    Updated to 2.17 but MM not launching
    28 Posts 5 Posters 9.4k Views 5 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sdetweil
      Hi Sam, i have to do this for 11 modules :grinning_face_with_big_eyes: …but that’s not the problem it takes a little time…but do I have to do all this again on every next MM Update?:dizzy_face:
      Greeting from Germany
      StoffbeuteluweS S 2 Replies Last reply Reply Quote 0
        Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
        The Mirror works but there are some errors…
        [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'cat' of module exports inside circular dependency
        (Use `Electron --trace-warnings ...` to show where the warning was created)
        [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'cd' of module exports inside circular dependency
        [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'chmod' of module exports inside circular dependency
        [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'cp' of module exports inside circular dependency
        [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'dirs' of module exports inside circular dependency
        [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'pushd' of module exports inside circular dependency
        [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'popd' of module exports inside circular dependency
        [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'echo' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'tempdir' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'pwd' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'exec' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'ls' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'find' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'grep' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'head' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'ln' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'mkdir' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'rm' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'mv' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'sed' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'set' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'sort' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'tail' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'test' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'to' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'toEnd' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'touch' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'uniq' of module exports inside circular dependency
        [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'which' of module exports inside circular dependency
          sdetweil @Stoffbeuteluwe
          @stoffbeuteluwe said in Updated to 2.17 but MM not launching:
          if you do the
          npm init
          in the module folder before npm install request (or whatever is missing)
          then that library will be loaded in the module node_modules list
          if NOT, then it looks for the 1st node_modules folder up the directory tree , finds one under MagicMirror and installs the module there
          BUT…
          on the next update, npm will check and see that this library was not required by MM, and so delete it, (security, so someone can’t sneak libraries into the installed folder)…
          so… answer to your question is ‘maybe’…
            how did u do the upgrade?
            can u tell me
            node -v
            npm -v
            output?
            this version of electron needs node 14. my script does NOT upgrade node
            StoffbeuteluweS 2 Replies Last reply Reply Quote 0
              @sdetweil when I’m home from work I will tell you….thanks in advance
                @sdetweil Hi…
                git pull & npm install
                node -v v14.17.3
                npm -v 6.14.13
                  @stoffbeuteluwe ok, thx… did u use my upgrade script?
                  if not, I would go thru every module (not defaults) and look for package.json
                  if present, in the module folder I would
                  rm package-lock.json
                  rm -rf node_modules
                  npm install
                  to reload the dependencies based on the new MM.
                  (this is what my upgrade script does)
                  after that, I would disable one module at a time to find the culprit…
                    @sdetweil said in Updated to 2.17 but MM not launching:
                    npm install
                    Ok thank you Sam i will try…
                      @stoffbeuteluwe u could use my upgrade script with force
                      to accomplish the same thing
                      I would disable modules to find it first, and then check after redoing npm install
                        @sdetweil do you think the error came from a module?
                        • 2 / 3
