    I can't get screencast to show up longer?
    1 Posts 1 Posters 351 Views 1 Watching
    • F Offline
      fribse
      Not sure what the h… happened here.
      My MMM-Screencast doesn’t show up in the Youtube app any longer.
      I did a reinstall with
      git clone https://github.com/kevinatown/MMM-Screencast.git
      cd MMM-Screencast
      npm install
      Config looks like this
            module: "MMM-Screencast",
            position: "bottom_right",
              castName: "Spejl",
              position: "bottomCenter",
              height: 600,
              width: 800,
      Just to be sure that I had the latest, but nothing shows up.
      Is there a special trick for this?
      Looking in the logs, I did find something, but I don’t understand the meaning, except that it says it’s already listening?
      0|MagicMir | [24.04.2021 17:30.32.266] [ERROR] Error [ERR_SERVER_ALREADY_LISTEN]: Listen method has been called more than once without clo
      sing.
      0|MagicMir |     at Server.listen (net.js:1386:11)
      0|MagicMir |     at DialServer.start (/home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:123:17)
      0|MagicMir |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Screencast/node_helper.js:22:21)
      0|MagicMir |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11)
      0|MagicMir |     at Socket.emit (events.js:210:5)
      0|MagicMir |     at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:434:28
      0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:75:11) {
      0|MagicMir |   code: 'ERR_SERVER_ALREADY_LISTEN'
      0|MagicMir | }
      I looked a bit with
      sudo netstat -tulpn | grep LISTEN
      And without MagicMirror running it shows
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      490/sshd
      tcp6       0      0 :::22                   :::*                    LISTEN      490/sshd
      with MagicMirror it shows
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      5754/electron.js
      tcp6       0      0 :::8569                 :::*                    LISTEN      5754/electron.js
      So the port 8569, isn’t that screencast? If I uncomment the screencast config, it doesn’t show the port as opened…
      So why doesn’t it show up in the app?
