    Profile switching API
    13 Posts 5 Posters 10.6k Views 2 Watching
    • 0 Offline
      00conman
      PPS in layman terms also because I’m just trying to learn how to build a module (module development form) and my brain is already oozing out my ears.
        paviro @00conman
        @00conman what do you mean by profile? This module does not switch any profiles it’s just activates and disables the monitor :D
        – The Doctor
        0 1 Reply Last reply Reply Quote 0
        • 0 Offline
          00conman @paviro
          @paviro response to reading the whole message back
          I was under the impression that you could sync up multiple different module configurations based on a face or “code.” For example Billy’s face code tracks the weather in London while Sally’s tracks New York’s.
          Response I was too lazy to re-write and only wrote reading the first sentance
          I had a stupid idea to make my mirror have 5 base profiles i.e. a weather, default, news, etc. And, I was going to base that profiling off of your code if possible. Also I was wondering if I could use a command from a terminal to change profile so that I could hook it up to a phone or tablet via something like tasker using a ssh. If possible I would love to attempt it but if not than I’ll move that idea to the trash.
          • 0 Offline
            00conman
            Furthermore, with some time browsing the forums I found this post
            https://forum.magicmirror.builders/topic/10/multiple-layouts-configs
            with you saying, “Different layouts based on facial recognition is already implemented here :slight_smile: It should be trivial to write something similar for the other use cases you just mentioned! Have a look at my code for an example.” While not outright saying it; it does sound something like different “profiles” that are able to be switched between.
              paviro
              It is but this thread is not about that module! Please go to this topic for that.
              Update: I moved your posts to the correct topic, please check next time :) will post an example how to switch profiles later.
              – The Doctor
              • 0 Offline
                00conman
                Okay sorry about that.
                My first question is if I would be able to switch out layouts via a command in the Pi’s terminal or via an ssh. And, my second, if I can change layouts from a terminal, is how I would go about making the different layouts.
                P MichMichM 2 Replies Last reply Reply Quote 0
                  paviro @00conman
                  @00conman sure you could. Would be the same thing like I do in my module but you probably would need to serve an API you could then trigger via a terminal :)
                  – The Doctor
                  • MichMichM Offline
                    MichMich @00conman
                    @00conman it would be worth creating a module that has an API to switch “profiles”. It’s actually extremely doable. But I suggest you open a separate topic for this.
                    • 0 Offline
                      00conman
                      Okay I’ll look into it.
                        ascension @00conman
                        @00conman
                        Any progress on this? Facial recognition looks great, but I can’t get approval from my better half to put a camera in the bathroom mirror… Changing profiles using a physical button or a gesture would work perfectly.
                        • K Offline
                          KirAsh4 Moderator
                          Just thinking out loud here, but you should be able to have a button that cycles through profiles. It might even be possible to use the current Button module (I forgot who wrote it), and use that. Set up a case switch to change profiles. Something sort of like this:
                          // Warning, pseudo code, will not run as-is
                          var buttonCount = 0;
                          var availableProfiles = 2;
                          if (detect_button_press()) {
                            buttonCount++;
                            if (buttonCount > availableProfiles) buttonCount = 0;
                            switch (buttonCount) {
                              case 0:
                                // Display profile for user 0
                                break;
                              case 1:
                                // Display profile for user 1
                                break;
                              case 2:
                                // Display profile for user 2
                                break;
                              default:
                                // Display default profile
                          Now you can push the button all day long. The only issue here is that you are cycling through the profiles, and for a household that has several, that can become a bit tedious.
                          Another possibility is to count button presses, so you would switch profiles based on how many times one pushed the button, but that too has its limitations. It works great for single-click, double-click, and possibly a long-press, but anything after that and it gets problematic again. Profile cycling is by far the easiest to implement.
                            ascension @KirAsh4
                            @KirAsh4
                            Thanks for the quick response! I’ll take a look at the BUTTON module. Hopefully it’ll work the way I need it to. Fortunately, I only have 2 profiles I’ll need to cycle thru.
