    Assistance with JavaScript widget
    2 Posts 2 Posters 307 Views 2 Watching
      Jasond
      I’m a complete noob to coding but new to the MagicMirror.
      I have a few modules already loaded and working eg. MMM-cryptocurrency and MMM-Widget. The latter is displaying Tradingview widgets without any issues.
      My problem is:
      I want to add another widget but it doesn’t display on the mirror. All i see is a white space where the widget is supposed to be.
      The module MMM-Widget is installed and this is the entry on in the config file.
      module: “MMM-Widget”,
      widgets: [
      //This widget works
      html:<!-- TradingView Widget BEGIN --> <div class="tradingview-widget-container"> <div class="tradingview-widget-container__widget"></div> <div class="tradingview-widget-copyright"><a href="https://www.tradingview.com" rel="noopener" target="_blank"><span class="blue-text">Quotes</span></a> by TradingView</div> <script type="text/javascript" src="https://s3.tradingview.com/external-embedding/embed-widget-tickers.js" async> { "symbols": [ { "description": "DOGECOIN", "proName": "BITTREX:DOGEUSD" }, { "description": "GOLD", "proName": "OANDA:XAUUSD" }, { "description": "AUD/USD", "proName": "OANDA:AUDUSD" }, { "description": "EUR/USD", "proName": "OANDA:EURUSD" }, { "description": "GBP/USD", "proName": "OANDA:GBPUSD" }, { "description": "AUD/CAD", "proName": "OANDA:AUDCAD" }, { "description": "EUR/CAD", "proName": "OANDA:EURCAD" }, { "description": "EUR/AUD", "proName": "OANDA:EURAUD" } ], "colorTheme": "dark", "isTransparent": true, "showSymbolLogo": true, "locale": "en" } </script> </div> <!-- TradingView Widget END -->, //insert your script or html codes here.
      position: “bottom_center”,
      width: “1800px”,
      height: “105px”,
      backgroundColor: “0000”
      //This is the widget that doesn’t display
      html:<script type="text/javascript"> DukascopyApplet = {"type":"fxmarkethours", "params":{ "showHeader":true, "displayMainMenu":false, "displayTimezoneChange":true, "displayInstrumentChange":true, "displayFollowButton":true, "allowTimezoneChange":true, "allowInstrumentChange":true, "defaultTimezone":1, "showIndicator":"0", "defaultFollowMode":true, "worldMapColor":"blue", "hoursBackground":"#444f5f", "hoursActiveBackground":"#7d92b0", "hoursTextColor":"#ffffff", "currentHourBGColor":"#f9fdff", "dstHourColor":"#0cf6ff", "indicatorBarColor":"#5090c6", "graphPointsColor":"#ffffff", "width":"743", "height":"433", "adv":"popup", "lang":"en" } }; </script>,
      position: “right”,
      width: “800px”,
      height: “450px”,
      backgroundColor: “#ffff”
      Please help if you are able to.
      Thank you!
      Jason
        sdetweil @Jasond
        @jasond the second on is not a widget, it is code… < script…< /script>
        MM is expecting html content
