    Help! - Adding and Changing Modules - Newbe
    14 Posts 6 Posters 5.6k Views 5 Watching
      PillarESci @sdetweil
      @sdetweil Thank you! These are helpful!
        PillarESci @MMRIZE
        @mmrize Thanks for replying. Right now I’m trying to modify the weather module for my location (North Carolina instead of New York). I replaced the openweather ID and API key in the config file but when I start up Magic Mirror that module is stuck on “loading” so I am assuming I’ve done something wrong. At a minimum would just like to get that working, but honestly, I’d like to replace it with a more robust weather module. When I look at the module portion of this website, I see all these settings you can do but have no idea how to insert them into the config file.
        Other items I’d like to learn how to do
        • try to have the calendar pull from my work, Office 365 calendar (working on a method I found through here were I import it into Google Calendar and then go from there)
        • add modules (haven’t figured out which ones yet, but the link provided below on adding modules looks to be helpful)
        • how to set-up the Raspberry Pi to autoboot Magic Mirror so I can put the Raspberry Pi in the mirror and try it out. I found the directions on how to do that, however, what isn’t clear is how I stop that? If I remove the raspberry pi to add modules or make changes, how do I get out of the Magic Mirror (control Q?).
        cowboysdudeC M S BKeyportB 5 Replies Last reply Reply Quote 0
        • cowboysdudeC Offline
          cowboysdude Module Developer @PillarESci
          @pillaresci 1st rule of config.js club.
          Always make a backup of your config.js LOL
          Does it work before you change and put your own info in the weather module?
            MMRIZE @PillarESci
            @pillaresci
            You can post your configuration (entire contents or just the parts of weather module). We can check what was wrong.
            The first to do is find the iCal(*.ics) feed URL of your target calendar service.
            Usually, module developers provide how-to-install (README.md) document in their module repository.
            It depends on what method you use. I assume you are using pm2 to manage MM’s running. You can connect MM remotely. After connection, type pm2 stop all, it will stop current MM’s execution.
              sdetweil @PillarESci
              @pillaresci every module config setup is the same
                       module:'modulename',
                       position:'where to put it',
                       disabled: true or false
                       config:  {
                           the options that the module describes
                            one per line
                             keyword: value
                @pillaresci if you are using a keyboard on the pi, you can minimize mm with alt-spacebar, n
                (same as on windows to minimize a full screen app)
                • BKeyportB Offline
                  BKeyport Module Developer @PillarESci
                  Using the Office 365 calendar should be easy.
                  if you’re using a calendar that shows up on https://outlook.live.com/, you can get an ICS to the file easily, by going to https://outlook.live.com/calendar/0/options/calendar/SharedCalendars.
                  From there, use the publish links to grab the ICS file and path for MM.
                  • BKeyportB Offline
                    @sdetweil You know, not including the ending comma (optional, I know) is gonna mess 'em up when they go to add more than one module…
                      sdetweil @BKeyport
                      @bkeyport use MMM-Config!
                      • BKeyportB Offline
                        @sdetweil True. :)
