    Mirror goes to black after adding MMM-CalendarWeek
    11 Posts 4 Posters 5.0k Views 4 Watching
      maddmurph
      I was having a ton of issues with my Mirror, so I deleted everything and started over. In the default mode it works fine. I have the clock and the weather.
      Now I have installed MMM-CalendarWeek (git cloned, npm install, etc) and the screen goes to black. npm run config:check doesn’t show any errors but it’s still not working.
                              module: "MMM-CalendarWeek",
                              position: "lower_third",
                                      calendars:[
                                              url: "https://calendar.google.com/calendar/ical/secretGooglecode"
      Any help would be appreciated.
        sdetweil @maddmurph
        @maddmurph look at theessages where u start mm.
        you will probably see a message
        module not found
        M 1 Reply Last reply
          maddmurph @sdetweil
          [08.08.2021 15:39.45.829] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
          Require stack:
          - /home/pi/MagicMirror/modules/MMM-CalendarWeek/node_helper.js
          So I’m guessing this means the url isn’t valid, but I copied the secret .ical address right from google. What am I missing?
            DJBOOB66
            recheck your config you may mistakes" ],"
                                calendars:[
              sdetweil @maddmurph
              @maddmurph the valid-url and request modules were removed from mm in 2.16 as request has a security issue and will not be fixed.
              we’ve found quite a few modules that did not document the libraries they used, oops
              so to fix near term
              npm install valid-url
              the module is still broken and next mm install this will fail again
                maddmurph @sdetweil
                I did that and now nothing works. I get this error
                [08.08.2021 19:02.42.973] [ERROR] WARNING! Could not find config file. Please create one. Starting with default configuration.
                [08.08.2021 19:02.42.976] [LOG]   Loading module helpers ...
                [08.08.2021 19:02.42.977] [LOG]   No helper found for module: alert.
                [08.08.2021 19:02.42.979] [LOG]   Initializing new module helper ...
                [08.08.2021 19:02.42.980] [LOG]   Module helper loaded: updatenotification
                [08.08.2021 19:02.42.982] [LOG]   No helper found for module: clock.
                [08.08.2021 19:02.42.985] [LOG]   No helper found for module: weather.
                [08.08.2021 19:02.42.987] [LOG]   All module helpers loaded.
                [08.08.2021 19:02.42.989] [ERROR] App threw an error during load
                [08.08.2021 19:02.42.992] [ERROR] Error: ENOENT: no such file or directory, open
                    at Object.openSync (fs.js:466:3)
                Tried running npm install ENOENT but that’s apparently not a thing.
                  maddmurph @DJBOOB66
                  @djboob66 Weird, it’s right in the config.js on the mirror. Good catch though.
                    sdetweil @maddmurph
                    @maddmurph weird a dozen people have done this successfully…
                    also npm install request
                    • Z
                      Zwirbel
                      In my case, in the error massage it said that also rrule-alt was missing, so I did a “npm install rrule-alt” to get it working again.
                        sdetweil @Zwirbel
                        @zwirbel bingo. nice work.
                          maddmurph @sdetweil
                          @sdetweil looks like I had https set to True and that was causing an issue in addition to the other installs needed.
                          Thanks for your help!
