    How do I use notfications
    tutorialhelpnotifications
    18 Posts 2 Posters 6.0k Views 2 Watching
      Alyx
      Hi Guys,
      I’m new to this and have no clue how to use js and notifications.
      I was wondering if someone can help me with setting up some modules to talk to each other. I want to use voice commands to activate a camera module to begin.
      I’m using MMM_Voice_Commands and want to use MMM_SelfieShoot. If someone can help on how to use these that would be great and then I can atleast replicate it for other modules.
      My Conf
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/getting-started/configuration.html#general
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-UK",
      	timeFormat: 12,
      	units: "metric",
      	serverOnly:  true/false/"local" ,
      	// starts serveronly and then starts chrome browser
      	notifications: [
              port: 11100,
              OnOff: false,
              notification: ["SELFIE_SHOOT", 'selfie']
              module: "MMM-Voice-Commands",
                  debug: true, //Displays end results and errors from annyang in the Log
                  autoStart: true, //Adds annyang commands when it first starts
                  activateCommand: "hello mirror", //Command to active all other commands
                  deactivateCommand: "goodbye mirror", //Command to deactivate all other commands
                  alertHeard: true, //Whether an alert should be shown when annyang hears a phrase (mostly for debug)
                  commands: {
                      "command statement :variable (optional statement)": "SOCKET_NOTIFICATION_NAME",
                      //The payload of the socket notification will be whatever is said in the :variable
                      "command statement *variable": function(param){
                          alert("Whatever is said in the *variable space is given as the "+param);
                          //These function's 'this' are bound to the module's 'this' so you can do stuff like:
                          this.sendNotification("PAGE_SELECT", "2");
                          this.sendnotifocation("SELFIE_SHOOT, selfie");
              disabled: false,
              module: 'MMM-Astro',
              position: 'top_left',
      		      sign: "leo",
      		      iconset: "4",
      		      extend: false,
          module: 'MMM-SleepWake',
          config:{
             mode: 'DPMS'
          module: "MMM-MotionDetector",
             captureIntervalTime: 1000,
          	scoreThreshold: 20,
          	timeout: 12
      	disabled: false,
      	module: "MMM-Selfieshot",
      	storePath: "./Storage/Photos",
      	width:1280,
      	height:720,
      	quality: 100,
      	device: null,
      	shootMessage: "Smile!",
      	shootCountdown: 3,
      	displayCountdown: true,
      	displayResult: true,
      	playShutter: true,
      	shutterSound: "shutter.mp3",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_center"
        		module: "MMM-OpenWeatherMapForecast",
        		header: "Weather",
        		classes: "default everyone",
        		disabled: false,
          			iconset: "4c",
          			units: "metric",
          			useAnimatedIcons: true,
          			concise: false,
          			forecastLayout: "table",
          			showWind: true
      Voice commands conf. this is a grab from an updated conf so dont worry about the lenght, my part is at the end
      Module.register("MMM-Voice-Commands", {
      	defaults: {
      		debug: false, //Displays end results and errors from annyang in the Log
      		alertHeard: false, //Wether an alert should be shown when annyang hears a phrase (mostly for debug)
      		commands: {
      			"socket test :payload": "TEST_SOCKET",
      			"function test :payload": function(payload){alert("Test: "+payload)} //in these functions 'this' is bound to the module so this.sendNotification() is valid
      	start: function() {
      		this.rawCommands = this.config.commands;
      		this.autoStart = this.config.autoStart;
      		this.activateCommand = this.config.activateCommand;
      		this.deactivateCommand = this.config.deactivateCommand;
      		this.alertHeard = this.config.alertHeard;
      		this.debug = this.config.debug;
      		this.commands = {};
      		this.active = false
      		this.initAnnyang();
      	initAnnyang: function(){
      		const self = this;
      		if (annyang) {
      			//Iterate over commands list to create a valid annyang command object
      			for (var key in self.rawCommands) {
      				if (self.rawCommands.hasOwnProperty(key)) {
      					//If the property is already a function, leave it that way. Otherwise assume it is a socket name
      					if(typeof self.rawCommands[key] !== "function"){
      						//Construct a valid function...
