    Google Calendar MMM-CalendarExt stopped working
    2 Posts 1 Posters 371 Views 1 Watching
      robolobos
      I had everything up and running, this mirror has been working with its existing config for a couple of years now. But today I wake up and where my google calendar usually is, is now completely blank. Nothing changed and it was working yesterday. It’s only pulling from one calendar and I double checked that the .ics looks good which it does.
      I did have a situation pop up with rainmeter recently where my google news feed died because they now require 2FA so you had to alter the widget to force show and bypass the 2FA. Is this because of something like that? Has anyone else seen this behavior?
        robolobos @robolobos
        @robolobos OK, I burned down the install, reformatted the SD card and re-installed MM with the newer MMM-CalendarEXT2 module. Made sure I was using the private link to the calendar and it’s pulling the data now. I’m not sure what part of all this fixed it but after running solid for a few years I guess it was time for a rebuild.
