Black Screen
Scheduled Pinned Locked Moved Forum
16 Posts 5 Posters 3.6k Views 5 Watching
    MassiveArts 0
    Good day,
    I would like to have MMM-Google Fit on my Smart Mirror. I have installed that too, but I have a black screen. But it starts in the black picture
    https://github.com/amcolash/MMM-GoogleFit
    		module: "weather",
    		header: "Weather Forecast",
    			type: "forecast",
    			locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
    			apiKey: "YOUR_OPENWEATHER_API_KEY"
    		module: 'MMM-GoogleFit',
    		position: 'position',
    			// If desired
    if (typeof module !== “undefined”) {module.exports = config;}
    B 1 Reply Last reply Jul 8, 2021, 11:17 PM Reply Quote 0
    • B Online
      BKeyport Module Developer @MassiveArts 0
      @massivearts-0 the way you posted it, the forum corrupted it.
      Please place ``` around the code next time.
      That being said, go to the magicmirror directory, and type:
      npm run config:check
      It’ll help you solve the errors.
      M 1 Reply Last reply Jul 8, 2021, 11:19 PM Reply Quote 0
        MassiveArts 0 @BKeyport
        @bkeyport said in Black Screen:
        B 1 Reply Last reply Jul 8, 2021, 11:23 PM Reply Quote 0
        • B Online
          @massivearts-0 you must be in the MagicMirror directory.
          pi@officemirror:~ $ cd MagicMirror/
          pi@officemirror:~/MagicMirror $ npm run config:check
          > magicmirror@2.16.0 config:check /home/pi/MagicMirror
          > node js/check_config.js
          [08.07.2021 16:19.03.333] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
          [08.07.2021 16:19.03.575] [INFO]  Your configuration file doesn't contain syntax errors :)
          M 1 Reply Last reply Jul 8, 2021, 11:26 PM Reply Quote 0
            B 1 Reply Last reply Jul 8, 2021, 11:27 PM Reply Quote 0
            • B Online
              @massivearts-0 back down to ~/MagicMirror/ and try the command there. Also, the config file should be at ~/MagicMirror/config/config.js
              M 1 Reply Last reply Jul 8, 2021, 11:32 PM Reply Quote 0
                Didn’t work
                S 1 Reply Last reply Jul 9, 2021, 12:18 AM Reply Quote 0
                  sdetweil @MassiveArts 0
                  @massivearts-0 open a terminal window onto the pi
                  npm run check:config
                  but as I said on discord
                  we need to see the messages that are output when u start MagicMirror
                  you either do
                  npm start
                  or pm2 start
                  if pm2 then the command to display the logs is
                  pm2 logs --lines=100
                  the black screen is probably a missing dependency module, and the messages will tell us which one
                    DJBOOB66
                    Maybe position: ‘position’, is your problem add a location on mirror like “top_left”
                    S 1 Reply Last reply Jul 9, 2021, 12:35 AM Reply Quote 0
                      sdetweil @DJBOOB66
                      @djboob66 yes, he had “top_Bar” before, but that is not the black screen
                      maybe no content displayed as mm can’t figure out where to put it
                      system is case sensitive
                      S 1 Reply Last reply Jul 9, 2021, 1:53 AM Reply Quote 0