      						function createCommand(socket){
      							return function(payload){
      								self.sendNotification(socket, payload);
      						//...And then put it in the object
      						self.commands[key] = createCommand(self.rawCommands[key])
      					}else{
      						self.commands[key] = self.rawCommands[key].bind(self);
      			if(self.autoStart){
      				annyang.addCommands(self.commands);
      				self.active = true;
      			const standardCommands = {}
      			standardCommands[self.activateCommand] = function(){
      				if(!self.active){
      					self.addCommands(self.commands);
      					self.active = true;
      					self.sendNotification("SHOW_ALERT", {type: "notification", title: "Voice Commands", message: "Activated"});
      				}else{
      					self.sendNotification("SHOW_ALERT", {type: "notification", title: "Voice Commands", message: "Already Active"});
      			standardCommands[self.deactivateCommand] = function(){
      				if(self.active){
      					self.removeCommands(self.commands);
      					self.active = false;
      					self.sendNotification("SHOW_ALERT", {type: "notification", title: "Voice Commands", message: "Deactivated"});
      				}else{
      					self.sendNotification("SHOW_ALERT", {type: "notification", title: "Voice Commands", message: "Already Deactivated"});
      			annyang.addCommands(standardCommands);
      			annyang.start();
      			if(self.debug){
      				annyang.addCallback("result", function(e){
      					Log.log(e)
      				annyang.addCallback("error", function(e){
      					Log.log(e)
                  // This is the code that I added to add a similar experience to Hello-Lucy
            if (self.alertHeard) {
              annyang.addCallback("result", function(e) {
                for (var i = 0; i < e.length; i++) {
                  // Get First result from annyang, which will be closest speech match
                  // Format notification into format to match MMM-HelloLucy
                  var notification = e[i]
                    .toUpperCase()
                    .trim()
                    .replace(" ", "_");
                  // MMM-Voice-Commands sends notification to MMM-GoogleMapsTraffic to HIDE
                  if (notification === "HIDE_TRAFFIC") {
                    self.sendNotification("HIDE_TRAFFIC");
                  // Check if notification is requesting location
                  else if (notification.indexOf("SHOW_TRAFFIC") > -1) {
                    // MMM-Voice-Commands sends notification to MMM-GoogleMapsTraffic to SHOW Default location per config
                    if (notification === "SHOW_TRAFFIC") {
                      self.sendNotification("SHOW_TRAFFIC");
                    // MMM-Voice-Commands sends notification to MMM-GoogleMapsTraffic to SHOW passed location from voice
                    else {
                      var indexOfNotification = notification.indexOf("SHOW_TRAFFIC");
                      var strippedPayload = notification
                        .replace("_", " ")
                        .substr(ind + 8, notification.length)
                        .trim();
                      var location = st
                        .replace("of", "")
                        .trim()
                        .replace("for", "")
                        .trim();
                      self.sendNotification("SHOW_TRAFFIC", location);
                  // Add Additional Modules similar to below
                  // MMM-Voice-Commands sends notification to MMM-Cocktails to HIDE
                  else if (notification === "HIDE_COCKTAILS") {
                    self.sendNotification("HIDE_COCKTAILS");
                  // MMM-Voice-Commands sends notification to MMM-Cocktails to SHOW
                  else if (notification === "SHOW_COCKTAILS") {
                    self.sendNotification("SHOW_COCKTAILS");
                  // MMM-Voice-Commands sends notification to MMM-Clock to HIDE
                  else if (notification === "HIDE_CLOCK") {
                    self.sendNotification("HIDE_CLOCK");
                  // MMM-Voice-Commands sends notification to MMM-Clock to SHOW
                  else if (notification === "SHOW_CLOCK") {
                    self.sendNotification("SHOW_CLOCK");
                  // MMM-Voice-Commands sends notification to MMM-Newsfeed to HIDE
                  else if (notification === "HIDE_NEWSFEED") {
                    self.sendNotification("HIDE_NEWSFEED");
