    after update MM does not start
    6 Posts 2 Posters 982 Views 2 Watching
    • V Offline
      voodoo-magic
      Hello everyone,
      after updating from version 2.16.0 to 2.17.1 with the script
      bash -c "$ (curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      MM no longer starts.
      Upgrade Log:
      Upgrade started - So Okt 31 19:49:33 CET 2021
      system is Linux archpi4 5.10.76-1-raspberrypi4-ARCH #1 SMP Thu Oct 28 14:06:17 UTC 2021 armv7l GNU/Linux
      the os is LSB Version: 1.4 Distributor ID: Arch Description: Arch Linux Release: rolling Codename: n/a
      user requested to apply changes
      doing test run = false
      Check current Node installation ...
      Node currently installed. Checking version number.
      Minimum Node version: v14.0.0
      Installed Node version: v16.11.1
      No Node.js upgrade necessary.
      Check current NPM installation ...
      NPM currently installed. Checking version number.
      Minimum npm version: V6.0.0
      Installed npm version: V7.24.2
      No npm upgrade necessary.
      remote name = origin
      upgrading from version 2.16.0 to 2.17.1
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is behind 'origin/master' by 166 commits, and can be fast-forwarded.
        (use "git pull" to update your local branch)
      Changes not staged for commit:
        (use "git add <file>..." to update what will be committed)
        (use "git restore <file>..." to discard changes in working directory)
      	modified:   package.json
      no changes added to commit (use "git add" and/or "git commit -a")
      there are 1 local files that are different than the master repo
         package.json
      save/restore files selection = y
      erasing lock files
      Arbeitsverzeichnis und Index-Status WIP on master: 26a76f80 Merge pull request #2607 from MichMich/develop gespeichert.
      test merge result rc='' , if empty, no conflicts
      executing merge, apply specified
      merge result rc= 0
       Updating 26a76f80..222a5f37 Fast-forward  .eslintrc.json
          3 +-  .github/CONTRIBUTING.md
          6 +-  .github/FUNDING.yml
          2 +-  .github/ISSUE_TEMPLATE.md
         10 +-  .github/PULL_REQUEST_TEMPLATE.md
         23 +-  .github/header.psd
        Bin 225118 -> 0 bytes  .github/workflows/automated-tests.yml
         37 +  .github/workflows/codecov-test-suites.yml
         14 +-  .github/workflows/enforce-changelog.yml
         14 +-  .github/workflows/node-ci.js.yml
         33 -  .husky/.gitignore
          1 -  .prettierignore
          4 -  CHANGELOG.md
         39 +  config/config.js.sample
          3 +-  index.html
          2 +-  js/app.js
          4 +-  js/class.js
         20 +-  js/electron.js
         17 +-  js/logger.js
         85 +-  js/module.js
          8 +-  js/server.js
         15 +  js/translator.js
         11 +-  module-types.ts
         46 +-  modules/default/calendar/calendarutils.js
         83 +-  modules/default/clock/clock.js
        163 +-  modules/default/clock/clock_styles.css
         23 +-  modules/default/currentweather/currentweather.js
          2 +  modules/default/updatenotification/git_helper.js
        177 +  modules/default/updatenotification/node_helper.js
         61 +-  modules/default/weather/forecast.njk
          7 +-  modules/default/weather/providers/README.md
        149 +-  modules/default/weather/providers/darksky.js
          6 +-  modules/default/weather/providers/envcanada.js
         57 +-  .../default/weather/providers/openweathermap.js
          6 +-  modules/default/weather/providers/smhi.js
        136 +-  modules/default/weather/providers/ukmetoffice.js
         26 +-  .../weather/providers/ukmetofficedatahub.js
         44 +-  modules/default/weather/providers/weatherbit.js
          4 +-  modules/default/weather/providers/weathergov.js
         40 +-  modules/default/weather/weather.js
          4 -  modules/default/weather/weatherobject.js
         42 +-  modules/default/weatherforecast/weatherforecast.js
          2 +  package-lock.json
       3895 ++++++++++----------  package.json
         69 +-  tests/configs/default.js
         21 +  tests/configs/empty_ipWhiteList.js
         19 +-  tests/configs/env.js
         17 +-  tests/configs/modules/alert/default.js
