    MMM-CalendarExt2: Black Screen
    30 Posts 3 Posters 7.5k Views 3 Watching
      sdetweil @jack819
      @jack819 and what do the messages say?
        jack819
        Here you go:
          sdetweil @jack819
          @jack819 you can’t have two instance running!
          do
          pm2 stop all
          pm2 info 0
          pm2 info 1
          look at the path of each and decide which one is right
          then
          pm2 start ??
          ?? is the name or number
          if all is good then get rid of the other one
          pm2 delete ???
          pm2 save
          and by messages, i meant the output of
          pm2 logs --lines=50
          pm2 --help will show u all the things I can do
            jack819 @sdetweil
            @sdetweil Ok. I did that and looked in the console. Here is the message:
            > magicmirror@2.15.0 start /home/pi/MagicMirror
            > ./run-start.sh $1
            [08.04.2021 12:24.35.192] [LOG]   Starting MagicMirror: v2.15.0
            [08.04.2021 12:24.35.203] [LOG]   Loading config ...
            [08.04.2021 12:24.35.216] [LOG]   Loading module helpers ...
            [08.04.2021 12:24.35.220] [LOG]   No helper found for module: alert.
            [08.04.2021 12:24.35.510] [LOG]   Initializing new module helper ...
            [08.04.2021 12:24.35.512] [LOG]   Module helper loaded: updatenotification
            [08.04.2021 12:24.35.514] [LOG]   No helper found for module: clock.
            [08.04.2021 12:24.36.214] [LOG]   Initializing new module helper ...
            [08.04.2021 12:24.36.215] [LOG]   Module helper loaded: MMM-Jast
            [08.04.2021 12:24.37.017] [LOG]   Initializing new module helper ...
            [08.04.2021 12:24.37.018] [LOG]   Module helper loaded: calendar
            [08.04.2021 12:24.37.270] [LOG]   Initializing new module helper ...
            [08.04.2021 12:24.37.272] [LOG]   Module helper loaded: MMM-CalendarExt2
            [08.04.2021 12:24.37.277] [LOG]   Initializing new module helper ...
            [08.04.2021 12:24.37.278] [LOG]   Module helper loaded: currentweather
            [08.04.2021 12:24.37.282] [LOG]   Initializing new module helper ...
            [08.04.2021 12:24.37.283] [LOG]   Module helper loaded: weatherforecast
            [08.04.2021 12:24.37.284] [LOG]   All module helpers loaded.
            [08.04.2021 12:24.37.446] [LOG]   Starting server on port 8080 ...
            [08.04.2021 12:24.37.473] [LOG]   Server started ...
            [08.04.2021 12:24.37.476] [LOG]   Connecting socket for: updatenotification
            [08.04.2021 12:24.37.479] [LOG]   Connecting socket for: MMM-Jast
            [08.04.2021 12:24.37.481] [LOG]   MMM-Jast helper method started...
            [08.04.2021 12:24.37.482] [LOG]   Connecting socket for: calendar
            [08.04.2021 12:24.37.483] [LOG]   Starting node helper for: calendar
            [08.04.2021 12:24.37.484] [LOG]   Connecting socket for: MMM-CalendarExt2
            [08.04.2021 12:24.37.485] [LOG]   Connecting socket for: currentweather
            [08.04.2021 12:24.37.486] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
            [08.04.2021 12:24.37.488] [LOG]   Connecting socket for: weatherforecast
            [08.04.2021 12:24.37.490] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
            [08.04.2021 12:24.37.491] [LOG]   Sockets connected & modules started ...
            [08.04.2021 12:24.37.842] [ERROR] Whoops! There was an uncaught exception...