                  // MMM-Voice-Commands sends notification to MMM-Newsfeed to SHOW
                  else if (notification === "SHOW_NEWSFEED") {
                    self.sendNotification("SHOW_NEWSFEED");
                  // MMM-Voice-Commands sends notification to MMM-AlarmClock to HIDE
                  else if (notification === "HIDE_ALARM") {
                    this.sendNotification("HIDE_ALARM");
                  // MMM-Voice-Commands sends notification to MMM-AlarmClock to SHOW
                  else if (notification === "SHOW_ALARM") {
                    this.sendNotification("SHOW_ALARM");
                  // MMM-Voice-Commands sends notification to MMM-Back to HIDE
                  else if (notification === "HIDE_BACKGROUND") {
                    this.sendNotification("HIDE_BACKGROUND");
                  // MMM-Voice-Commands sends notification to MMM-Back to SHOW
                  else if (notification === "SHOW_BACKGROUND") {
                    this.sendNotification("SHOW_BACKGROUND");
                  // MMM-Voice-Commands sends notification to calendar to HIDE
                  else if (notification === "HIDE_CALENDAR") {
                    this.sendNotification("HIDE_CALENDAR");
                  // MMM-Voice-Commands sends notification to calendar to SHOW
                  else if (notification === "SHOW_CALENDAR") {
                    this.sendNotification("SHOW_CALENDAR");
                  // MMM-Voice-Commands sends notification to MMM-CARDS to HIDE
                  else if (notification === "HIDE_CARDS") {
                    this.sendNotification("HIDE_CARDS");
                  // MMM-Voice-Commands sends notification to MMM-CARDS to SHOW
                  else if (notification === "SHOW_CARDS") {
                    this.sendNotification("SHOW_CARDS");
                  // MMM-Voice-Commands sends notification to MMM-Census to HIDE
                  else if (notification === "HIDE_CENSUS") {
                    this.sendNotification("HIDE_CENSUS");
                  // MMM-Voice-Commands sends notification to MMM-Census to SHOW
                  else if (notification === "SHOW_CENSUS") {
                    this.sendNotification("SHOW_CENSUS");
                  // MMM-Voice-Commands sends notification to MMM-CLOCK to HIDE
                    this.sendNotification("HIDE_CLOCK");
                  // MMM-Voice-Commands sends notification to MMM-CLOCK to SHOW
                    this.sendNotification("SHOW_CLOCK");
                  // MMM-Voice-Commands sends notification to MMM-COCKTAILS to HIDE
                    this.sendNotification("HIDE_COCKTAILS");
                  // MMM-Voice-Commands sends notification to MMM-COCKTAILS to SHOW
                    this.sendNotification("SHOW_COCKTAILS");
                  // MMM-Voice-Commands sends notification to compliments to HIDE
                  else if (notification === "HIDE_COMPLIMENTS") {
                    this.sendNotification("HIDE_COMPLIMENTS");
                  // MMM-Voice-Commands sends notification to compliments to SHOW
                  else if (notification === "SHOW_COMPLIMENTS") {
                    this.sendNotification("SHOW_COMPLIMENTS");
                  // MMM-Voice-Commands sends notification to MMM-NOAA to HIDE
                  else if (notification === "HIDE_COWBOY") {
                    this.sendNotification("HIDE_COWBOY");
                  // MMM-Voice-Commands sends notification to MMM-NOAA to SHOW
                  else if (notification === "SHOW_COWBOY") {
                    this.sendNotification("SHOW_COWBOY");
                  // MMM-Voice-Commands sends notification to MMM-EOL to HIDE
                  else if (notification === "HIDE_DARWIN") {
                    this.sendNotification("HIDE_DARWIN");
                  // MMM-Voice-Commands sends notification to MMM-EOL to SHOW
                  else if (notification === "SHOW_DARWIN") {
                    this.sendNotification("SHOW_DARWIN");
                  // MMM-Voice-Commands sends notification to MMM-EARTH to HIDE
                  else if (notification === "HIDE_EARTH") {
                    this.sendNotification("HIDE_EARTH");
                  // MMM-Voice-Commands sends notification to MMM-EARTH to SHOW
                  else if (notification === "SHOW_EARTH") {
                    this.sendNotification("SHOW_EARTH");
                  // MMM-Voice-Commands sends notification to MMM-EyeCandy to HIDE
