    No such file or directory
    3 Posts 2 Posters 912 Views 2 Watching
    • delta 1D
      delta 1
      Hey, guys, I’m new to the MM project but I got everything up and running, but I’ve been trying to install some modules and so far none has worked for me I currently trying to install the screencast module I’ve been getting ( -bash: cd: MMM-Screencast: No such file or directory ) whenever I run the, cd MMM-Screencast command but I notice when I check the magic mirror folder the (MMM-screencast) folder is not in the module folder it is just there in the magic mirror folder with everything else .coding error.PNG
      • A
        aarish
        It is case sensitive. The module is called MMM-ScreenCast but you forgot to capitalize the C in a cast so instead of doing cd MMM-Screencast do MMM-ScreenCast
        delta 1D 1 Reply Last reply
        • delta 1D
          delta 1 @aarish
          @aarish thanks bro that worked
