    MM not starting anymore | new SD-Card
    3 Posts 2 Posters 889 Views 3 Watching
      Schmaniel
      My MM (after only like 2/3months!) is not starting anymore and now I need a new SD-Card.
      I tried to boot my RPI 3B with an SSD, but I wasn’t able to get it to work.
      I previously had this card: https://www.amazon.de/dp/B073JYVKNX - what should I get for one?
      Is it normal, that the SD Card broke so fast?
      Oh and yeah… can I possible safe my image somehow? - I don’t want to do this 10hour software thing again :c
        sdetweil @Schmaniel
        @schmaniel cards are fragile… never power off before shutdown.
        don’t know if u can save anything
        use my install script after building new OS card
        see https://github.com/sdetweil/MagicMirror_scripts
          Schmaniel @sdetweil
          @sdetweil the installation of the mm is not that hard, but the configuration from all the modules was kind of :/
          especially I had rewritten something ^^
          I’m trying to get it with an ssd to work, so I don’t have this problem anymore.
          I will test your script anyways, thank you!
