    How to port/create a sweep clock module from existing html/js/css code
    12 Posts 4 Posters 2.8k Views 4 Watching
    • N Offline
      nirvana
      The code for animated clock is here: https://github.com/manuelmeister/Swiss-Railway-Clock
      This is the awesome Swiss railway clock found in all Swiss railway stations. Please let me know if there is an easy way to create a module out of this to display the clockface with sweeping seconds hand.
      It looks like this: http://sbb.meister.io/
      • mumblebajM Offline
        mumblebaj Module Developer @nirvana
        @nirvana You can have a go at my module I created for this.
        MMM-SweepClock
        Works fine. Any issues please raise on the modules git page and I will have a look for you.
          sdetweil @nirvana
          @nirvana should be very easy.
          the index.html body content becomes the return from getDom()
          the script is returned from getScripts()
          and the css is returned from getStyles()
          with a slight mod to add the module name in front
          use my sample module to start
          https://github.com/sdetweil/SampleModule
          • N Offline
            nirvana @sdetweil
            @sdetweil Thanks for the info.
            I have problems adding index.html to getDom() wrapper, how to add all elements correctly
            The syntax is different I suppose from html
            I just started html and js, so don’t know much about this languages.
              sdetweil @nirvana
              @nirvana just the stuff in the body tag, not all of index.html
              <div>
              </div>
              https://stackoverflow.com/questions/805107/creating-multiline-strings-in-javascript
              so, all you would have to do is copy/paste the body contents and wrap it in backtics (shifted to left on the number 1 key)
              getDom(), MUST always return SOMETHING (some html element)
              most of the examples return an empty div, when there is not yet anything to display (or they are hidden)
                css info
                https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
                developing module specs
                https://docs.magicmirror.builders/development/introduction.html#general-advice
                • N Offline
                  nirvana @sdetweil
                  @sdetweil ok thank you very much
                  will go through them and try to build the module
                  • N Offline
                    nirvana @sdetweil
                    @sdetweil It is working but only showing the svg image of the clock face without hour/minute hands.
                    I think the time elements are not called using moment.js
                    The script uses new Date() to get the time. how to tell scipt.js to use moment.js call to get the time instead
                      sdetweil @nirvana
                      @nirvana Date should work.
                      make sure the css labels line up w the code
                      did u pass the css file back on getStyles?
                      you should be able to see all that in the developers window
                      ctrl-shift-i
                      elements tab will let u see the dom and elements
                      console any messages
                      source the code for your module, and u can step thru it
                      see
                      https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1631634934084
                      • N Offline
                        nirvana @sdetweil
                        @sdetweil I tried but not working, I think something is missing.
                        Anyways, I am just using the default analog clock for now. Thanks for all help. I may try it sometime later. u1.png u2.png
                        S mumblebajM 2 Replies Last reply Reply Quote 0
                          sdetweil @nirvana
                          @nirvana yeh, the code needs to change
                          window.addEventListener('DOMContentLoaded', () => {
                              firstMinute()
                          this will never occur, cause it happened a long time ago in MM web page being loaded
                          u could use notification of DomObjectsCreated to call firstMinute()
                          I don’t know if this is right in MM
                          document.addEventListener("visibilitychange", () => {
                          its the difference between having the whole page to yourself and sharing the space with other modules
                            MMM-SweepClock
                            • N Offline
                              nirvana @mumblebaj
                              @mumblebaj Works perfectly! Thanks for your time!
                              I also tried but could not make this work, but edited the default MM clock to contain sweep seconds.
