    Problem mmm-hue-lights, config file can not be loaded, check:config ok
    2 Posts 2 Posters 463 Views 2 Watching
    • L Offline
      Liz
      Hello,
      I am currently running in some problems setting up the hue-lights module.
      I accidently wiped my running mm2 installation and had to start from scratch.
      Before that it was running just fine with this module.
      If it is relevant I first pulled the module inside the “MagicMirror” folder and ran “npm run install” there.
      I then removed it again, navigated to the modules and pulled it there via git.
      I checked my hue developper account and my user is working
      I also checked the IP of my bridge because this had changed before when we had an power outage.
      I can ping the IP from my raspi.
      I already removed it from the modules folder and pulled it again via git.
      My mirror is up and running.
      As soon as I put the mmm-hue-lights module settings in the config I just get a black screen. The console gives me the following information and error messages:
      > magicmirror@2.17.1 start /home/pi/MagicMirror
      > ./run-start.sh $1
      [22.10.2021 10:11.05.418] [LOG]   Starting MagicMirror: v2.17.1
      [22.10.2021 10:11.05.430] [LOG]   Loading config ...
      [22.10.2021 10:11.05.443] [LOG]   Loading module helpers ...
      [22.10.2021 10:11.05.446] [LOG]   No helper found for module: alert.
      [22.10.2021 10:11.05.449] [LOG]   No helper found for module: clock.
      [22.10.2021 10:11.05.462] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
      Require stack:
      - /home/pi/MagicMirror/modules/mmm-hue-lights/node_helper.js
      [22.10.2021 10:11.05.464] [LOG]   Loading module helpers ...
      [22.10.2021 10:11.05.466] [LOG]   No helper found for module: alert.
      [22.10.2021 10:11.05.468] [LOG]   No helper found for module: clock.
      [22.10.2021 10:11.05.474] [ERROR] App threw an error during load
      [22.10.2021 10:11.05.480] [ERROR] Error: Cannot find module 'request'
      Require stack:
          at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
          at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (internal/modules/cjs/loader.js:732:27)
          at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
          at Module.require (internal/modules/cjs/loader.js:959:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/mmm-hue-lights/node_helper.js:2:15)
          at Module._compile (internal/modules/cjs/loader.js:1078:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
      [22.10.2021 10:11.05.486] [ERROR] Whoops! There was an uncaught exception...
      [22.10.2021 10:11.05.508] [ERROR] Error: Cannot find module 'request'
      Require stack:
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/mmm-hue-lights/node_helper.js',
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/js/electron.js',
          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          undefined
      my config of the module currently looks like this (I tried working without the additional settings) at the moment only the obligatory ones IP and user:
      		module: "mmm-hue-lights",
      		position: "top_left", // pick whichever position you want
      			bridgeIp: "xxxxxx",
      			user: "xxxx",
      			//updateInterval: 1000,
      			//initialLoadDelay: 0,
      			//displayType: "grid",
      		////	displayFilter: ["all"],
      			//minimalGrid: true,
      			//displayMode: "lights",
      			 ////... and whatever else configuration options you want to use
        JohnBachini
        https://forum.magicmirror.builders/topic/15778/black-screen-fix-in-2-16-and-later