         13 -  tests/configs/modules/calendar/auth-default.js
         15 +-  tests/configs/modules/calendar/basic-auth.js
         15 +-  tests/configs/modules/calendar/changed-port.js
         15 +-  tests/configs/modules/calendar/custom.js
         15 +-  tests/configs/modules/calendar/default.js
         15 +-  tests/configs/modules/calendar/fail-basic-auth.js
         15 +-  tests/configs/modules/calendar/old-basic-auth.js
         15 +-  tests/configs/modules/calendar/recurring.js
         15 +-  tests/configs/modules/clock/clock_12hr.js
         11 -  tests/configs/modules/clock/clock_24hr.js
         13 -  tests/configs/modules/clock/clock_analog.js
         13 -  .../modules/clock/clock_displaySeconds_false.js
         11 -  .../configs/modules/clock/clock_showPeriodUpper.js
         11 -  tests/configs/modules/clock/clock_showTime.js
         23 +  tests/configs/modules/clock/clock_showWeek.js
         11 -  tests/configs/modules/clock/es/clock_12hr.js
         10 -  tests/configs/modules/clock/es/clock_24hr.js
         11 -  .../modules/clock/es/clock_showPeriodUpper.js
         10 -  tests/configs/modules/clock/es/clock_showWeek.js
         10 -  .../modules/compliments/compliments_anytime.js
         11 -  .../modules/compliments/compliments_date.js
         11 -  .../compliments/compliments_only_anytime.js
         11 -  .../modules/compliments/compliments_parts_day.js
         11 -  tests/configs/modules/display.js
         16 -  tests/configs/modules/helloworld/helloworld.js
         13 -  .../modules/helloworld/helloworld_default.js
         13 -  tests/configs/modules/newsfeed/default.js
         11 -  tests/configs/modules/newsfeed/incorrect_url.js
         11 -  tests/configs/modules/newsfeed/prohibited_words.js
         11 -  tests/configs/modules/positions.js
         13 -  .../modules/weather/currentweather_compliments.js
         18 +-  .../modules/weather/currentweather_default.js
         15 +-  .../modules/weather/currentweather_options.js
         17 +-  .../modules/weather/currentweather_units.js
         15 +-  .../modules/weather/forecastweather_default.js
         15 +-  .../modules/weather/forecastweather_options.js
         15 +-  .../modules/weather/forecastweather_units.js
         15 +-  tests/configs/noIpWhiteList.js
         19 +-  tests/configs/port_8090.js
         19 +-  tests/configs/without_modules.js
         13 +-  tests/e2e/env_spec.js
         47 +-  tests/e2e/fonts.js
         19 +-  tests/e2e/global-setup.js
         67 +-  tests/e2e/ipWhitelist_spec.js
         32 +-  tests/e2e/mock-console.js
         21 +  tests/e2e/modules/alert_spec.js
         33 +-  tests/e2e/modules/clock_es_spec.js
         77 +-  tests/e2e/modules/clock_spec.js
        121 +-  tests/e2e/modules/compliments_spec.js
         97 +-  tests/e2e/modules/helloworld_spec.js
         44 +-  tests/e2e/modules/newsfeed_spec.js
         64 +-  tests/e2e/modules_display_spec.js
         44 +-  tests/e2e/modules_position_spec.js
         46 +-  tests/e2e/port_config.js
         33 +-  tests/e2e/vendor_spec.js
         22 +-  tests/e2e/without_modules.js
         39 +-  tests/{e2e => electron}/dev_console.js
          0  tests/electron/env_spec.js
         40 +  tests/electron/global-setup.js
         53 +  tests/{servers => electron/modules}/basic-auth.js
          2 +-  tests/{e2e => electron}/modules/calendar_spec.js
          2 +-  tests/{e2e => electron}/modules/mocks/index.js
          0  .../modules/mocks/weather_current.js
          4 +  .../modules/mocks/weather_forecast.js
          4 +  tests/{e2e => electron}/modules/weather_spec.js
         15 +  tests/unit/classes/translator_spec.js
          3 +  tests/unit/functions/updatenotification_spec.js
        126 +  tests/unit/functions/weather_object_spec.js
         31 +  tests/unit/global_vars/defaults_modules_spec.js
         37 +-  tests/unit/global_vars/root_path_spec.js
         40 +-  tests/unit/mocks/logger.js
         20 -  translations/translations.js
          2 +-  vendor/css/font-awesome.css
          2 +-  vendor/package-lock.json
        300 +-  vendor/package.json
         36 +-  123 files changed, 3606 insertions(+), 3927 deletions(-)  delete mode 100644 .github/header.psd