            [08.04.2021 12:24.37.853] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                at Server.setupListenHandle [as _listen2] (net.js:1313:16)
                at listenInCluster (net.js:1361:12)
                at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8) {
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '127.0.0.1',
              port: 8080
            [08.04.2021 12:24.37.855] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [08.04.2021 12:24.37.856] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [08.04.2021 12:24.37.896] [LOG]   Launching application.
              sdetweil @jack819
              @jack819 looks like something is still running on port 8080
              SO, stop MM (ctrl-c)
              and then do
              ps -ef | grep node
                jack819 @sdetweil
                @sdetweil Did that and got this message:
                pi@raspberrypi:~ $ ps -ef | grep node
                pi        1391  1358  1 12:41 pts/0    00:00:00 grep --color=auto node
                pi@raspberrypi:~ $
                The message in the console is still the same:
                > ./run-start.sh $1
                [08.04.2021 12:44.57.081] [LOG]   Starting MagicMirror: v2.15.0
                [08.04.2021 12:44.57.091] [LOG]   Loading config ...
                [08.04.2021 12:44.57.102] [LOG]   Loading module helpers ...
                [08.04.2021 12:44.57.105] [LOG]   No helper found for module: alert.
                [08.04.2021 12:44.57.398] [LOG]   Initializing new module helper ...
                [08.04.2021 12:44.57.400] [LOG]   Module helper loaded: updatenotification
                [08.04.2021 12:44.57.401] [LOG]   No helper found for module: clock.
                [08.04.2021 12:44.58.115] [LOG]   Initializing new module helper ...
                [08.04.2021 12:44.58.116] [LOG]   Module helper loaded: MMM-Jast
                [08.04.2021 12:44.58.951] [LOG]   Initializing new module helper ...
                [08.04.2021 12:44.58.953] [LOG]   Module helper loaded: calendar
                [08.04.2021 12:44.59.195] [LOG]   Initializing new module helper ...
                [08.04.2021 12:44.59.196] [LOG]   Module helper loaded: MMM-CalendarExt2
                [08.04.2021 12:44.59.199] [LOG]   Initializing new module helper ...
                [08.04.2021 12:44.59.199] [LOG]   Module helper loaded: currentweather
                [08.04.2021 12:44.59.201] [LOG]   Initializing new module helper ...
                [08.04.2021 12:44.59.203] [LOG]   Module helper loaded: weatherforecast
                [08.04.2021 12:44.59.204] [LOG]   All module helpers loaded.
                [08.04.2021 12:44.59.353] [LOG]   Starting server on port 8080 ...
                [08.04.2021 12:44.59.378] [LOG]   Server started ...
                [08.04.2021 12:44.59.380] [LOG]   Connecting socket for: updatenotification
                [08.04.2021 12:44.59.382] [LOG]   Connecting socket for: MMM-Jast
                [08.04.2021 12:44.59.383] [LOG]   MMM-Jast helper method started...
                [08.04.2021 12:44.59.384] [LOG]   Connecting socket for: calendar
                [08.04.2021 12:44.59.386] [LOG]   Starting node helper for: calendar
                [08.04.2021 12:44.59.387] [LOG]   Connecting socket for: MMM-CalendarExt2
                [08.04.2021 12:44.59.389] [LOG]   Connecting socket for: currentweather
                [08.04.2021 12:44.59.390] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                [08.04.2021 12:44.59.391] [LOG]   Connecting socket for: weatherforecast
                [08.04.2021 12:44.59.393] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                [08.04.2021 12:44.59.394] [LOG]   Sockets connected & modules started ...
                [08.04.2021 12:44.59.751] [ERROR] Whoops! There was an uncaught exception...
                [08.04.2021 12:44.59.763] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                  code: 'EADDRINUSE',
                  syscall: 'listen',
                  port: 8080
                [08.04.2021 12:44.59.766] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [08.04.2021 12:44.59.767] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                [08.04.2021 12:44.59.809] [LOG]   Launching application.
                [08.04.2021 12:45.21.540] [LOG]   Shutting down server...
