    Black Screen
    Scheduled Pinned Locked Moved Forum
    16 Posts 5 Posters 6.0k Views 5 Watching
      MassiveArts 0 @BKeyport
      @bkeyport said in Black Screen:
      you must be in the MagicMirror directory.
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @MassiveArts 0
        @massivearts-0 back down to ~/MagicMirror/ and try the command there. Also, the config file should be at ~/MagicMirror/config/config.js
        M 1 Reply Last reply
          Didn’t work
            sdetweil @MassiveArts 0
            @massivearts-0 open a terminal window onto the pi
            npm run check:config
            but as I said on discord
            we need to see the messages that are output when u start MagicMirror
            you either do
            npm start
            or pm2 start
            if pm2 then the command to display the logs is
            pm2 logs --lines=100
            the black screen is probably a missing dependency module, and the messages will tell us which one
              DJBOOB66
              Maybe position: ‘position’, is your problem add a location on mirror like “top_left”
                sdetweil @DJBOOB66
                @djboob66 yes, he had “top_Bar” before, but that is not the black screen
                maybe no content displayed as mm can’t figure out where to put it
                system is case sensitive
                  the module he added didn’t document needing request
                    DJBOOB66
                    You did do
                    cd git clone https://github.com/amcolash/MMM-GoogleFit.git
                    cd MMM-GoogleFit
                    npm install
                      sdetweil @DJBOOB66
                      @djboob66 yes he did. but the module uses the request library without documenting it in the package.json
                      and request was removed from the MagicMirror package in 2.15.
                      • BKeyportB
                        @sdetweil how dare they remove libraries in the main program they don’t use anymore! 🤣🤣
                          sdetweil @BKeyport
                          @bkeyport and forced to stop using!!
                          bugsounetB 1 Reply Last reply
                          • bugsounetB
                            bugsounet Banned @sdetweil
                            Many sub library use again it, it’s very very long to depreciate a library ;)
