    MMM-GroveGestures Parsing error: Parenthesized pattern
    3 Posts 2 Posters 755 Views 2 Watching
    • jerry11DJ Offline
      jerry11D
      Re: MMM-GroveGestures
      Copying the default config code into config.js makes “npm run config:check” generate a “Parsing error: Parenthesized pattern” on
      exec: (module, gestures) => {
      module.hide(1000, null, {lockstring:"GESTURE"})}
      I’m uncertain how to fix it or proceed and I so much want to incorporate this module into my setup. Can anyone please offer some advice? Thank you. (complete config code is below):
        module: "MMM-GroveGestures",
          autoStart: true, //When Mirror starts, recognition will start.
          verbose:false, // If set as `true`, useful messages will be logged.
          recognitionTimeout: 1000, //Gesture sequence will be ended after this time from last recognized gesture.
          cancelGesture: "WAVE", //If set, You can cancel gesture sequence with this gesture.
          visible: true, //Recognized gesture sequence will be displayed on position
          idleTimer: 1000*60*30, // `0` for disable, After this time from last gesture, onIdle will be executed.
          onIdle: { // See command section
            moduleExec: {
              module: [],
          onDetected: {
            notificationExec: {
              notification: "GESTURE_DETECTED",
            /* You can make Mirror to wake up the modules which were hidden by onIdle with any gestures.
            moduleExec: {
              module: [],
              exec: (module) => {
                module.show(1000, null, {lockstring:"GESTURE"})
          gestureMapFromTo: { //When your sensor is installed with rotated direction, you can calibrate with this.
            "Up": "UP",
            "Down": "DOWN",
            "Left": "LEFT",
            "Right": "RIGHT",
            "Forward": "FORWARD",
            "Backward": "BACKWARD",
            "Clockwise": "CLOCKWISE",
            "anti-clockwise": "ANTICLOCKWISE",
            "wave": "WAVE"
          defaultNotification: "GESTURE",
          pythonPath: "/usr/bin/python", // your python path
          defaultCommandSet: "default",
          commandSet: {
            "default": {
              "FORWARD-BACKWARD": {
                notificationExec: {
                  notification: "ASSISTANT_ACTIVATE",
                  payload: null
              "LEFT-RIGHT": {
                notificationExec: {
                  notification: "ASSISTANT_CLEAR",
                  payload:null,
              "CLOCKWISE": {
                moduleExec: {
                  module: [],
              "ANTICLOCKWISE": {
                moduleExec: {
                  module: [],
              "LEFT": {
                notificationExec: {
                  notification: "ARTICLE_PREVIOUS",
                  payload: null,
              "RIGHT": {
                notificationExec: {
                  notification: "ARTICLE_NEXT",
                  payload: null,
        sdetweil @jerry11D
        @jerry11d don’t do that.
        why are u copying this code?
        jerry11DJ 1 Reply Last reply Reply Quote 0
        • jerry11DJ Offline
          jerry11D @sdetweil
          @sdetweil to make sure my config contains no errors before I start editing and tweaking, only to be completely baffled whether a syntax error is of my doing or not … case in point.
