    Calendar shows hours left at holidays
    3 Posts 2 Posters 1.0k Views 2 Watching
    • M
      MacG
      I use the default calendar to display the holidays (“Feiertage”) here in Germany. For example, today is one and is displayed that it is “Noch 14 Stunden” (14 hours left). But there I would like to have the display “Heute” (today) or the date. Also because the 14 hours are calculated using UTC time and not the local time.
      I can’t find anything suitable in the calendar configuration. Does anyone know the solution?
        sdetweil @MacG
        @macg I think that is getRelative:0
        • M
          MacG @sdetweil
          @sdetweil The timeFormat is relative by default. I used getRelative: 0 without changes at the display. Also with timeFormat: “absolute” only the display changed since hours instead of remaining hours. But with an additional urgency: 0 it works. Thank you, Sam!
          Oh yes, an adjustment of the format was also necessary. The dateFormat was no longer applied.
          Before:
          	header: "Feiertage",
          		dateFormat: "D. MMM",
          		displaySymbol: false,
          		broadcastEvents: false,
          		hideTime: true,
          		fadePoint: 0.05,
          		fetchInterval: 24 * 60 * 60 * 1000,    // 1 day
          			maximumEntries: 3,
          			url: "webcal://localhost:8080/modules/calendar/feiertage.ics"
          After changes:
          		hideTime: true,
          		timeFormat: "absolute",
          		getRelative: 0,
          		urgency: 0,
          		fullDayEventDateFormat: "D. MMM",
          		nextDaysRelative: true,   // shows Tomorrow and Today
          		fadePoint: 0.05,
          			maximumEntries: 3,
          I can well do without the “today”.
          Edit: The “Today” comes with the setting: nextDaysRelative: true.