                  else if (notification === "HIDE_EYECANDY") {
                    this.sendNotification("HIDE_EYECANDY");
                  // MMM-Voice-Commands sends notification to MMM-EyeCandy to SHOW
                  else if (notification === "SHOW_EYECANDY") {
                    this.sendNotification("SHOW_EYECANDY");
                  // MMM-Voice-Commands sends notification to MMM-Events to HIDE
                  else if (notification === "HIDE_EVENTS") {
                    this.sendNotification("HIDE_EVENTS");
                  // MMM-Voice-Commands sends notification to MMM-Events to SHOW
                  else if (notification === "SHOW_EVENTS") {
                    this.sendNotification("SHOW_EVENTS");
                  // MMM-Voice-Commands sends notification to MMM-rfacts to HIDE
                  else if (notification === "HIDE_FAX") {
                    this.sendNotification("HIDE_FAX");
                  // MMM-Voice-Commands sends notification to MMM-rfacts to SHOW
                  else if (notification === "SHOW_FAX") {
                    this.sendNotification("SHOW_FAX");
                  // MMM-Voice-Commands sends notification to MMM-Glock to HIDE
                  else if (notification === "HIDE_FLIPPER") {
                    this.sendNotification("HIDE_FLIPPER");
                  // MMM-Voice-Commands sends notification to MMM-Glock to SHOW
                  else if (notification === "SHOW_FLIPPER") {
                    this.sendNotification("SHOW_FLIPPER");
                  // MMM-Voice-Commands sends notification to MMM-FlightsAbove to HIDE
                  else if (notification === "HIDE_FLIGHTS") {
                    this.sendNotification("HIDE_FLIGHTS");
                  // MMM-Voice-Commands sends notification to MMM-FlightsAbove to SHOW
                  else if (notification === "SHOW_FLIGHTS") {
                    this.sendNotification("SHOW_FLIGHTS");
                  // MMM-Voice-Commands sends notification to MMM-Fortune to HIDE
                  else if (notification === "HIDE_FORTUNE") {
                    this.sendNotification("HIDE_FORTUNE");
                  // MMM-Voice-Commands sends notification to MMM-Fortune to SHOW
                  else if (notification === "SHOW_FORTUNE") {
                    this.sendNotification("SHOW_FORTUNE");
                  // MMM-Voice-Commands sends notification to MMM-Gas to HIDE
                  else if (notification === "HIDE_GAS") {
                    this.sendNotification("HIDE_GAS");
                  // MMM-Voice-Commands sends notification to MMM-Gas to SHOW
                  else if (notification === "SHOW_GAS") {
                    this.sendNotification("SHOW_GAS");
                  // MMM-Voice-Commands sends notification to MMM-JEOPARDY to HIDE
                  else if (notification === "HIDE_JEOPARDY") {
                    this.sendNotification("HIDE_JEOPARDY");
                  // MMM-Voice-Commands sends notification to MMM-JEOPARDY to SHOW
                  else if (notification === "SHOW_JEOPARDY") {
                    this.sendNotification("SHOW_JEOPARDY");
                  // MMM-Voice-Commands sends notification to MMM-LICE to HIDE
                  else if (notification === "HIDE_LICE") {
                    this.sendNotification("HIDE_LICE");
                  // MMM-Voice-Commands sends notification to MMM-LICE to SHOW
                  else if (notification === "SHOW_LICE") {
                    this.sendNotification("SHOW_LICE");
                  // MMM-Voice-Commands sends notification to MMM-URHere to HIDE
                  else if (notification === "HIDE_LOCATION") {
                    this.sendNotification("HIDE_LOCATION");
                  // MMM-Voice-Commands sends notification to MMM-URHere to SHOW
                  else if (notification === "SHOW_LOCATION") {
                    this.sendNotification("SHOW_LOCATION");
                  // MMM-Voice-Commands sends notification to MMM-Lottery to HIDE
                  else if (notification === "HIDE_LOTTERY") {
                    this.sendNotification("HIDE_LOTTERY");
                  // MMM-Voice-Commands sends notification to MMM-Lottery to SHOW
                  else if (notification === "SHOW_LOTTERY") {
                    this.sendNotification("SHOW_LOTTERY");
                  // MMM-Voice-Commands sends notification to MMM-EasyPix to HIDE
                  else if (notification === "HIDE_LUCY") {
                    this.sendNotification("HIDE_LUCY");
