Profile switching API
13 Posts 5 Posters 8.3k Views 2 Watching
    ascension @00conman
    @00conman
    Any progress on this? Facial recognition looks great, but I can’t get approval from my better half to put a camera in the bathroom mirror… Changing profiles using a physical button or a gesture would work perfectly.
    • K Offline
      KirAsh4 Moderator
      Just thinking out loud here, but you should be able to have a button that cycles through profiles. It might even be possible to use the current Button module (I forgot who wrote it), and use that. Set up a case switch to change profiles. Something sort of like this:
      // Warning, pseudo code, will not run as-is
      var buttonCount = 0;
      var availableProfiles = 2;
      if (detect_button_press()) {
        buttonCount++;
        if (buttonCount > availableProfiles) buttonCount = 0;
        switch (buttonCount) {
          case 0:
            // Display profile for user 0
            break;
          case 1:
            // Display profile for user 1
            break;
          case 2:
            // Display profile for user 2
            break;
          default:
            // Display default profile
      Now you can push the button all day long. The only issue here is that you are cycling through the profiles, and for a household that has several, that can become a bit tedious.
      Another possibility is to count button presses, so you would switch profiles based on how many times one pushed the button, but that too has its limitations. It works great for single-click, double-click, and possibly a long-press, but anything after that and it gets problematic again. Profile cycling is by far the easiest to implement.
      A 1 Reply Last reply Jun 27, 2016, 5:01 PM Reply Quote 0
        ascension @KirAsh4
        @KirAsh4
        Thanks for the quick response! I’ll take a look at the BUTTON module. Hopefully it’ll work the way I need it to. Fortunately, I only have 2 profiles I’ll need to cycle thru.
        2 / 2