      create mode 100644 .github/workflows/automated-tests.yml  delete mode 100644 .github/workflows/node-ci.js.yml  delete mode 100644 .husky/.gitignore
      create mode 100644 modules/default/updatenotification/git_helper.js
      create mode 100644 tests/configs/default.js
      create mode 100644 tests/configs/modules/clock/clock_showTime.js
      create mode 100644 tests/e2e/mock-console.js  rename tests/{e2e => electron}/dev_console.js (100%)
      create mode 100644 tests/electron/env_spec.js
      create mode 100644 tests/electron/global-setup.js  rename tests/{servers => electron/modules}/basic-auth.js (91%)  rename tests/{e2e => electron}/modules/calendar_spec.js (98%)  rename tests/{e2e => electron}/modules/mocks/index.js (100%)  rename tests/{e2e => electron}/modules/mocks/weather_current.js (87%)  rename tests/{e2e => electron}/modules/mocks/weather_forecast.js (95%)  rename tests/{e2e => electron}/modules/weather_spec.js (95%)
      create mode 100644 tests/unit/functions/updatenotification_spec.js
      create mode 100644 tests/unit/functions/weather_object_spec.js  delete mode 100644 tests/unit/mocks/logger.js
      processor architecture is armv7l
      updating MagicMirror runtime, please wait
      > magicmirror@2.17.1 install
      > echo "Installing vendor files ...
      > " && cd vendor && npm install --loglevel=error
      changed 3 packages, and audited 10 packages in 5s
      found 0 vulnerabilities
      > magicmirror@2.17.1 postinstall
      > npm run install-fonts && echo "MagicMirror installation finished successfully!
      > magicmirror@2.17.1 install-fonts
      > echo "Installing fonts ...
      > " && cd fonts && npm install --loglevel=error
      up to date, audited 2 packages in 1s
      > magicmirror@2.17.1 prepare
      > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
      no husky installed.
      added 8 packages, removed 38 packages, changed 303 packages, and audited 295 packages in 2m
      20 packages are looking for funding
        run `npm fund` for details
      npm install completed - So Okt 31 19:51:26 CET 2021 on base
      fixing sandbox permissions
      Checking for modules with removed libraries
      downloading dumpactivemodules script
      processing dependency changes for active modules with package.json files
      processing for module MMM-DWD-WarnWeather please wait
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      added 47 packages, and audited 48 packages in 46s
      2 packages are looking for funding
      processing complete for module MMM-DWD-WarnWeather
      removing git alias
      we stashed a set of files that appear changed from the latest repo versions. you should review them
      Upgrade ended - So Okt 31 19:52:23 CET 2021
      Thank you, greetings vm
      • V Offline
        voodoo-magic @voodoo-magic
        mm-out.log
        > magicmirror@2.16.0 start
        [31.10.2021 19:44.57.511] [LOG]   Starting MagicMirror: v2.16.0
        [31.10.2021 19:44.57.542] [LOG]   Loading config ...
        [31.10.2021 19:44.57.558] [LOG]   Loading module helpers ...
        [31.10.2021 19:44.57.561] [LOG]   No helper found for module: alert.
        [31.10.2021 19:44.57.802] [LOG]   Initializing new module helper ...
        [31.10.2021 19:44.57.804] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 19:44.57.806] [LOG]   No helper found for module: clock.
        [31.10.2021 19:44.57.812] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 19:44.57.813] [LOG]   No helper found for module: compliments.
        [31.10.2021 19:44.57.818] [LOG]   Initializing new module helper ...
        [31.10.2021 19:44.57.819] [LOG]   Module helper loaded: currentweather
        [31.10.2021 19:44.57.823] [LOG]   Initializing new module helper ...
        [31.10.2021 19:44.57.824] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 19:44.58.413] [LOG]   Initializing new module helper ...
        [31.10.2021 19:44.58.414] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 19:44.58.474] [LOG]   Initializing new module helper ...
        [31.10.2021 19:44.58.475] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 19:44.58.476] [LOG]   All module helpers loaded.
        [31.10.2021 19:44.58.633] [LOG]   Starting server on port 8080 ...
        [31.10.2021 19:44.58.657] [LOG]   Server started ...
