    using a library in a module
    2 Posts 2 Posters 454 Views 2 Watching
    • T Offline
      TomasF
      I’m trying to use https://github.com/onury/tasktimer, I can get it to work in node_helper but
      the module doesn’t see it. I’ve tried adding
      // Define required scripts.
      getScripts: function () {
        return ["modules/MMM-GooglePhotos/node_modules/tasktimer/lib/tasktimer.js"]
      and using
      const timer = TaskTimer(1000)
      in a function but I get a TaskTimer not defined error.
      Any sugestions?
      -Tomas
        sdetweil @TomasF
        @tomasf i don’t know for certain, but you could open the developers window and look at the sources tab to see what was actually imported and setup…