                  // MMM-Voice-Commands sends notification to MMM-EasyPix to SHOW
                  else if (notification === "SHOW_LUCY") {
                    this.sendNotification("SHOW_LUCY");
                  // MMM-Voice-Commands sends notification to MMM-Lunartic to HIDE
                  else if (notification === "HIDE_MOON") {
                    this.sendNotification("HIDE_MOON");
                  // MMM-Voice-Commands sends notification to MMM-Lunartic to SHOW
                  else if (notification === "SHOW_MOON") {
                    this.sendNotification("SHOW_MOON");
                  // MMM-Voice-Commands sends notification to MMM-NASA to HIDE
                  else if (notification === "HIDE_NASA") {
                    this.sendNotification("HIDE_NASA");
                  // MMM-Voice-Commands sends notification to MMM-NASA to SHOW
                  else if (notification === "SHOW_NASA") {
                    this.sendNotification("SHOW_NASA");
                  // MMM-Voice-Commands sends notification to MMM-NEO to HIDE
                  else if (notification === "HIDE_NEO") {
                    this.sendNotification("HIDE_NEO");
                  // MMM-Voice-Commands sends notification to MMM-NEO to SHOW
                  else if (notification === "SHOW_NEO") {
                    this.sendNotification("SHOW_NEO");
                  // MMM-Voice-Commands sends notification to newsfeed to HIDE
                  else if (notification === "HIDE_NEWS") {
                    this.sendNotification("HIDE_NEWS");
                  // MMM-Voice-Commands sends notification to newsfeed to SHOW
                  else if (notification === "SHOW_NEWS") {
                    this.sendNotification("SHOW_NEWS");
                  // MMM-Voice-Commands sends notification to MMM-PETFINDER to HIDE
                  else if (notification === "HIDE_PETFINDER") {
                    this.sendNotification("HIDE_PETFINDER");
                  // MMM-Voice-Commands sends notification to MMM-PETFINDER to SHOW
                  else if (notification === "SHOW_PETFINDER") {
                    this.sendNotification("SHOW_PETFINDER");
                  // MMM-Voice-Commands sends notification to MMM-FMI to HIDE
                  else if (notification === "HIDE_PHONE") {
                    this.sendNotification("HIDE_PHONE");
                  // MMM-Voice-Commands sends notification to MMM-FMI to SHOW
                  else if (notification === "SHOW_PHONE") {
                    this.sendNotification("SHOW_PHONE");
                  // MMM-Voice-Commands sends notification to MMM-ImageSlideshow to HIDE
                  else if (notification === "HIDE_PICTURES") {
                    this.sendNotification("HIDE_PICTURES");
                  // MMM-Voice-Commands sends notification to MMM-ImageSlideshow to SHOW
                  else if (notification === "SHOW_PICTURES") {
                    this.sendNotification("SHOW_PICTURES");
                  // MMM-Voice-Commands sends notification to MMM-PilotWX to HIDE
                  else if (notification === "HIDE_PILOTS") {
                    this.sendNotification("HIDE_PILOTS");
                  // MMM-Voice-Commands sends notification to MMM-PilotWX to SHOW
                  else if (notification === "SHOW_PILOTS") {
                    this.sendNotification("SHOW_PILOTS");
                  // MMM-Voice-Commands sends notification to MMM-AfterShip to HIDE
                  else if (notification === "HIDE_SHIPPING") {
                    this.sendNotification("HIDE_SHIPPING");
                  // MMM-Voice-Commands sends notification to MMM-AfterShip to SHOW
                  else if (notification === "SHOW_SHIPPING") {
                    this.sendNotification("SHOW_SHIPPING");
                  // MMM-Voice-Commands sends notification to MMM-ISS to HIDE
                  else if (notification === "HIDE_STATION") {
                    this.sendNotification("HIDE_STATION");
                  // MMM-Voice-Commands sends notification to MMM-ISS to SHOW
                  else if (notification === "SHOW_STATION") {
                    this.sendNotification("SHOW_STATION");
                  // MMM-Voice-Commands sends notification to MMM-PC-Stats to HIDE
                  else if (notification === "HIDE_STATS") {
                    this.sendNotification("HIDE_STATS");
                  // MMM-Voice-Commands sends notification to MMM-PC-Stats to SHOW