        [31.10.2021 19:44.58.658] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 19:44.58.660] [LOG]   Connecting socket for: currentweather
        [31.10.2021 19:44.58.662] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 19:44.58.664] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 19:44.58.665] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 19:44.58.666] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 19:44.58.667] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 19:44.58.668] [LOG]   Sockets connected & modules started ...
        [31.10.2021 19:44.59.385] [LOG]   Launching application.
        [31.10.2021 19:45.02.162] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 19:45.02.171] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 19:45.02.314] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 19:45.08.430] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
        > magicmirror@2.17.1 start
        [31.10.2021 19:54.15.352] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 19:54.15.361] [LOG]   Loading config ...
        [31.10.2021 19:54.15.375] [LOG]   Loading module helpers ...
        [31.10.2021 19:54.15.378] [LOG]   No helper found for module: alert.
        [31.10.2021 19:54.15.407] [LOG]   Initializing new module helper ...
        [31.10.2021 19:54.15.409] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 19:54.15.411] [LOG]   No helper found for module: clock.
        [31.10.2021 19:54.15.416] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 19:54.15.418] [LOG]   No helper found for module: compliments.
        [31.10.2021 19:54.15.423] [LOG]   Initializing new module helper ...
        [31.10.2021 19:54.15.424] [LOG]   Module helper loaded: currentweather
        [31.10.2021 19:54.15.429] [LOG]   Initializing new module helper ...
        [31.10.2021 19:54.15.430] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 19:54.16.092] [LOG]   Initializing new module helper ...
        [31.10.2021 19:54.16.093] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 19:54.16.210] [LOG]   Initializing new module helper ...
        [31.10.2021 19:54.16.213] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 19:54.16.214] [LOG]   All module helpers loaded.
        [31.10.2021 19:54.16.391] [LOG]   Starting server on port 8080 ...
        [31.10.2021 19:54.16.416] [LOG]   Server started ...
        [31.10.2021 19:54.16.417] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 19:54.16.418] [LOG]   Connecting socket for: currentweather
        [31.10.2021 19:54.16.421] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 19:54.16.422] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 19:54.16.423] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 19:54.16.424] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 19:54.16.425] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 19:54.16.426] [LOG]   Sockets connected & modules started ...
        [31.10.2021 19:54.17.332] [LOG]   Launching application.
        [31.10.2021 19:56.20.151] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 19:56.20.158] [LOG]   Loading config ...
        [31.10.2021 19:56.20.164] [LOG]   Loading module helpers ...
        [31.10.2021 19:56.20.166] [LOG]   No helper found for module: alert.
        [31.10.2021 19:56.20.183] [LOG]   Initializing new module helper ...
        [31.10.2021 19:56.20.184] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 19:56.20.185] [LOG]   No helper found for module: clock.
        [31.10.2021 19:56.20.186] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 19:56.20.187] [LOG]   No helper found for module: compliments.
        [31.10.2021 19:56.20.190] [LOG]   Initializing new module helper ...
        [31.10.2021 19:56.20.191] [LOG]   Module helper loaded: currentweather
        [31.10.2021 19:56.20.194] [LOG]   Initializing new module helper ...
        [31.10.2021 19:56.20.195] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 19:56.20.524] [LOG]   Initializing new module helper ...
        [31.10.2021 19:56.20.525] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 19:56.20.582] [LOG]   Initializing new module helper ...
        [31.10.2021 19:56.20.582] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 19:56.20.583] [LOG]   All module helpers loaded.
        [31.10.2021 19:56.20.660] [LOG]   Starting server on port 8080 ...
        [31.10.2021 19:56.20.675] [LOG]   Server started ...
        [31.10.2021 19:56.20.676] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 19:56.20.677] [LOG]   Connecting socket for: currentweather
        [31.10.2021 19:56.20.679] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 19:56.20.681] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 19:56.20.681] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 19:56.20.682] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 19:56.20.683] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 19:56.20.683] [LOG]   Sockets connected & modules started ...
        [31.10.2021 19:56.20.860] [LOG]   Launching application.
        [31.10.2021 19:56.25.748] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 19:56.25.769] [INFO]  Checking git for module: default
        [31.10.2021 19:56.25.791] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 19:56.25.812] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 19:58.22.998] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 19:58.23.005] [LOG]   Loading config ...
