    Can I use a Chromebook?
    6 Posts 2 Posters 2.7k Views 2 Watching
    • B
      bobdabuilder
      Hi all,
      new user and grateful to be a part of such a vibrant community.
      I’m not very technical but wanted to have a simple calendaring, to-do list, and perhaps photos displayed on a MM in my kitchen. I also would like to have it as touchscreen. In order to simplify my build and have a supported device, I wanted to run Magic Mirror on a 14" Lenovo Chromebook 3. Will magic mirror work on such a device? If so, will it run natively or will I have to do anything fancy to the OS?
      thanks!
      Bob B.
        sdetweil @bobdabuilder
        @bobdabuilder u need to install an open OS on the chromebook… and you ‘can’ dual boot between chromeOS and whatever.
        I use Gallium on my chrome book and chromeBOXes …
        https://wiki.galliumos.org/Installing
        the biggest thing is you have to remove the write protect screw from inside the case to allow writing the new boot firmware
        but then its up to you…
        I dual booted for about 6 months then wiped chromeOS completely and boot gallium now…
        I just replaced my Jetson Nano in the hall mirror with an hp Chromebox.
        dual core Intel, HDMI and display port, 4k output. 4 USB ports, wifi and Ethernet. no fan required. installed Gallium Linux. and mm runs great. box is 4x4x1.5. expandable ram, 16 gig ssd disk. $40 (see them for <30 too)
        Also have Gallium on my Toshiba chromebook
        B 1 Reply Last reply
        • B
          bobdabuilder @sdetweil
          @sdetweil said in Can I use a Chromebook?:
          Thank you @sdetweil !
          I suspect these screws are within the chassis itself and their locations vary with each model then? Are there any simpler options given I wish to have touchscreen? Ideally I’d like to have at least 14" screen but prefer 24 inch or so.
            @bobdabuilder yes take the cover off and remove the screw. 5 minute job, this was my first time (Chromebook). I used it in the hospital w covid jan-feb…
            I don’t have a touchscreen model, so I don’t know about that. mm won’t run under chromeOS
            • B
              @sdetweil - thank you!
                @bobdabuilder here is two different dial boot methods
                https://au.pcmag.com/linux/89550/how-to-install-linux-on-your-chromebook