                  else if (notification === "SHOW_STATS") {
                    this.sendNotification("SHOW_STATS");
                  // MMM-Voice-Commands sends notification to MMM-Sudoku to HIDE
                  else if (notification === "HIDE_SUDOKU") {
                    this.sendNotification("HIDE_SUDOKU");
                  // MMM-Voice-Commands sends notification to MMM-Sudoku to SHOW
                  else if (notification === "SHOW_SUDOKU") {
                    this.sendNotification("SHOW_SUDOKU");
                  // MMM-Voice-Commands sends notification to MMM-SunRiseSet to HIDE
                  else if (notification === "HIDE_SUNRISE") {
                    this.sendNotification("HIDE_SUNRISE");
                  // MMM-Voice-Commands sends notification to MMM-SunRiseSet to SHOW
                  else if (notification === "SHOW_SUNRISE") {
                    this.sendNotification("SHOW_SUNRISE");
                  // MMM-Voice-Commands sends notification to MMM-SORT to HIDE
                  else if (notification === "HIDE_TIDES") {
                    this.sendNotification("HIDE_TIDES");
                  // MMM-Voice-Commands sends notification to MMM-SORT to SHOW
                  else if (notification === "SHOW_TIDES") {
                    this.sendNotification("SHOW_TIDES");
                  // MMM-Voice-Commands sends notification to MMM-EventHorizon to HIDE
                  else if (notification === "HIDE_TIMER") {
                    this.sendNotification("HIDE_TIMER");
                  // MMM-Voice-Commands sends notification to MMM-EventHorizon to SHOW
                  else if (notification === "SHOW_TIMER") {
                    this.sendNotification("SHOW_TIMER");
                  // MMM-Voice-Commands sends notification to MMM-ATM to HIDE
                  else if (notification === "HIDE_TRIVIA") {
                    this.sendNotification("HIDE_TRIVIA");
                  // MMM-Voice-Commands sends notification to MMM-ATM to SHOW
                  else if (notification === "SHOW_TRIVIA") {
                    this.sendNotification("SHOW_TRIVIA");
                  // MMM-Voice-Commands sends notification to MMM-Voice-Commands to HIDE
                  else if (notification === "HIDE_VOICE") {
                    this.hide(1000);
                  // MMM-Voice-Commands sends notification to MMM-Voice-Commands to SHOW
                  else if (notification === "SHOW_VOICE") {
                    this.show(1000);
                  // MMM-Voice-Commands sends notification to MMM-BMW-DS to HIDE
                  else if (notification === "HIDE_WEATHER") {
                    this.sendNotification("HIDE_WEATHER");
                  // MMM-Voice-Commands sends notification to MMM-BMW-DS to SHOW
                  else if (notification === "SHOW_WEATHER") {
                    this.sendNotification("SHOW_WEATHER");
                  // MMM-Voice-Commands sends notification to MMM-EarthWinds to HIDE
                  else if (notification === "HIDE_WIND") {
                    this.sendNotification("HIDE_WIND");
                  // MMM-Voice-Commands sends notification to MMM-EarthWinds to SHOW
                  else if (notification === "SHOW_WIND") {
                    this.sendNotification("SHOW_WIND");
                  // MMM-Voice-Commands sends notification to MMM-SelfieShoot to CAPTURE
                  else if (notification === "SELFIE_SHOOT") {
                    this.sendNotification("SELFIE_SHOOT");
      	addCommands: function(commands){
      		annyang.abort();
      		annyang.addCommands(commands);
      		annyang.start();
      	removeCommands: function(commands){
      		annyang.abort();
      		var test1 = typeof commands;
      		var test2 = Array.isArray(commands)
      		if(typeof commands === "object") annyang.removeCommands(Array.isArray(commands) ? commands : Object.keys(commands));
      		annyang.start()
      	getScripts: function() {
      		return[
      			this.file("js/annyang.min.js"),
        sdetweil @Alyx
        @alyx said in How do I use notfications:
        self.sendNotification(“SHOW_ALERT”, {type: “notification”, title: “Voice Commands”, message: “Deactivated”})
        thats all u have to do
        sendNotification(“string”, optional_parameters needed by receiver of message
        this is a broadcast… all modules get it…
        so when u figure out what the command is then do that
        self.sendNotification(“SELFIE_SHOOT”, ???)
