    Help!!
    4 Posts 3 Posters 709 Views 3 Watching
    • G Offline
      GnomeMcGmome
      So, i just built my first mirror and it is super cool. I cant get the weather module to work and it is always saying loading. I registered and got an api key but it wont work. I also want to add my personal google calendar but i cannot figure out how. IM a total noob so any help would be appreciated.
        sdetweil @GnomeMcGmome
        @gnomemcgmome
        calendar
        logon to calendar.google.com via the web
        in the left nav select your calendar, left click and pick settings
        a column will appear to the right,
        scroll down to Integrate calendar
        select the secret address in ical format (url)
        paste that into the config.js where it says url:
        for the calendar
        note that your url should be in quotes
        weather… u either need the locationID or…
        G 1 Reply Last reply Reply Quote 1
        • G Offline
          GnomeMcGmome @sdetweil
          @sdetweil ok awesome thank you
            scumbelly @GnomeMcGmome
            @gnomemcgmome
            Hi. Take a look at this to see if it will help with your loading issue.
            https://forum.magicmirror.builders/topic/14919/weather-module-location-id
            Cheers.
