    v2.17.0
    Scheduled Pinned Locked Moved MagicMirror
    2 Posts 1 Posters 4.1k Views 2 Watching
    • MichMichM
      MichMich
      [2.17.0] - 2021-10-01
      https://github.com/MichMich/MagicMirror/releases/tag/v.2.17.0
      Special thanks to the following contributors: @apiontek, @eouia, @jupadin, @khassel and @rejas.
      Added
      • Added showTime parameter to clock module for enabling/disabling time display in analog clock.
      • Added custom electron switches from user config (config.electronSwitches).
      • Added unit tests for updatenotification module.
      Updated
      • Bump electron to v13 (and spectron to v15) and update other dependencies in package.json.
      • Refactor test configs, use default test config for all tests.
      • Updated github templates.
      • Actually test all js and css files when lint script is run.
      • Update jsdocs and print warnings during testing too.
      • Update weathergov provider to try fetching not just current, but also foreacst, when API URLs available.
      • Refactored clock layout.
      • Refactored methods from weatherproviders into weatherobject (isDaytime, updateSunTime).
      • Use of logger.js in jest tests.
      • Run prettier over all relevant files.
      • Move tests needing electron in new category electron, use server only mode in e2e tests.
      • Update dependencies in package.json.
      Fixed
      • Fix undefined error with ignoreToday option in weather module (#2620).
      • Fix time zone correction in calendar module when the date hour is equal to the time zone correction value (#2632).
      • Fix black cursor on startup when using electron.
      • Fix update notification not working for own repository (#2644).
      Reply Quote 1
      • MichMichM MichMich locked this topic on
      • MichMichM
        MichMich
        [2.17.1] - 2021-10-01
        https://github.com/MichMich/MagicMirror/releases/tag/v2.17.1
        Fixed
        • Fixed error when accessing letsencrypt certificates.
        Reply Quote 1
