    Help configuring the Magic Mirror
    11 Posts 4 Posters 8.5k Views 5 Watching
    • SnilleS Offline
      Snille Module Developer @PhilsterM9
      @PhilsterM9 Hi again, maybe I’m missing something…
      If you followed the install guide when you installed…
      When you SSH in to your Pi (or open a terminal on the desktop of the pi) you should end up in a prompt looking like this:
      pi@MagicMirror:~ $
      Now, type as follows:
      pi@MagicMirror:~ $ cd MagicMirror/config/
      You should now be in MagicMirror/config/ looking like this:
      pi@MagicMirror:~/MagicMirror/config $
      To copy a file enter:
      pi@MagicMirror:~/MagicMirror/config $ cp config.js.sample config.js
      Check if the files where copied with ls both file should be there now:
      pi@MagicMirror:~/MagicMirror/config $ ls
      Listed like this:
      config.js  config.js.sample
      Now, if you want you can edit your config file:
      pi@MagicMirror:~/MagicMirror/config $ nano config.js
      Change whatever you need to change…
      But you actually don’t have to change anything just for testing it.
      Now restart the MagicMirror with pm2 like this:
      pi@MagicMirror:~/MagicMirror/config $ pm2 restart mm
      You should se something like this:
      Restarts are now immutable, to update environment or conf use --update-env
      [PM2] Applying action restartProcessId on app [mm](ids: 0)
      [PM2] [mm](0) ✓
      │ App name │ id │ mode │ pid   │ status │ restart │ uptime │ cpu │ mem      │ watching │
      │ mm       │ 0  │ fork │ 26361 │ online │ 32      │ 0s     │ 22% │ 2.3 MB   │ disabled │
       Use `pm2 show ` to get more details about an app
      And your Magic should have started. :)
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
