    Manual installation error
    10 Posts 2 Posters 1.6k Views 2 Watching
    • D
      dodo
      Hi all,
      New to MagicMirror and this is my first attempt to run it.
      It is installed on a Rpi 3B+ with the latest Raspberry OS (2021-05-07-raspios-buster-armhf) and I used the manual installation method as per instructions.
      When I try to run MM, this is what I get:
      alex@MagicMirror:~/MagicMirror $ npm run start
      > magicmirror@2.16.0 start /home/alex/MagicMirror
      > electron js/electron.js
      [13.09.2021 12:34.16.087] [LOG]   Starting MagicMirror: v2.16.0
      [13.09.2021 12:34.16.096] [LOG]   Loading config ...
      [13.09.2021 12:34.16.110] [LOG]   Loading module helpers ...
      [13.09.2021 12:34.16.114] [LOG]   No helper found for module: alert.
      [13.09.2021 12:34.16.436] [LOG]   Initializing new module helper ...
      [13.09.2021 12:34.16.439] [LOG]   Module helper loaded: updatenotification
      [13.09.2021 12:34.16.441] [LOG]   No helper found for module: clock.
      [13.09.2021 12:34.16.700] [LOG]   Initializing new module helper ...
      [13.09.2021 12:34.16.702] [LOG]   Module helper loaded: calendar
      [13.09.2021 12:34.16.704] [LOG]   No helper found for module: compliments.
      [13.09.2021 12:34.16.706] [LOG]   No helper found for module: weather.
      [13.09.2021 12:34.16.749] [LOG]   Initializing new module helper ...
      [13.09.2021 12:34.16.750] [LOG]   Module helper loaded: newsfeed
      [13.09.2021 12:34.16.752] [LOG]   All module helpers loaded.
      [13.09.2021 12:34.16.913] [LOG]   Starting server on port 8080 ...
      [13.09.2021 12:34.16.942] [LOG]   Server started ...
      [13.09.2021 12:34.16.944] [LOG]   Connecting socket for: updatenotification
      [13.09.2021 12:34.16.946] [LOG]   Connecting socket for: calendar
      [13.09.2021 12:34.16.947] [LOG]   Starting node helper for: calendar
      [13.09.2021 12:34.16.949] [LOG]   Connecting socket for: newsfeed
      [13.09.2021 12:34.16.950] [LOG]   Starting node helper for: newsfeed
      [13.09.2021 12:34.16.952] [LOG]   Sockets connected & modules started ...
      /home/alex/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.16.0 start: `electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.16.0 start script.
      npm ERR!     /home/alex/.npm/_logs/2021-09-13T11_34_17_115Z-debug.log
      Initially I had a different error and I thought I’d follow the troubleshooting instructions saying to change
      "start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
      to
      "start": "node_modules/.bin/electron js/electron.js",
      which I did. Now I am getting the above error.
      I checked the debug log and here’s what it contains:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'start' ]
      2 info using npm@6.14.15
      3 info using node@v14.17.6
      5 info lifecycle magicmirror@2.16.0~prestart: magicmirror@2.16.0
      6 info lifecycle magicmirror@2.16.0~start: magicmirror@2.16.0
      7 verbose lifecycle magicmirror@2.16.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.16.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/alex/MagicMirror/node_modules/.bin:/usr/local/sb$
      9 verbose lifecycle magicmirror@2.16.0~start: CWD: /home/alex/MagicMirror
      10 silly lifecycle magicmirror@2.16.0~start: Args: [ '-c', 'electron js/electron.js' ]
      11 silly lifecycle magicmirror@2.16.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.16.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.16.0 start: `electron js/electron.js`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:400:28)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:400:28)
      13 verbose stack     at maybeClose (internal/child_process.js:1055:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
      14 verbose pkgid magicmirror@2.16.0
      15 verbose cwd /home/alex/MagicMirror
      16 verbose Linux 5.10.60-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "start"
      18 verbose node v14.17.6
      19 verbose npm  v6.14.15
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.16.0 start: `electron js/electron.js`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.16.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      I don’t quite understand what this means. Anyone have any idea how to fix this please?
      • D
        dodo @sdetweil
        @sdetweil Yes, full version with desktop.
        Just deleted the whole MagicMirror folder and run your script.
        It works PERFECTLY!
        I don’t know why this isn’t the default was of installation, it’s sooooo easier!
        Thank you for your assistance, much appreciated.
        • D
          dodo @dodo
          Perhaps I should also mention that during the installation process, I noticed a warning saying:
          “this version of npm is compatible with lockfileVersion@1 but package-lock.json was generated for lockfileVersion@2”
          I don’t know if this helps someone but I thought I’d mention it just in case.
            sdetweil @dodo
            @dodo you are using the full desktop version of buster, correct?
            you should see the temples on the desktop before installing MagicMirror
              sdetweil @dodo
              @dodo you could also use my installation script
              see https://github.com/sdetweil/MagicMirror_scripts
              • D
                dodo @sdetweil
                @sdetweil Thank you for that, I’ll try it.
                Do I need to uninstall everything and then run your scripts?
                Also, I have installed MM using the user “alex” instead of “pi”. Do I need to change anything in your scripts before I run them?
                  sdetweil @dodo
                  @dodo just rename the MagicMirror folder to some other name
                  u only need to run the install script
                  it should handle different user name just fine
                  u didn’t answer about the os version. needs to be full with graphical desktop
                  • D
                    dodo @sdetweil
                    It works PERFECTLY!
                      sdetweil @dodo
                      @dodo said in Manual installation error:
                      it’s listed as one of the alternative ways
                      • D
                        dodo @sdetweil
                        @sdetweil Yeah, I know. It should be the opposite, this method should be the default for dummies like myself!
                          sdetweil @dodo
                          not dummy, just inexperienced…
                          my script was from the base, but it wasn’t possible to update as frequently as we all needed.
                          my intent is to get you up and running.
                          a year from now you will know a lot more