        [31.10.2021 19:58.23.011] [LOG]   Loading module helpers ...
        [31.10.2021 19:58.23.013] [LOG]   No helper found for module: alert.
        [31.10.2021 19:58.23.030] [LOG]   Initializing new module helper ...
        [31.10.2021 19:58.23.031] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 19:58.23.032] [LOG]   No helper found for module: clock.
        [31.10.2021 19:58.23.033] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 19:58.23.034] [LOG]   No helper found for module: compliments.
        [31.10.2021 19:58.23.037] [LOG]   Initializing new module helper ...
        [31.10.2021 19:58.23.038] [LOG]   Module helper loaded: currentweather
        [31.10.2021 19:58.23.041] [LOG]   Initializing new module helper ...
        [31.10.2021 19:58.23.042] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 19:58.23.359] [LOG]   Initializing new module helper ...
        [31.10.2021 19:58.23.360] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 19:58.23.419] [LOG]   Initializing new module helper ...
        [31.10.2021 19:58.23.419] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 19:58.23.420] [LOG]   All module helpers loaded.
        [31.10.2021 19:58.23.498] [LOG]   Starting server on port 8080 ...
        [31.10.2021 19:58.23.512] [LOG]   Server started ...
        [31.10.2021 19:58.23.514] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 19:58.23.515] [LOG]   Connecting socket for: currentweather
        [31.10.2021 19:58.23.517] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 19:58.23.518] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 19:58.23.519] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 19:58.23.520] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 19:58.23.521] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 19:58.23.521] [LOG]   Sockets connected & modules started ...
        [31.10.2021 19:58.23.698] [LOG]   Launching application.
        [31.10.2021 19:58.25.464] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 19:58.25.491] [INFO]  Checking git for module: default
        [31.10.2021 19:58.25.515] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 19:58.25.533] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:00.01.760] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:00.01.767] [LOG]   Loading config ...
        [31.10.2021 20:00.01.773] [LOG]   Loading module helpers ...
        [31.10.2021 20:00.01.775] [LOG]   No helper found for module: alert.
        [31.10.2021 20:00.01.792] [LOG]   Initializing new module helper ...
        [31.10.2021 20:00.01.793] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:00.01.794] [LOG]   No helper found for module: clock.
        [31.10.2021 20:00.01.795] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:00.01.796] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:00.01.799] [LOG]   Initializing new module helper ...
        [31.10.2021 20:00.01.800] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:00.01.803] [LOG]   Initializing new module helper ...
        [31.10.2021 20:00.01.804] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:00.02.122] [LOG]   Initializing new module helper ...
        [31.10.2021 20:00.02.123] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:00.02.181] [LOG]   Initializing new module helper ...
        [31.10.2021 20:00.02.182] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:00.02.182] [LOG]   All module helpers loaded.
        [31.10.2021 20:00.02.261] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:00.02.275] [LOG]   Server started ...
        [31.10.2021 20:00.02.277] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:00.02.278] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:00.02.280] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:00.02.281] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:00.02.282] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:00.02.283] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:00.02.283] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:00.02.284] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:00.02.465] [LOG]   Launching application.
        [31.10.2021 20:00.04.145] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 20:00.04.171] [INFO]  Checking git for module: default
        [31.10.2021 20:00.04.193] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 20:00.04.210] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:00.07.085] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
        [31.10.2021 20:01.48.349] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:01.48.356] [LOG]   Loading config ...
        [31.10.2021 20:01.48.362] [LOG]   Loading module helpers ...
        [31.10.2021 20:01.48.364] [LOG]   No helper found for module: alert.
        [31.10.2021 20:01.48.380] [LOG]   Initializing new module helper ...
        [31.10.2021 20:01.48.382] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:01.48.383] [LOG]   No helper found for module: clock.
        [31.10.2021 20:01.48.384] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:01.48.385] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:01.48.388] [LOG]   Initializing new module helper ...
        [31.10.2021 20:01.48.389] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:01.48.391] [LOG]   Initializing new module helper ...
        [31.10.2021 20:01.48.392] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:01.48.717] [LOG]   Initializing new module helper ...
        [31.10.2021 20:01.48.718] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:01.48.776] [LOG]   Initializing new module helper ...
        [31.10.2021 20:01.48.777] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:01.48.777] [LOG]   All module helpers loaded.