                [08.04.2021 12:45.21.544] [LOG]   Stopping module helper: updatenotification
                [08.04.2021 12:45.21.546] [LOG]   Stopping module helper: MMM-Jast
                [08.04.2021 12:45.21.548] [LOG]   Stopping module helper: calendar
                [08.04.2021 12:45.21.550] [LOG]   Stopping module helper: currentweather
                [08.04.2021 12:45.21.551] [LOG]   Stopping module helper: weatherforecast
                  sdetweil @jack819
                  @jack819 ok, cant tell
                  ps -ef
                  will have to look thru the process list
                  do u have another web server on this machine?
                  pihole
                    jack819 @sdetweil
                    @sdetweil Here is the list:
                    UID        PID  PPID  C STIME TTY          TIME CMD
                    root         1     0  0 12:39 ?        00:00:04 /sbin/init splash
                    root         2     0  0 12:39 ?        00:00:00 [kthreadd]
                    root         3     2  0 12:39 ?        00:00:00 [rcu_gp]
                    root         4     2  0 12:39 ?        00:00:00 [rcu_par_gp]
                    root         8     2  0 12:39 ?        00:00:00 [mm_percpu_wq]
                    root         9     2  0 12:39 ?        00:00:00 [rcu_tasks_rude_]
                    root        10     2  0 12:39 ?        00:00:00 [rcu_tasks_trace]
                    root        11     2  0 12:39 ?        00:00:00 [ksoftirqd/0]
                    root        12     2  0 12:39 ?        00:00:04 [rcu_sched]
                    root        13     2  0 12:39 ?        00:00:00 [migration/0]
                    root        14     2  0 12:39 ?        00:00:00 [cpuhp/0]
                    root        15     2  0 12:39 ?        00:00:00 [cpuhp/1]
                    root        16     2  0 12:39 ?        00:00:00 [migration/1]
                    root        17     2  0 12:39 ?        00:00:01 [ksoftirqd/1]
                    root        20     2  0 12:39 ?        00:00:00 [cpuhp/2]
                    root        21     2  0 12:39 ?        00:00:00 [migration/2]
                    root        22     2  0 12:39 ?        00:00:00 [ksoftirqd/2]
                    root        25     2  0 12:39 ?        00:00:00 [cpuhp/3]
                    root        26     2  0 12:39 ?        00:00:00 [migration/3]
                    root        27     2  0 12:39 ?        00:00:00 [ksoftirqd/3]
                    root        30     2  0 12:39 ?        00:00:00 [kdevtmpfs]
                    root        31     2  0 12:39 ?        00:00:00 [netns]
                    root        33     2  0 12:39 ?        00:00:03 [kworker/1:1-events]
                    root        35     2  0 12:39 ?        00:00:00 [kauditd]
                    root        36     2  0 12:39 ?        00:00:00 [khungtaskd]
                    root        37     2  0 12:39 ?        00:00:00 [oom_reaper]
                    root        38     2  0 12:39 ?        00:00:00 [writeback]
                    root        39     2  0 12:39 ?        00:00:00 [kcompactd0]
                    root        57     2  0 12:39 ?        00:00:00 [kblockd]
                    root        58     2  0 12:39 ?        00:00:00 [blkcg_punt_bio]
                    root        59     2  0 12:39 ?        00:00:00 [watchdogd]
                    root        60     2  0 12:39 ?        00:00:01 [kworker/3:1-events]
                    root        62     2  0 12:39 ?        00:00:00 [rpciod]
                    root        63     2  0 12:39 ?        00:00:00 [kworker/u9:0-hci0]
                    root        64     2  0 12:39 ?        00:00:00 [xprtiod]
                    root        65     2  0 12:39 ?        00:00:00 [kswapd0]
                    root        66     2  0 12:39 ?        00:00:00 [nfsiod]
                    root        67     2  0 12:39 ?        00:00:00 [kthrotld]
                    root        68     2  0 12:39 ?        00:00:00 [iscsi_eh]
