    MagicMirror Doesn't Start
    4 Posts 2 Posters 943 Views 2 Watching
      droidus
      I am receiving this error:
      pi@raspberrypi:~/MagicMirror_scripts $ ./run-start.sh
      grep: config/config.js: No such file or directory
      internal/modules/cjs/loader.js:892
        throw err;
      Error: Cannot find module '/home/pi/MagicMirror_scripts/serveronly'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:889:15)
          at Function.Module._load (internal/modules/cjs/loader.js:745:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Starting chromium browser now, have patience, it takes a minute
      The browser shows a “This site can’t be reached” page.
        sdetweil @droidus
        @droidus said in MagicMirror Doesn't Start:
        why are u trying to run it?
        its suppoosed to be started by package.json
        “start”:
        whan its a pi0 or electron is not installed…
        IF you use my script to install MM…
        u don’t download my stuff, just copy/paste the one line for each function
          sdetweil
          install
          to execute the install script, cut/paste this line into the terminal window on your device (I can't say PI, cause it works in a lot of other places too)
          upgrade
          this works on Mac as well, cut/paste this line into the terminal window on your device
            sdetweil @droidus
            @droidus IF it was needed, the install script would have changed
            package.json
            		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
            to
            		"start": "./run-start.sh $1",
