    Change current CSS with a module?
    Scheduled Pinned Locked Moved Solved Development
    11 Posts 2 Posters 3.5k Views 2 Watching
      MacG @MacG
      I don’t have the knowledge for plan A. I tried it, but it doesn’t affect the display and it doesn’t show up on MMM-RemoteControl in the Edit View list. What is necessary though.
      I can change or add a few lines of code, but I can’t rewrite a module. The gradient stays as it is.
      to disable the following class
      .MMM-BackgroundSlideshow .gradient background-image: radial-gradient(at center top, rgba(0, 0, 0, 0) 45%, rgba(0, 0, 0, 0.45) 85%) !important;
      Module.register("MMM-BGSs-NoGradient", {
      	// define variables used by module, but not in config data
      	// some_variable:  true,
      	// some_other_variable: "a string",
      	// holder for config info from module_name.js
      	config:null,
      	init: function(){
      		Log.log(this.name + " is in init!");
      	start: function(){
      		Log.log(this.name + " is starting!");
      	loaded: function(callback) {
      		Log.log(this.name + " is loaded!");
      		callback();
      	// return list of stylesheet files to use if any
      	getStyles: function() {
      		return 	[
      			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
      			//'script.css', // will try to load it from the vendor folder, otherwise it will load is from the module folder.
      			//'font-awesome.css', // this file is available in the vendor folder, so it doesn't need to be avialable in the module folder.
      			//this.file('anotherfile.css'), // this file will be loaded straight from the module folder.
      			//'https://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/css/bootstrap.min.css',  // this file will be loaded from the bootstrapcdn servers.
      	// messages received from other modules and the system (NOT from your node helper)
      	// payload is a notification dependent data structure
      	notificationReceived: function(notification, payload, sender) {
      		// once everybody is loaded up
      		if(notification==="ALL_MODULES_STARTED"){
      			// send our config to our node_helper
      			this.sendSocketNotification("CONFIG",this.config)
      		if (sender) {
      			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
      		} else {
      			Log.log(this.name + " received a system notification: " + notification);
      	// system notification your module is being hidden
      	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
      	suspend: function(){
      	// system notification your module is being unhidden/shown
      	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
      	resume: function(){
      	// this is the major worker of the module, it provides the displayable content for this module
      	getDom: function() {
      		wrapper.className = 'bgss-nogradient_container';
      		// if user supplied message text in its module config, use it
      		if(this.config.hasOwnProperty("message")){
      			// using text from module config block in config.js
      			wrapper.innerHTML = this.config.message;
      		else{
      		// use hard coded text
      			wrapper.innerHTML = " ";
      		// change css
      		Object.assign(
      			document.querySelector('.MMM-BackgroundSlideshow .gradient').style,
      				display: none
      		// pass the created content back to MM to add to DOM.
      		return wrapper;