                    root        69     2  0 12:39 ?        00:00:00 [iscsi_destroy]
                    root        72     2  0 12:39 ?        00:00:00 [DWC Notificatio]
                    root        73     2  0 12:39 ?        00:00:00 [uas]
                    root        75     2  0 12:39 ?        00:00:00 [vchiq-slot/0]
                    root        76     2  0 12:39 ?        00:00:00 [vchiq-recy/0]
                    root        77     2  0 12:39 ?        00:00:00 [vchiq-sync/0]
                    root        78     2  0 12:39 ?        00:00:00 [zswap-shrink]
                    root        79     2  0 12:39 ?        00:00:00 [sdhci]
                    root        80     2  0 12:39 ?        00:00:00 [irq/47-mmc0]
                    root        82     2  0 12:39 ?        00:00:00 [mmc_complete]
                    root        83     2  0 12:39 ?        00:00:00 [kworker/1:1H-kblockd]
                    root        84     2  0 12:39 ?        00:00:00 [jbd2/mmcblk0p2-]
                    root        85     2  0 12:39 ?        00:00:00 [ext4-rsv-conver]
                    root        87     2  0 12:39 ?        00:00:00 [ipv6_addrconf]
                    root       103     2  0 12:39 ?        00:00:00 [kworker/3:2H-kblockd]
                    root       106     2  0 12:39 ?        00:00:01 [kworker/0:2H+kblockd]
                    root       112     1  0 12:39 ?        00:00:00 /lib/systemd/systemd-journald
                    root       113     2  0 12:39 ?        00:00:00 [kworker/2:2H-kblockd]
                    root       149     1  0 12:39 ?        00:00:00 /lib/systemd/systemd-udevd
                    root       180     2  0 12:39 ?        00:00:00 [vchiq-keep/0]
                    root       181     2  0 12:39 ?        00:00:00 [SMIO]
                    root       188     2  0 12:39 ?        00:00:00 [mmal-vchiq]
                    root       190     2  0 12:39 ?        00:00:00 [mmal-vchiq]
                    root       191     2  0 12:39 ?        00:00:00 [mmal-vchiq]
                    root       193     2  0 12:39 ?        00:00:00 [mmal-vchiq]
                    root       210     2  1 12:39 ?        00:00:40 [v3d_bin]
                    root       213     2  1 12:39 ?        00:00:36 [v3d_render]
                    root       215     2  0 12:39 ?        00:00:05 [v3d_tfu]
                    root       218     2  0 12:39 ?        00:00:00 [v3d_csd]
                    root       219     2  0 12:39 ?        00:00:00 [v3d_cache_clean]
                    root       221     2  0 12:39 ?        00:00:00 [card1-crtc0]
                    root       229     2  0 12:39 ?        00:00:00 [cfg80211]
                    root       235     2  0 12:39 ?        00:00:00 [brcmf_wq/mmc1:0]
                    root       238     2  0 12:39 ?        00:00:00 [brcmf_wdog/mmc1]
                    systemd+   322     1  0 12:39 ?        00:00:00 /lib/systemd/systemd-timesyncd
                    root       359     1  0 12:39 ?        00:00:00 /usr/sbin/rsyslogd -n -iNONE
                    root       362     1  0 12:39 ?        00:00:00 /usr/lib/udisks2/udisksd
                    nobody     363     1  0 12:39 ?        00:00:00 /usr/sbin/thd --triggers /etc/tr
                    root       366     1  0 12:39 ?        00:00:00 /usr/sbin/cupsd -l
                    root       368     1  0 12:39 ?        00:00:00 /lib/systemd/systemd-logind
                    avahi      373     1  0 12:39 ?        00:00:00 avahi-daemon: running [raspberry
                    root       376     1  0 12:39 ?        00:00:00 /usr/sbin/cron -f
                    root       383     1  0 12:39 ?        00:00:00 /usr/sbin/alsactl -E HOME=/run/a
                    avahi      394   373  0 12:39 ?        00:00:00 avahi-daemon: chroot helper
                    message+   395     1  0 12:39 ?        00:00:00 /usr/bin/dbus-daemon --system --
                    root       401     1  0 12:39 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /r
                    root       409     1  0 12:39 ?        00:00:00 /usr/sbin/rngd -r /dev/hwrng
