    Module Border Removal Issue
    Scheduled Pinned Locked Moved Solved Custom CSS
    14 Posts 3 Posters 4.6k Views 3 Watching
      matt216 @sdetweil
      @sdetweil said in Module Border Removal Issue:
      yes, and it really eliminates the ‘try this, nope, try this, nope… loop’
      Doesn’t it! Waiting for pm2 restart mm each time was driving me nuts!
        sdetweil @matt216
        @matt216 said in Module Border Removal Issue:
        you don’t have to do a full restart,
        change custom.css and hit f5 in the dev window, or ctrl-r on the MM side
        so the cycle
        start MM, npm start dev
        or ctrl-shift-i if already running
        use the elements tab to locate the html entry, which will expand the css class tree on the right
        select the element u want to change (select pointer to left of elements page
        edit the styles, upper right to get the effect u want
        select/copy
        alt-spacebar, n to minimise MM window
        use your editor to add/change entry custom.css
        using class name found in dev window
        paste
        save
        click on taskbar mm entry to resurface page
        ctrl-r or f5 to refresh page, reloading custom.css
        check results…
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
        • ankonaskiff17A Offline
          ankonaskiff17 @sdetweil
          @sdetweil This a follow-on question regarding developer tools while MM running. If you have a module that is updating at a rapid pace it gets to be a real challenge trying to drill down to the lines you want to look at because at each cycle it will close all the expanded subsections. Is there a way to stop that other than setting a large update value?
          Seems like it was either stock ticker or news ticker were culprits as rest of modules like calendar you can update every 12 hours or so.
            sdetweil @ankonaskiff17
            @ankonaskiff17 no, they recreate the output every time, so you have to slow them down…