        make sure ‘self’ is set when u make the call
        where ??? is optional parms, (don’t supply it if not used)
          Alyx @sdetweil
          Ok so for selfie shoot all I need to do is to input in my MM conf, self.sendNotification(“SELFIE_SHOOT”, “selfie”) ‘selfie’ is the voice command i wish to call. And I put this where i call the selfie_shoot module or the voice commands module?
          Sorry I’ll need some hand holding with the request haha
            sdetweil @Alyx
            sorry, after looking at the module, i don’t understand what its looking for in its config…
            supposedly you would have to write no code.
              Alyx @sdetweil
              @sdetweil so then should I remove my notification code and any reference I’ve made?
                sdetweil @Alyx
                @alyx i don’t know.
                  Alyx @sdetweil
                  @sdetweil I did there with no results, how would you usually set this up? I’ve tried following the documentation but its hard for myself to understand.
                  https://github.com/mykle1/Hello-Lucy/blob/master/How to add modules to Hello-Lucy
                  The dev of the custom config I use said to follow this but it doesnt make sense to me
                    Alyx
                    I was playing around with the default compliments module and apparently it is supposed to work out of the box with the voice_commands config I have although that doesnt seem to be the case… Am I doing something wrong form the start?
                      sdetweil @Alyx
                      @alyx are u an english speaker? if not translate the file to your language
                        Alyx @sdetweil
                        @sdetweil yep I am, I’m thinking of moving to another module. I’m thinking Hello Lucy, do you have any recommendations? As long as I can make it communicate with a module I dont care haha
                          sdetweil @Alyx
                          @alyx hello-lucy never worked for me… poor voice recognition, have to repeat myself 4 or 5 times…
                            Alyx
                            @sdetweil Ah damn, what would you recommend then? I need the interface to be voice driven
                              sdetweil @Alyx
                              @alyx as I said before, then only one I KNOW works is GoogleAssistant, BUT you ALSO have to do extra work to make YOUR command choice work. but there is little documentation on that, you have to discover it…
                              so its a lot MORE difficult than what u are already working on.
                                Alyx @sdetweil
                                @sdetweil Right so i’m not left with much choice then, is magic mirror left in the past then with the lack of support/ documentation?
                                  sdetweil @Alyx
                                  @alyx no… magic mirror is the runtime the modules plug into …
                                  I am here providing support, voluntary… but module support is up to the author.
                                  the voice_command thing is 3 years old.
                                  there are 100’s of modules… i don’t even TRY to learn them… but I look for install and config problems, and new users.
                                  but in many cases you the user, have to do extraordinary things to make some of these older modules work. BUT u need skills to do it
                                  we are a shared community… some users jump in to help on specific modules, or types of modules. .
                                  but still voluntary… some authors take the summer off, and work on modules in the winter…
                                    Alyx @sdetweil
                                    @sdetweil Understandable Sam, the support is of course appreciated as I mentioned before. My self studies can only take me so far in a certain amount of time is all.
                                    I’ll take your advise with google assistant for now and se if I can find some documentation regarding implementing other modules. I saw some PM2 ones working with Alexa in videos so that my plan after.
                                      sdetweil @Alyx
                                      @alyx ok, alexa here is a pain in the rear…
                                      for GA, look at the recipes folder
                                        Alyx @sdetweil
                                        @sdetweil ah ok will do then haha cheers
