    MMM-MQTTBridge not working
    5 Posts 3 Posters 1.5k Views 3 Watching
    • G
      gkchimz
      Hi I am trying to set this up for the first time. This is the error message i get when i start mm:
      Is anyone able to advise me please. Thanks
      | [30.09.2021 17:16.03.787] [ERROR] 0|mm | TypeError: Cannot read property 'length' of undefined 0|mm | at Class.connectMqtt (/home/pi/MagicMirror/modules/MMM-MQTTbridge/node_helper.js:54:36) 0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-MQTTbridge/node_helper.js:67:14) 0|mm | at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11) 0|mm | at Socket.emit (events.js:315:20) 0|mm | at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22) 0|mm | at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:428:39 0|mm | at processTicksAndRejections (internal/process/task_queues.js:79:11)
      M 1 Reply Last reply
      • M
        MMRIZE @gkchimz
        @gkchimz
        It seems your mqttDictionaries wrong.
        G 1 Reply Last reply
        • G
          gkchimz @MMRIZE
          @mmrize
          Thank you for the fast response. Here is the dictionary i am using
          var mqttHook = [
              mqttTopic: "home",
              mqttPayload: [
                  payloadValue: "ASSISTANT_LISTEN",
                  mqttNotiCmd: ["Command1"]
                  payloadValue: "None",
                  mqttNotiCmd: ["Command2"]
              mqttTopic: "myhome/test2",
              mqttPayload: [
                  payloadValue: "",
          var mqttNotiCommands = [
              commandId: "Command1",
              notiID: "ASSISTANT_LISTEN",
              notiPayload: 'BLABLABLA-1'
              commandId: "Command2",
              notiPayload: 'kjkjkj'
          G M 2 Replies Last reply
          • G
            gkchimz @gkchimz
            @gkchimz
            config.js
            	module: 'MMM-MQTTbridge',
            	disabled: false,
            	position: 'middle_center',
            		mqttServer: "mqtt://username:password@192.168.0.99:1883",
            		mqttConfig:
            			listenMqtt: true,
            			interval: 300000,
            		notiConfig:
            			listenNoti: true,
            			ignoreNotiId: ["CLOCK_MINUTE", "NEWS_FEED"],
            			ignoreNotiSender: ["system", "NEWS_FEED"],
            		// set "NOTIFICATIONS -> MQTT" dictionary at /dict/notiDictionary.js
            		// set "MQTT -> NOTIFICATIONS" dictionary at /dict/mqttDictionary.js
            • M
              MMRIZE @gkchimz
              @gkchimz
              Have you set the last line of dictionary?
                module.exports = { mqttHook,  mqttNotiCommands};
