctl enable pm2-pi...
                        [PM2] [v] Command successfully executed.
                        [PM2] Freeze a process list on reboot via:
                        $ pm2 save
                        [PM2] Remove init script via:
                        $ pm2 unstartup systemd
                        pm2 startup command done
                        configure the pm2 config file for MagicMirror
                        start MagicMirror via pm2 now
                        save MagicMirror pm2 config now
                        stop MagicMirror via pm2 now
                        disable screensaver via gsettings was true and uint32 300
                        disable screensaver via lightdm.conf
                        disable screensaver via lxsession
                        ^[[92mWe're ready! Run ^[[1m^[[97mpm2 start MagicMirror^[[0m^[[92m from the ~/M$
                        install completed - Fri Apr  9 09:04:39 EDT 2021
                        • 3 / 3
