    Mirror goes to black after adding MMM-CalendarWeek
    11 Posts 4 Posters 4.1k Views 4 Watching
      sdetweil @maddmurph
      @maddmurph look at theessages where u start mm.
      you will probably see a message
      module not found
        maddmurph @sdetweil
        [08.08.2021 15:39.45.829] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
        Require stack:
        - /home/pi/MagicMirror/modules/MMM-CalendarWeek/node_helper.js
        So I’m guessing this means the url isn’t valid, but I copied the secret .ical address right from google. What am I missing?
          DJBOOB66
          recheck your config you may mistakes" ],"
                      module: "MMM-CalendarWeek",
                      position: "lower_third",
                              calendars:[
                                      url: "https://calendar.google.com/calendar/ical/secretGooglecode"
            sdetweil @maddmurph
            @maddmurph the valid-url and request modules were removed from mm in 2.16 as request has a security issue and will not be fixed.
            we’ve found quite a few modules that did not document the libraries they used, oops
            so to fix near term
            npm install valid-url
            the module is still broken and next mm install this will fail again
              maddmurph @sdetweil
              I did that and now nothing works. I get this error
              [08.08.2021 19:02.42.973] [ERROR] WARNING! Could not find config file. Please create one. Starting with default configuration.
              [08.08.2021 19:02.42.976] [LOG]   Loading module helpers ...
              [08.08.2021 19:02.42.977] [LOG]   No helper found for module: alert.
              [08.08.2021 19:02.42.979] [LOG]   Initializing new module helper ...
              [08.08.2021 19:02.42.980] [LOG]   Module helper loaded: updatenotification
              [08.08.2021 19:02.42.982] [LOG]   No helper found for module: clock.
              [08.08.2021 19:02.42.985] [LOG]   No helper found for module: weather.
              [08.08.2021 19:02.42.987] [LOG]   All module helpers loaded.
              [08.08.2021 19:02.42.989] [ERROR] App threw an error during load
              [08.08.2021 19:02.42.992] [ERROR] Error: ENOENT: no such file or directory, open
                  at Object.openSync (fs.js:466:3)
              Tried running npm install ENOENT but that’s apparently not a thing.
                maddmurph @DJBOOB66
                @djboob66 Weird, it’s right in the config.js on the mirror. Good catch though.
                  sdetweil @maddmurph
                  @maddmurph weird a dozen people have done this successfully…
                  also npm install request
                  • Z Offline
                    Zwirbel
                    In my case, in the error massage it said that also rrule-alt was missing, so I did a “npm install rrule-alt” to get it working again.
                      sdetweil @Zwirbel
                      @zwirbel bingo. nice work.
                        maddmurph @sdetweil
                        @sdetweil looks like I had https set to True and that was causing an issue in addition to the other installs needed.
                        Thanks for your help!
