    Change MM fonts
    13 Posts 3 Posters 3.2k Views 2 Watching
      Aaaxel
      Hello everybody,
      I started my MM few days ago and I would like to change the font of it, I don’t quite like the actual one (its name is Roboto I believe). So I got an .ots file of a new font I like more (2 actually) and I’m trying to use it as the font for every modules. Problem is, I have never done that and I have no idea of how works a CSS file at all, so I would like to know how to do that (is it even possible?)
      Thanks,
      Axel
        sdetweil @Aaaxel
        @aaaxel so, you want to add an entry to css/custom.css that changes the font name
        which is done in the body statement in main.css (don’t edit main.css)
        if custom.css doesn’t exist, create it like this
        cd ~/MagicMirror
        touch css/coustom.css
        then u can edit it (custom/css) and add
        body {
             font-family: "Roboto Condensed", sans-serif;
        with your new font family instead
          Aaaxel @sdetweil
          @sdetweil Is that all? nothing changes :grinning_face_with_sweat: I may have to do something obvious for you that I don’t know as a beginner
          S ? 2 Replies Last reply Reply Quote 0
            sdetweil @Aaaxel
            @aaaxel i’m not sure what you said…
            fonts go in the fonts folder, yes?
            • ? Offline
              A Former User @Aaaxel
              This post is deleted!
                Aaaxel @Guest
                @hango Cool! It half-worked: Most of the fonts have changed, but there is still some text in roboto, especially in the default news module…
                • ? Offline
                    Aaaxel @Guest
                    @hango ok I got it, I should be able to update every module this way, thanks!
                    • ? Offline
                        Aaaxel @Guest
                        @hango I just tried your 2 solutions but newsfeed still don’t change…
                        This is what I have in custom.css:
                        @import url('https://fonts.googleapis.com/css2?family=Spartan:wght@200;400;600;800&display=swap');
                        body {
                             font-family: "Spartan", sans-serif;
                             font-weight: 800;
                             .newsfeed {
                             font-weight: 600;
                        I also tried this way:
                        body {
                             font-weight: 800;
                             .newsfeed {
                             font-weight: 600;
                        • ? Offline
                          A Former User
                            Aaaxel @Guest
                            @hango Aaand now that works! Great, thanks! :ok_hand:
                            So how did you find the others nbames like “newsfeed-source”, “newsfeed.title” etc…? I would like to do it by myself next time :winking_face:
                            • ? Offline
