    Poemoftheday module showing black screen
    7 Posts 3 Posters 1.6k Views 3 Watching
    • E
      e199504
      I have installed the module MMM-PoemOfTheDay,
      As instructed I added the following to the config file.
          module: "MMM-PoemOfTheDay",
          position: "lower_third",
            textLimit: 1000,
            lineLimit: 10,
            detectLanguageApiKey: "{API_KEY}",
            languageSet: ["en", "es"],
            updateInterval: 120000
      Upon running the magic mirror, I only get a black screen.
      Did someone experience the same problem ?
        sdetweil @e199504
        @e199504 said in Poemoftheday module showing black screen:
        is that a period?
        not in JavaScript. remove that
        • E
          e199504 @sdetweil
          @sdetweil I removed the dot. This time I am getting the error that I need to check my config file.
          When I runnpm run config:check, I am getting the following error
          [13.05.2021 15:06.26.058] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
          [13.05.2021 15:06.26.130] [ERROR] Your configuration file contains syntax errors :(
          [13.05.2021 15:06.26.133] [ERROR] Line 56 column 3: Parsing error: Unexpected token {
          This is a snippet of my config file
            sdetweil @e199504
            so, that means the line before it contains an error…
            USUALLY unexpected token means the line before is missing a trailing comma
                 		module:"......",
                 	}       /// this line, should say, MORE to FOLLOW   , <--- comma
                 		module:"ppppp",
            • E
              e199504 @sdetweil
              @sdetweil I copied again the array to add in the config file from the Poemoftheday
              here is the snippet of my config file
              			module: "alert",
                  			position: "upper_third",
                    				textLimit: 1000,
                    				lineLimit: 10,
               			module: "MMM-Breathwork",
                			position: "bottom_right",
                sdetweil @e199504
                @e199504 that should be ok… did config:check find anything?
                also, did you do the npm install in the module folder after git clone?
                what do the messages say where u start MM?
                npm start or pm2
                if using pm2 then
                pm2 logs --lines=100
                should show them
                • O
                  Ortega65
                  I am also having similar issue.
