    Black Screen
    Scheduled Pinned Locked Moved Forum
    16 Posts 5 Posters 5.3k Views 5 Watching
      MassiveArts 0
      Good day,
      I would like to have MMM-Google Fit on my Smart Mirror. I have installed that too, but I have a black screen. But it starts in the black picture
      https://github.com/amcolash/MMM-GoogleFit
      		module: "weather",
      		header: "Weather Forecast",
      			type: "forecast",
      			locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			apiKey: "YOUR_OPENWEATHER_API_KEY"
      		module: 'MMM-GoogleFit',
      		position: 'position',
      			// If desired
      if (typeof module !== “undefined”) {module.exports = config;}
      • BKeyportB Offline
        BKeyport Module Developer @MassiveArts 0
        @massivearts-0 the way you posted it, the forum corrupted it.
        Please place ``` around the code next time.
        That being said, go to the magicmirror directory, and type:
        npm run config:check
        It’ll help you solve the errors.
          MassiveArts 0 @BKeyport
          @bkeyport said in Black Screen:
          • BKeyportB Offline
            @massivearts-0 you must be in the MagicMirror directory.
            pi@officemirror:~ $ cd MagicMirror/
            pi@officemirror:~/MagicMirror $ npm run config:check
            > magicmirror@2.16.0 config:check /home/pi/MagicMirror
            > node js/check_config.js
            [08.07.2021 16:19.03.333] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
            [08.07.2021 16:19.03.575] [INFO]  Your configuration file doesn't contain syntax errors :)
              • BKeyportB Offline
                @massivearts-0 back down to ~/MagicMirror/ and try the command there. Also, the config file should be at ~/MagicMirror/config/config.js
                  Didn’t work
                    sdetweil @MassiveArts 0
                    @massivearts-0 open a terminal window onto the pi
                    cd ~/MagicMirror
                    npm run check:config
                    but as I said on discord
                    we need to see the messages that are output when u start MagicMirror
                    you either do
                    npm start
                    or pm2 start
                    if pm2 then the command to display the logs is
                    pm2 logs --lines=100
                    the black screen is probably a missing dependency module, and the messages will tell us which one
                      DJBOOB66
                      Maybe position: ‘position’, is your problem add a location on mirror like “top_left”
                        sdetweil @DJBOOB66
                        @djboob66 yes, he had “top_Bar” before, but that is not the black screen
                        maybe no content displayed as mm can’t figure out where to put it
                        system is case sensitive
                          the module he added didn’t document needing request
                            DJBOOB66
                            You did do
                            cd git clone https://github.com/amcolash/MMM-GoogleFit.git
                            cd MMM-GoogleFit
                            npm install
                              sdetweil @DJBOOB66
                              @djboob66 yes he did. but the module uses the request library without documenting it in the package.json
                              and request was removed from the MagicMirror package in 2.15.
                              • BKeyportB Offline
                                @sdetweil how dare they remove libraries in the main program they don’t use anymore! 🤣🤣
                                  sdetweil @BKeyport
                                  @bkeyport and forced to stop using!!
                                  bugsounetB 1 Reply Last reply Reply Quote 0
                                  • bugsounetB Offline
                                    bugsounet Banned @sdetweil
                                    Many sub library use again it, it’s very very long to depreciate a library ;)
