    MagicMirror Synology Docker Module Installation
    3 Posts 2 Posters 2.0k Views 2 Watching
    • FrelandF
      Freland
      Hi!
      I’ve been running my MagicMirror setup with a Raspberry Pi for some time, but now I would like to transition into running it via docker on my Synology Network disk.
      I followed this guide to get things up and running : https://mariushosting.com/how-to-install-magicmirror-on-your-synology-nas/
      However, now I’m stuck with the question - how do I install modules in docker?! Anyone that can explain or send me in the right direction?
      //F
        sdetweil @Freland
        @freland on your server you use the docker exec command to get a prompt into the running container, and then do the git clone, npm install. using the containers npm and node
        then u can close the prompt and edit the config.js stored on the host disk, and restart
        FrelandF 1 Reply Last reply
        • FrelandF
          Freland @sdetweil
          @sdetweil Great! thanks for the help! I was able to get things up and running…
