    Help! - Adding and Changing Modules - Newbe
    14 Posts 6 Posters 4.1k Views 5 Watching
    • BKeyportB Offline
      BKeyport Module Developer @PillarESci
      Using the Office 365 calendar should be easy.
      if you’re using a calendar that shows up on https://outlook.live.com/, you can get an ICS to the file easily, by going to https://outlook.live.com/calendar/0/options/calendar/SharedCalendars.
      From there, use the publish links to grab the ICS file and path for MM.
      • BKeyportB Offline
        @sdetweil You know, not including the ending comma (optional, I know) is gonna mess 'em up when they go to add more than one module…
          sdetweil @BKeyport
          @bkeyport use MMM-Config!
          • BKeyportB Offline
            @sdetweil True. :)