                    root       430     1  0 12:39 ?        00:00:00 /sbin/dhcpcd -q -b
                    root       460     1  0 12:39 ?        00:00:00 /usr/sbin/cups-browsed
                    root       484     1  0 12:39 ?        00:00:00 /usr/sbin/lightdm
                    root       493     1  0 12:39 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
                    root       516     1  0 12:39 ?        00:00:00 wpa_supplicant -B -c/etc/wpa_sup
                    root       527   484  5 12:39 tty7     00:01:56 /usr/lib/xorg/Xorg -s 0 -dpms :0
                    root       528     1  0 12:39 tty1     00:00:00 /bin/login -f
                    root       547     1  0 12:39 ?        00:00:00 nginx: master process /usr/sbin/
                    www-data   548   547  0 12:39 ?        00:00:00 nginx: worker process
                    www-data   549   547  0 12:39 ?        00:00:00 nginx: worker process
                    www-data   550   547  0 12:39 ?        00:00:00 nginx: worker process
                    www-data   551   547  0 12:39 ?        00:00:00 nginx: worker process
                    pi         554     1  0 12:39 ?        00:00:02 PM2 v4.5.6: God Daemon (/home/pi
                    root       576   484  0 12:39 ?        00:00:00 lightdm --session-child 14 17
                    pi         593     1  0 12:39 ?        00:00:00 /lib/systemd/systemd --user
                    pi         594   593  0 12:39 ?        00:00:00 (sd-pam)
                    pi         607   576  0 12:39 ?        00:00:00 /usr/bin/lxsession -s LXDE-pi -e
                    pi         616   593  0 12:39 ?        00:00:00 /usr/bin/dbus-daemon --session -
                    pi         640   607  0 12:39 ?        00:00:00 /usr/bin/ssh-agent x-session-man
                    root       654     1  0 12:39 ?        00:00:00 /usr/bin/hciattach /dev/serial1
                    root       658     2  0 12:39 ?        00:00:00 [kworker/u9:2-hci0]
                    root       660     1  0 12:39 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
                    pi         663   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfsd
                    pi         686   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfsd-fuse /run/us
                    pi         689   528  0 12:39 tty1     00:00:00 -bash
                    pi         692   607  0 12:39 ?        00:00:00 openbox --config-file /home/pi/.
                    pi         700   607  0 12:39 ?        00:00:00 lxpolkit
                    pi         706   607  0 12:39 ?        00:00:03 lxpanel --profile LXDE-pi
                    pi         729     1  0 12:39 ?        00:00:00 xcompmgr -aR
                    pi         745   593  0 12:39 ?        00:00:00 /usr/bin/pulseaudio --daemonize=
                    pi         747     1  0 12:39 ?        00:00:01 /usr/bin/python3 /usr/share/syst
                    pi         748     1  0 12:39 ?        00:00:00 /usr/bin/ssh-agent -s
                    rtkit      749     1  0 12:39 ?        00:00:00 /usr/lib/rtkit/rtkit-daemon
                    root       792     2  0 12:39 ?        00:00:00 [krfcommd]
                    pi         798     1  0 12:39 ?        00:00:00 /usr/lib/menu-cache/menu-cached
                    pi         802   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-udisks2-volum
                    pi         806   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-goa-volume-mo
                    pi         810   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volum
                    pi         814   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-afc-volume-mo
                    pi         819   593  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-mo
                    pi         830   663  0 12:39 ?        00:00:00 /usr/lib/gvfs/gvfsd-trash --spaw
                    pi        1050   706  1 12:40 ?        00:00:37 /usr/lib/chromium-browser/chromi
