    First four-five modules showing, the others are not
    5 Posts 3 Posters 696 Views 3 Watching
    • T Offline
      techlady
      I am running Magic Mirror- the latest version on a Raspberry PI 4. It was working fine for the last couple of weeks, but it stopped working correctly. The first few modules show, but no modules after them shows. I ran dev console. This is the message I get each time I run it: main.js:36 Uncaught TypeError: Cannot read property 'appendChild' of undefined at main.js:36 at Array.forEach (<anonymous>) at createDomObjects (main.js:20) at Object.modulesStarted (main.js:502) at startModules (loader.js:55) at loader.js:38 at HTMLLinkElement.stylesheet.onload (loader.js:210)
      I also get this warning:
      Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
          Policy set or a policy with "unsafe-eval" enabled. This exposes users of
          this app to unnecessary security risks.
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
      This warning will not show up
      once the app is packaged.
      (anonymous)	@	electron/js2c/renderer_init.js:111
      Any help you can give will be appreciated.
      • S Away
        sdetweil @techlady
        @techlady I would start by disabling each module one at a time
        add
          disabled: true,
        after the module:
        line
        and restart mm
        it looks like a module did not return content from it’s getDom() routine
        • T Offline
          techlady @sdetweil
          @sdetweil Thank you very much. That did the trick.
          • S Away
            sdetweil @techlady
            @techlady which module was the villian?
            • T Offline
              techlady @sdetweil
              @sdetweil Luckily, it was the very next one- the default compliments module. I haven’t taken the time to see what is wrong with it. Since everything works now, I’ll leave it disabled until I have time to figure it out.
