    show local webpages using iframe
    8 Posts 3 Posters 2.3k Views 3 Watching
    • G Offline
      gkchimz
      Can someone help me with how i structure the path and where i store the webpages so that i can use an iframe module to show a webpage i have saved locally.
      I have tried - MMM-SmartWebDisplay and placed the files in the MagicMirror folder, but this did not work.
      Many thanks
        sdetweil @gkchimz
        @gkchimz the MM web server root is MagicMirror:port_from_config.js SO
        http://localhost:8080/somefile.html (in the MM folder)
        http://localhost:8080/modules/somemodulename/somefile.html (in some module folder)
        • G Offline
          gkchimz @sdetweil
          I have tried both :
          "http://192.168.1.31:8080/modules/mymote/mymote.html"
          and
          "http://localhost:8080/modules/mymote/mymote.html"
          These work when using a browser but MM displays the below error in the console.
          Refused to display 'http://192.168.1.31:8080/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
            sdetweil @gkchimz
            @gkchimz what are your address and ipWhitelist setting in config.js?
            • thgmirrorT Offline
              thgmirror
              @gkchimz
              Store your html direct in the modules-folder and add it as URL for MMM-SmartWebDisplay like
              url: [“/modules/myhtml.html”],
              S G 2 Replies Last reply Reply Quote 0
                sdetweil @thgmirror
                @thgmirror
                that would be, for him
                url: ["/modules/mymote/myhtml.html"],
                • G Offline
                  gkchimz @sdetweil
                  var config = {
                    address: "0.0.0.0",
                  ipWhitelist: [],
                    electronOptions: {
                      webPreferences: {
                        webviewTag: true
                    port: 8080,
                  • G Offline
                    gkchimz @thgmirror
                    @thgmirror - Thank you very much for your help. This now works.