        [31.10.2021 20:01.48.853] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:01.48.868] [LOG]   Server started ...
        [31.10.2021 20:01.48.869] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:01.48.870] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:01.48.872] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:01.48.874] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:01.48.874] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:01.48.875] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:01.48.876] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:01.48.876] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:01.49.055] [LOG]   Launching application.
        [31.10.2021 20:03.25.379] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:03.25.386] [LOG]   Loading config ...
        [31.10.2021 20:03.25.392] [LOG]   Loading module helpers ...
        [31.10.2021 20:03.25.395] [LOG]   No helper found for module: alert.
        [31.10.2021 20:03.25.411] [LOG]   Initializing new module helper ...
        [31.10.2021 20:03.25.412] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:03.25.413] [LOG]   No helper found for module: clock.
        [31.10.2021 20:03.25.415] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:03.25.416] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:03.25.419] [LOG]   Initializing new module helper ...
        [31.10.2021 20:03.25.420] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:03.25.423] [LOG]   Initializing new module helper ...
        [31.10.2021 20:03.25.424] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:03.25.748] [LOG]   Initializing new module helper ...
        [31.10.2021 20:03.25.749] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:03.25.806] [LOG]   Initializing new module helper ...
        [31.10.2021 20:03.25.806] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:03.25.807] [LOG]   All module helpers loaded.
        [31.10.2021 20:03.25.884] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:03.25.899] [LOG]   Server started ...
        [31.10.2021 20:03.25.900] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:03.25.901] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:03.25.903] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:03.25.905] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:03.25.905] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:03.25.906] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:03.25.907] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:03.25.907] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:03.26.088] [LOG]   Launching application.
        [31.10.2021 20:03.27.842] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 20:03.27.867] [INFO]  Checking git for module: default
        [31.10.2021 20:03.27.892] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 20:03.27.910] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:03.30.085] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
        [31.10.2021 20:05.06.809] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:05.06.818] [LOG]   Loading config ...
        [31.10.2021 20:05.06.826] [LOG]   Loading module helpers ...
        [31.10.2021 20:05.06.831] [LOG]   No helper found for module: alert.
        [31.10.2021 20:05.06.849] [LOG]   Initializing new module helper ...
        [31.10.2021 20:05.06.853] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:05.06.856] [LOG]   No helper found for module: clock.
        [31.10.2021 20:05.06.859] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:05.06.863] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:05.06.868] [LOG]   Initializing new module helper ...
        [31.10.2021 20:05.06.871] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:05.06.876] [LOG]   Initializing new module helper ...
        [31.10.2021 20:05.06.879] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:05.07.203] [LOG]   Initializing new module helper ...
        [31.10.2021 20:05.07.206] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:05.07.265] [LOG]   Initializing new module helper ...
        [31.10.2021 20:05.07.268] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:05.07.271] [LOG]   All module helpers loaded.
        [31.10.2021 20:05.07.349] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:05.07.368] [LOG]   Server started ...
        [31.10.2021 20:05.07.371] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:05.07.375] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:05.07.381] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:05.07.389] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:05.07.392] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:05.07.395] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:05.07.398] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:05.07.401] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:05.07.577] [LOG]   Launching application.
        [31.10.2021 20:05.09.537] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 20:05.09.555] [INFO]  Checking git for module: default
        [31.10.2021 20:05.09.572] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 20:05.09.590] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:05.10.154] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
        [31.10.2021 20:06.55.864] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:06.55.871] [LOG]   Loading config ...
        [31.10.2021 20:06.55.877] [LOG]   Loading module helpers ...
        [31.10.2021 20:06.55.879] [LOG]   No helper found for module: alert.
        [31.10.2021 20:06.55.896] [LOG]   Initializing new module helper ...
        [31.10.2021 20:06.55.897] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:06.55.898] [LOG]   No helper found for module: clock.
        [31.10.2021 20:06.55.900] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:06.55.901] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:06.55.904] [LOG]   Initializing new module helper ...
        [31.10.2021 20:06.55.905] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:06.55.908] [LOG]   Initializing new module helper ...
        [31.10.2021 20:06.55.908] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:06.56.231] [LOG]   Initializing new module helper ...
        [31.10.2021 20:06.56.232] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:06.56.289] [LOG]   Initializing new module helper ...
        [31.10.2021 20:06.56.290] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:06.56.290] [LOG]   All module helpers loaded.
