    Black Screen After MM Update
    4 Posts 2 Posters 1.5k Views 2 Watching
      sonicgoose
      I know others have had this issue in the past and I’ve looked at those posts but can’t find a solution. I have two MagicMirror installations on different RPis — one update no problem with:
      pm2 stop MagicMirror
      cd /MagicMirror
      git pull
      npm install
      The second one just gives me a black screen. The developer inspector won’t even open in the browser. Here is the tail end of the error log:
      [17.04.2021 12:30.25.807] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './v4' is not defined by "exports" in /home/pi/MagicMirror/node_modules/uuid/package.json
      [17.04.2021 12:30.25.839] [ERROR] App threw an error during load
      [17.04.2021 12:30.25.840] [ERROR] Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './v4' is not defined by "exports" in /home/pi/MagicMirror/node_modules/uuid/package.json
          at applyExports (internal/modules/cjs/loader.js:497:9)
          at resolveExports (internal/modules/cjs/loader.js:513:23)
          at Function.Module._findPath (internal/modules/cjs/loader.js:641:31)
          at Module._resolveFilename (internal/modules/cjs/loader.js:959:27)
          at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (internal/modules/cjs/loader.js:848:27)
          at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
          at Module.require (internal/modules/cjs/loader.js:1032:19)
          at require (internal/modules/cjs/helpers.js:72:18)
      [17.04.2021 12:30.25.842] [ERROR] Whoops! There was an uncaught exception...
      [17.04.2021 12:30.25.851] [ERROR] Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './v4' is not defined by "exports" in /home/pi/MagicMirror/node_modules/uuid/package.json
          at require (internal/modules/cjs/helpers.js:72:18) {
        code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
      [17.04.2021 12:30.25.853] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [17.04.2021 12:30.25.854] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Any suggestions?
        sdetweil @sonicgoose
        @sonicgoose said in Black Screen After MM Update:
        cd /MagicMirror
        git pull
        npm install
        is MagicMirror really in the root? or in user folder ~/MagicMirror
          sonicgoose @sdetweil
          @sdetweil User. Sorry, I was logged in through ssh as the user, so no need to type the ~ before.
          Short answer: ~/MagicMirror
            sonicgoose @sonicgoose
            Reinstalled MM and modules from scratch. Backup was too old and I had changed too much since it was done. Reinstalling was faster.
