    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 357.4k Views 23 Watching
      savage_gr1nd @Journeytojah
      @Journeytojah don’t sudo anything in this git. I made that mistake also.
        Journeytojah @savage_gr1nd
        @savage_gr1nd will try, i can imagine i had done that without realizing…
        I like the response time of alexa, and would love to get this integrated, but like i said with less talking and more text.
        Will try again some time and update…
        • G Offline
          Gunwoody
          I’m just revisiting this project as i was getting nowhere. I think i am now even more confused. Can someone tell me ‘where’ the certs folder needs copying to? Is it into the MagicMirror folder or is it somewhere else??
          Thanks anyone :)
          lucallmonL 1 Reply Last reply Reply Quote 1
          • lucallmonL Offline
            lucallmon @Gunwoody
            @Gunwoody I gave up on it too. The git is not user friendly and there’s no step by step guide. Pit that together and I’ll come back.
            G 1 Reply Last reply Reply Quote 1
            • G Offline
              Gunwoody @lucallmon
              @lucallmon I’m just getting nowhere. I can setup MagicMirror2. I can configure it and get it to run no problem. Where it gets fuzzy is
              a) where does MMM-Mirroronthewall module go - is it inside the modules folder of MagicMirror2?
              b) Where do you run the aws-iot-device-sdk ?
              c) Where does the certs folder go?
              Just a simple step guide would be ace - anyone??
                joanaz @Gunwoody
                @Gunwoody @lucallmon sorry, you do have to have a little of programming experience and experience of using AWS services to setup this module. I do have a step by step guide in the companion Alexa skill repo, but it would still be hard for people without any software experience.
                • G Offline
                  Gunwoody
                  I haven’t had any trouble setting up AWS/Lambda - i just can’t get it running loxcally - can you just answer the above questions for me.
                  • G Offline
                    Gunwoody
                    I’ve also got Alexa-avs running with sensory wakeword engine - so i’m not a complete idiot :)
                    • G Offline
                      Gunwoody @Gunwoody
                      @Gunwoody Hold the front page - i may have cracked it :)
                      • G Offline
                        Gunwoody @Gunwoody
                        @Gunwoody OK - getting closer.
                        Upload of zip to Lambda finally worked ok.
                        I can now enter Utterances in the service simulator on developer console and get a Lambda response
                        I can see the response properly logged in Cloudwatch logs with no errors
                        But i must be missing something fundamental because when i load Magic Mirror ir run perfectly but doesn’t seem to be listening for the Alexa wake words etc.
                        Oh well getting closer all the time :)
                        • 11
                        • 12
                        • 13
                        • 14
                        • 15
                        • 18
                        • 19
                        • 13 / 19
