    Problem starting various modules
    help
    3 Posts 2 Posters 1.2k Views 2 Watching
      jasjr54
      I have been running MagicMirror on a Raspberry Pi for the last year without any problems. Recently I set up a new Raspberry Pi that I also want to run MagicMirror on. However, after installing and configuring it, and then installing a couple of the same modules that work on the other Pi, I get the following error when starting up some of the modules:
      [09.11.2021 08:39.18.297] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-EveryNews/node_helper.js
      • /home/pi/MagicMirror/js/app.js
      • /home/pi/MagicMirror/serveronly/index.js
      This happens on only some of the modules including MMM-EveryNews, which works just fine on the other Pi. Other modules work just fine.
      Did I miss something during installation or is this new Pi missing something?
      Thanks!
        sdetweil @jasjr54
        @jasjr54 see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
          jasjr54 @sdetweil
          @sdetweil That did it! Many thanks!
