    How to port/create a sweep clock module from existing html/js/css code
    12 Posts 4 Posters 2.8k Views 4 Watching
      sdetweil
      css info
      https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
      developing module specs
      https://docs.magicmirror.builders/development/introduction.html#general-advice
      • N Offline
        nirvana @sdetweil
        @sdetweil ok thank you very much
        will go through them and try to build the module
        • N Offline
          nirvana @sdetweil
          @sdetweil It is working but only showing the svg image of the clock face without hour/minute hands.
          I think the time elements are not called using moment.js
          The script uses new Date() to get the time. how to tell scipt.js to use moment.js call to get the time instead
            sdetweil @nirvana
            @nirvana Date should work.
            make sure the css labels line up w the code
            did u pass the css file back on getStyles?
            you should be able to see all that in the developers window
            ctrl-shift-i
            elements tab will let u see the dom and elements
            console any messages
            source the code for your module, and u can step thru it
            see
            https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1631634934084
            • N Offline
              nirvana @sdetweil
              @sdetweil I tried but not working, I think something is missing.
              Anyways, I am just using the default analog clock for now. Thanks for all help. I may try it sometime later. u1.png u2.png
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @nirvana
                @nirvana yeh, the code needs to change
                window.addEventListener('DOMContentLoaded', () => {
                    firstMinute()
                this will never occur, cause it happened a long time ago in MM web page being loaded
                u could use notification of DomObjectsCreated to call firstMinute()
                I don’t know if this is right in MM
                document.addEventListener("visibilitychange", () => {
                its the difference between having the whole page to yourself and sharing the space with other modules
                • mumblebajM Offline
                  mumblebaj Module Developer @nirvana
                  @nirvana You can have a go at my module I created for this.
                  MMM-SweepClock
                  Works fine. Any issues please raise on the modules git page and I will have a look for you.
                  • N Offline
                    nirvana @mumblebaj
                    @mumblebaj Works perfectly! Thanks for your time!
                    I also tried but could not make this work, but edited the default MM clock to contain sweep seconds.