                    pi        1072  1050  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                    pi        1073  1050  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                    pi        1075  1073  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                    pi        1096  1072  2 12:40 ?        00:00:48 /usr/lib/chromium-browser/chromi
                    pi        1102  1050  0 12:40 ?        00:00:03 /usr/lib/chromium-browser/chromi
                    pi        1113  1075  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                    pi        1125  1096  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                    pi        1130  1075  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                    pi        1140  1075  0 12:40 ?        00:00:00 /usr/lib/chromium-browser/chromi
                    pi        1205  1075  0 12:40 ?        00:00:04 /usr/lib/chromium-browser/chromi
                    pi        1340  1075  3 12:40 ?        00:01:12 /usr/lib/chromium-browser/chromi
                    root      1697     2  0 12:51 ?        00:00:02 [kworker/0:3-events]
                    root      1706     2  0 12:51 ?        00:00:00 [kworker/1:2H]
                    root      1708     2  0 12:51 ?        00:00:00 [kworker/2:1H]
                    root      1709     2  0 12:51 ?        00:00:00 [kworker/3:0H]
                    root      1765     2  0 12:57 ?        00:00:00 [kworker/u8:1-events_unbound]
                    root      1772     2  0 12:58 ?        00:00:00 [kworker/2:1-mm_percpu_wq]
                    root      1781     2  0 13:00 ?        00:00:00 [kworker/0:0H]
                    root      1793     2  0 13:02 ?        00:00:00 [kworker/0:0+events_freezable]
                    root      1796     2  0 13:03 ?        00:00:00 [kworker/u8:0-ext4-rsv-conversio
                    root      1830     2  0 13:04 ?        00:00:00 [kworker/0:2-mm_percpu_wq]
                    root      1834     2  0 13:05 ?        00:00:00 [kworker/1:0-events]
                    root      1838     2  0 13:06 ?        00:00:00 [kworker/2:0-events]
                    root      1842     2  0 13:07 ?        00:00:00 [kworker/3:0-events]
                    root      1849     2  0 13:09 ?        00:00:00 [kworker/0:1-events]
                    root      1859     2  0 13:11 ?        00:00:00 [kworker/u8:2-events_unbound]
                    pi        1864   593  0 13:11 ?        00:00:00 /usr/lib/gvfs/gvfsd-metadata
                    root      1870     2  0 13:11 ?        00:00:00 [kworker/1:2-mm_percpu_wq]
                    root      1871     2  0 13:11 ?        00:00:00 [kworker/2:2-events]
                    root      1900     2  0 13:12 ?        00:00:00 [kworker/1:0H]
                    root      1974     2  0 13:13 ?        00:00:00 [kworker/3:2-events]
                    root      1975     2  0 13:13 ?        00:00:00 [kworker/0:1H]
                    root      1982     2  0 13:13 ?        00:00:00 [kworker/3:1H]
                    pi        2008   706  2 13:13 ?        00:00:00 lxterminal
                    pi        2014  2008  0 13:13 pts/0    00:00:00 bash
                    root      2043     2  0 13:13 ?        00:00:00 [kworker/2:3]
                    pi        2044  2014  0 13:14 pts/0    00:00:00 ps -ef
                    pi@raspberrypi:~ $
                    I do not have a web server running on this machine.
                      sdetweil @jack819
                      @jack819 said in MMM-CalendarExt2: Black Screen:
                      root 547 1 0 12:39 ? 0:00:00 nginx: master process /usr/sbin/
                      think that is incorrect
                        jack819
                        @sdetweil I can barely figure out the simplest tasks on this so I don’t know how that happened. How do I stop that or remove it? The other option (which I would prefer not to do) is I can wipe this all (operating system, etc) and re-install everything.
                        • 2 / 3
