    Calendar not working after update
    4 Posts 2 Posters 1.1k Views 2 Watching
    • U Offline
      uatuba
      Greetings…I updated, and everything worked great using the update script, except the calendar. If I don’t comment out the calendar section in my config, I just get a blank screen. When I do comment it out, everything else works as expected. Has there been a change or do I have something wrong? I’ve searched the documentation and the forum and I can’t find anything.
                            header: "Upcoming Events",
                            timeFormat: "absolute",
                            getRelative: 0,
                            urgency: 0,
                            showEnd: false,
                            maximumEntries: 10,
                                                    symbol: "calendar-check-o ",
                                                    url: "webcal://p62-caldav.icloud.com/[removed]"
        sdetweil @uatuba
        @uatuba you said u updated? how did u do that?
        for 2.15 you also had to do npm install again because some dependencies changed
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          uatuba @sdetweil
          @sdetweil I used the upgrade script. Nothing broke…except the Calendar. I went back and did npm install.
          Now nothing works–I get a blank screen, which may have to do with the MMM-PIR-Sensor module which breaks every time I do an upgrade.
            sdetweil @uatuba
            @uatuba yeh, good old pir needs a binary build
            electron-rebuild to match electron versions
            we should have looked at the logs for calendar issue