        [31.10.2021 20:06.56.367] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:06.56.381] [LOG]   Server started ...
        [31.10.2021 20:06.56.382] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:06.56.384] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:06.56.386] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:06.56.387] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:06.56.388] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:06.56.389] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:06.56.390] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:06.56.390] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:06.56.570] [LOG]   Launching application.
        [31.10.2021 20:06.59.498] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 20:06.59.518] [INFO]  Checking git for module: default
        [31.10.2021 20:06.59.537] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 20:06.59.554] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:07.00.089] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
        [31.10.2021 20:08.36.885] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:08.36.892] [LOG]   Loading config ...
        [31.10.2021 20:08.36.898] [LOG]   Loading module helpers ...
        [31.10.2021 20:08.36.900] [LOG]   No helper found for module: alert.
        [31.10.2021 20:08.36.917] [LOG]   Initializing new module helper ...
        [31.10.2021 20:08.36.918] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:08.36.919] [LOG]   No helper found for module: clock.
        [31.10.2021 20:08.36.920] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:08.36.921] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:08.36.924] [LOG]   Initializing new module helper ...
        [31.10.2021 20:08.36.925] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:08.36.928] [LOG]   Initializing new module helper ...
        [31.10.2021 20:08.36.929] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:08.37.255] [LOG]   Initializing new module helper ...
        [31.10.2021 20:08.37.256] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:08.37.314] [LOG]   Initializing new module helper ...
        [31.10.2021 20:08.37.314] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:08.37.315] [LOG]   All module helpers loaded.
        [31.10.2021 20:08.37.394] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:08.37.409] [LOG]   Server started ...
        [31.10.2021 20:08.37.410] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:08.37.411] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:08.37.413] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:08.37.415] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:08.37.415] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:08.37.416] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:08.37.417] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:08.37.417] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:08.37.598] [LOG]   Launching application.
        [31.10.2021 20:08.39.425] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 20:08.39.460] [INFO]  Checking git for module: default
        [31.10.2021 20:08.39.486] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 20:08.39.502] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:08.44.099] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
        [31.10.2021 20:10.19.727] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:10.19.736] [LOG]   Loading config ...
        [31.10.2021 20:10.19.742] [LOG]   Loading module helpers ...
        [31.10.2021 20:10.19.744] [LOG]   No helper found for module: alert.
        [31.10.2021 20:10.19.764] [LOG]   Initializing new module helper ...
        [31.10.2021 20:10.19.765] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:10.19.766] [LOG]   No helper found for module: clock.
        [31.10.2021 20:10.19.767] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:10.19.769] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:10.19.772] [LOG]   Initializing new module helper ...
        [31.10.2021 20:10.19.772] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:10.19.775] [LOG]   Initializing new module helper ...
        [31.10.2021 20:10.19.776] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:10.20.103] [LOG]   Initializing new module helper ...
        [31.10.2021 20:10.20.104] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:10.20.162] [LOG]   Initializing new module helper ...
        [31.10.2021 20:10.20.163] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:10.20.163] [LOG]   All module helpers loaded.
        [31.10.2021 20:10.20.240] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:10.20.254] [LOG]   Server started ...
        [31.10.2021 20:10.20.256] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:10.20.257] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:10.20.259] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:10.20.260] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:10.20.261] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:10.20.262] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:10.20.262] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:10.20.263] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:10.20.443] [LOG]   Launching application.
        [31.10.2021 20:10.22.224] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 20:10.22.248] [INFO]  Checking git for module: default
        [31.10.2021 20:10.22.270] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 20:10.22.288] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:10.23.224] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
        [31.10.2021 20:12.03.920] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:12.03.927] [LOG]   Loading config ...
        [31.10.2021 20:12.03.933] [LOG]   Loading module helpers ...
        [31.10.2021 20:12.03.935] [LOG]   No helper found for module: alert.
        [31.10.2021 20:12.03.951] [LOG]   Initializing new module helper ...
        [31.10.2021 20:12.03.952] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:12.03.954] [LOG]   No helper found for module: clock.
        [31.10.2021 20:12.03.956] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:12.03.957] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:12.03.960] [LOG]   Initializing new module helper ...
        [31.10.2021 20:12.03.961] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:12.03.964] [LOG]   Initializing new module helper ...
        [31.10.2021 20:12.03.965] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:12.04.299] [LOG]   Initializing new module helper ...
