    Mirror goes to black after adding MMM-CalendarWeek
    11 Posts 4 Posters 4.2k Views 4 Watching
      sdetweil @maddmurph
      @maddmurph the valid-url and request modules were removed from mm in 2.16 as request has a security issue and will not be fixed.
      we’ve found quite a few modules that did not document the libraries they used, oops
      so to fix near term
      cd ~/MagicMirror
      npm install valid-url
      the module is still broken and next mm install this will fail again
        maddmurph @sdetweil
        I did that and now nothing works. I get this error
        [08.08.2021 19:02.42.973] [ERROR] WARNING! Could not find config file. Please create one. Starting with default configuration.
        [08.08.2021 19:02.42.976] [LOG]   Loading module helpers ...
        [08.08.2021 19:02.42.977] [LOG]   No helper found for module: alert.
        [08.08.2021 19:02.42.979] [LOG]   Initializing new module helper ...
        [08.08.2021 19:02.42.980] [LOG]   Module helper loaded: updatenotification
        [08.08.2021 19:02.42.982] [LOG]   No helper found for module: clock.
        [08.08.2021 19:02.42.985] [LOG]   No helper found for module: weather.
        [08.08.2021 19:02.42.987] [LOG]   All module helpers loaded.
        [08.08.2021 19:02.42.989] [ERROR] App threw an error during load
        [08.08.2021 19:02.42.992] [ERROR] Error: ENOENT: no such file or directory, open
            at Object.openSync (fs.js:466:3)
        Tried running npm install ENOENT but that’s apparently not a thing.
          maddmurph @DJBOOB66
          @djboob66 Weird, it’s right in the config.js on the mirror. Good catch though.
            sdetweil @maddmurph
            @maddmurph weird a dozen people have done this successfully…
            also npm install request
            • Z Offline
              Zwirbel
              In my case, in the error massage it said that also rrule-alt was missing, so I did a “npm install rrule-alt” to get it working again.
                sdetweil @Zwirbel
                @zwirbel bingo. nice work.
                  maddmurph @sdetweil
                  @sdetweil looks like I had https set to True and that was causing an issue in addition to the other installs needed.
                  Thanks for your help!