        [31.10.2021 20:12.04.299] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:12.04.357] [LOG]   Initializing new module helper ...
        [31.10.2021 20:12.04.358] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:12.04.358] [LOG]   All module helpers loaded.
        [31.10.2021 20:12.04.436] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:12.04.450] [LOG]   Server started ...
        [31.10.2021 20:12.04.451] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:12.04.452] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:12.04.454] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:12.04.456] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:12.04.457] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:12.04.457] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:12.04.458] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:12.04.459] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:12.04.638] [LOG]   Launching application.
        [31.10.2021 20:12.06.377] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 20:12.06.407] [INFO]  Checking git for module: default
        [31.10.2021 20:12.06.430] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 20:12.06.450] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:12.11.274] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
        [31.10.2021 20:13.50.810] [LOG]   Starting MagicMirror: v2.17.1
        [31.10.2021 20:13.50.817] [LOG]   Loading config ...
        [31.10.2021 20:13.50.823] [LOG]   Loading module helpers ...
        [31.10.2021 20:13.50.826] [LOG]   No helper found for module: alert.
        [31.10.2021 20:13.50.842] [LOG]   Initializing new module helper ...
        [31.10.2021 20:13.50.843] [LOG]   Module helper loaded: updatenotification
        [31.10.2021 20:13.50.844] [LOG]   No helper found for module: clock.
        [31.10.2021 20:13.50.845] [LOG]   No helper found for module: calendar_monthly.
        [31.10.2021 20:13.50.846] [LOG]   No helper found for module: compliments.
        [31.10.2021 20:13.50.849] [LOG]   Initializing new module helper ...
        [31.10.2021 20:13.50.850] [LOG]   Module helper loaded: currentweather
        [31.10.2021 20:13.50.853] [LOG]   Initializing new module helper ...
        [31.10.2021 20:13.50.854] [LOG]   Module helper loaded: weatherforecast
        [31.10.2021 20:13.51.182] [LOG]   Initializing new module helper ...
        [31.10.2021 20:13.51.183] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [31.10.2021 20:13.51.243] [LOG]   Initializing new module helper ...
        [31.10.2021 20:13.51.244] [LOG]   Module helper loaded: newsfeed
        [31.10.2021 20:13.51.244] [LOG]   All module helpers loaded.
        [31.10.2021 20:13.51.322] [LOG]   Starting server on port 8080 ...
        [31.10.2021 20:13.51.337] [LOG]   Server started ...
        [31.10.2021 20:13.51.338] [LOG]   Connecting socket for: updatenotification
        [31.10.2021 20:13.51.339] [LOG]   Connecting socket for: currentweather
        [31.10.2021 20:13.51.341] [LOG]   Connecting socket for: weatherforecast
        [31.10.2021 20:13.51.342] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [31.10.2021 20:13.51.343] [LOG]   MMM-DWD-WarnWeather helper started...
        [31.10.2021 20:13.51.344] [LOG]   Connecting socket for: newsfeed
        [31.10.2021 20:13.51.345] [LOG]   Starting node helper for: newsfeed
        [31.10.2021 20:13.51.345] [LOG]   Sockets connected & modules started ...
        [31.10.2021 20:13.51.530] [LOG]   Launching application.
        [31.10.2021 20:13.53.302] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        [31.10.2021 20:13.53.328] [INFO]  Checking git for module: default
        [31.10.2021 20:13.53.354] [INFO]  Checking git for module: calendar_monthly
        [31.10.2021 20:13.53.375] [INFO]  Checking git for module: MMM-DWD-WarnWeather
        [31.10.2021 20:13.56.707] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
          sdetweil @voodoo-magic
          @voodoo-magic when did u do the upgrade, I just upgraded it to do a lot more, but doesn’t show any of the module work…
          • V Offline
            voodoo-magic @sdetweil
            @sdetweil Upgrade was performed on 31 October.
            mm-error.log
            [31.10.2021 19:44.58.661] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
            [31.10.2021 19:44.58.663] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
            [31.10.2021 19:44.59.546] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
              @voodoo-magic can u send me the installers/upgrade.log
              same userid at gmail
              something doesn’t seem right
              unless u have no extra modules installed
              • V Offline
                voodoo-magic
                Today I updated my operating system.
                Version 2.17.1 is now running.
                Thank you @sdetweil
